*Note: I made this exact post on a different website ( http://www.thetruckersreport.com/truckin...on-remover.html ) but I wanted to find out what this forum has to say about it*
Has anyone seen this product? Has anyone TRIED this product?
The following is posted on their website. (Source http://motorkote.com/64oz-motorkote-...n-remover.html )
Injection Stiction occurs when oxidation & carbon build-up form inside the injector. This is related to newer injection technology that runs hotter & causes the oil side of the injector to stick or foul. MotorKote® Diesel Stiction Remover™ removes carbon build-up & provides a coating to eliminate friction in diesel injectors.
BENEFITS:
• Often Restores Fouled Injectors
• Helps Restore Lost Power & Compression
• Fights Deposit Build-up
• Helps Reduce Friction Drag & Wear
• Helps Prevent Build-up of Harmful Chemical Oxidation
• Helps Reduce Noise & Vibrations in Lifters & Valves
• Reduces Blow-by & Helps Smooth Idle
RECOMMENDED USAGE:
• Initial cleanup in Pickup Truck replace 64 fl oz of oil with Diesel Stiction Remover®
• Prevention replace 32 fl oz of oil
• Initial cleanup in Semi Truck replace 128 fl oz of oil with Diesel Stiction Remover®
• Prevention replace 64 fl oz of oil
I haven't found anyone talk about this product on forums, but when I start looking up other products of theirs, 80% seem to be bogus promotional posts from Chinese marketing firms (single post users with unsubstantiated claims), with 20% seeming to be from legitimate forum users (high post counts). I'd love to believe a witch doctor, but I'm not willing to spend what will be nearly $130 after taxes and shipping costs on snake oil. Just wanting thoughts or experiences.
I always add Lucas or Howes to my fuel, but thought maybe trying this might offer additional help to improve performance.
BENEFITS:
RECOMMENDED USAGE:
