Unused Bosch 3313 cartridge
by Run
02/07/16 11:14 PM
David Fry in his own words
by Merkava_4
02/07/16 11:02 PM
Trans Pacific Partnership
by Merkava_4
02/07/16 09:57 PM
Schaeffer 711 10w30 Detroit 60 12.7
by TiredTrucker
02/07/16 09:17 PM
2012 Mazdaspeed3 transaxle 36k OCI 75W80
by MD1032
02/07/16 09:13 PM
Ford announces new assembly plant in Mexico.
by mrsilv04
02/07/16 09:10 PM
Guy with a cart full of Euro 5W40
by ledslinger
02/07/16 08:51 PM
Ever wonder how the new Camaro is made?
by BobsArmory
02/07/16 08:43 PM
Credit Card Reader 4 Smart Phone-Small Business
by crazyoildude
02/07/16 08:16 PM
talent doesn't pay like it used to.
by motor_oil_madman
02/07/16 07:46 PM
Disappointed with Accord after one Salt Exposure
by JHZR2
02/07/16 06:58 PM
Valvoline white bottle 2.99 at Menard's.
by jhellwig
02/07/16 06:47 PM
slewman, lithium1189, Monktana, djh3, Compignite
56850 Registered Users
55 registered (bdcardinal, Bill_G, Bandito440, Astro14, ajchien, 4 invisible), 806 Guests and 96 Spiders online.
56850 Members
66 Forums
244397 Topics
Page 1 of 2 1 2 >
#3237750 - 01/04/14 10:02 PM Antifreeze question
Plumber Offline
Loc: USA
Prestone antifreeze tester says the liquid is rated to -15 degrees. Is this when it actually freezes solid, or gets slushy?
#3237760 - 01/04/14 10:11 PM Re: Antifreeze question [Re: Plumber]
Donald Offline
Loc: Upstate NY
I would put a little in a Dixie and see how it does at 0F which is what your freezer should be.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3237854 - 01/05/14 12:13 AM Re: Antifreeze question [Re: Plumber]
Kuato Offline
Loc: 327km N of the other border
Considering the precision of those testers, err on the safe side and figure it will eventually freeze at -15, with the normal transition from liquid to slush to soft ice to hard frozen.
If you have the chance and location, maybe a radiator drain and refill with 100% coolant is in order. (Adjusted for system capacity)
Amsoil user.
13 F150, 5.0, 69000km (43k mi)
04 Wrangler, 2.4, 312000km (194k mi)
#3237880 - 01/05/14 12:51 AM Re: Antifreeze question [Re: Kuato]
crazyoildude Offline
Loc: New Jersey
100% coolant? Never a good idea Never! 50/50
#3237907 - 01/05/14 03:31 AM Re: Antifreeze question [Re: crazyoildude]
KitaCam Offline
Loc: SunnySouthFlorida
Yes! 50-50 is good to -34F (I think that's about -37C)
Kitacam is an 05 Camry LE/I4/MT; 6/15 @ 132,500....Pennzoil Plat-Plus 5w-30 for the hot summer...with Toyo filter
#3237911 - 01/05/14 03:49 AM Re: Antifreeze question [Re: crazyoildude]
shDK Offline
Loc: Denmark
perhaps the guy meant he should drain a bit of the coolant in the system. maybe a litre, and then refill with concentrated coolant. To adjust the freezing point. i think that what what he meant.
#3237964 - 01/05/14 07:25 AM Re: Antifreeze question [Re: Plumber]
NHGUY Offline
Loc: USA
100% will freeze.Water is the carrier of thermal conductivity.
#3238017 - 01/05/14 08:41 AM Re: Antifreeze question [Re: Plumber]
JHZR2 Offline
Loc: New Jersey
Slush and solid is just a matter of time. The differentiation is thermal mass (how much heat the engine block retains.
You could make a practical assessment of how often and for how long is the temperature actually -15? Maybe not long or never.
Still, to me that means your as is a little light, as it still gets quite cold in IL. I'd just siphon a small amount of your current AF and replace it with neat AF and call it a day. You can do a calculation to determine how much you need, and you definitely don't want to get too much glycol in there, but you should add some.
#3238064 - 01/05/14 09:35 AM Re: Antifreeze question [Re: Plumber]
Plumber Offline
Loc: USA
Severe cold is hitting tonight. I plan on warming up the 54, then dilute some more antifreeze.
A month ago I figured -15 would be fine! Ugh....
#3238154 - 01/05/14 11:15 AM Re: Antifreeze question [Re: Plumber]
doitmyself Offline
Loc: MI
My Prestone antifreeze tester pictured below turned out to be incorrect.
Try to find a shop that has a refractometer to test your juice. It takes less than 5 minutes time.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#3238247 - 01/05/14 12:27 PM Re: Antifreeze question [Re: Plumber]
Plumber Offline
Loc: USA
I just got back from the yard. The beater 54 took 5 cranks to start, I let it run for 30 minutes, added about a gallon of 60/40 and let it run another 10 minutes. My biggest gripe would be a cat or critter making a home on the warm engine!
Running a 5w-30 National brand oil, and a blue bottle of STP...sounded great upon start up! Not bad for a 230 flathead from 1954 in bad temps!
Edited by Plumber (01/05/14 12:33 PM)
#3238495 - 01/05/14 03:51 PM Re: Antifreeze question [Re: shDK]
Kuato Offline
Precisely. I wish people would read for content.
I said, "radiator drain and refill...adjusted for capacity". We don't need to do the math for OP but an adjustment from the current protection to a 50/50 situation would be a good idea.
And to be fair I should have said to adjust to 50/50 in the first post.
Edited by Kuato (01/05/14 04:05 PM)
Amsoil user.
#3238757 - 01/05/14 08:36 PM Re: Antifreeze question [Re: doitmyself]
Jiblet Offline
Loc: Massachusetts
A decent coolant refractometer can be bought for around $25.
Those floating ball things are worse than useless.
#3238893 - 01/05/14 11:00 PM Re: Antifreeze question [Re: Jiblet]
Loc: New Jersey
we use those exact type testers and have no issues with them
My Personal Choice Of Engine Oil Is Usually PYB And PHM For My Dino Choices, As For Synthetic I Like The QSUD..
Oil Filters Anything Wix Or Fram Ultra.
#3239055 - 01/06/14 07:30 AM Re: Antifreeze question [Re: Kuato]
Wilhelm_D Offline
Loc: Tacoma, WA
100% ethylene glycol would result in protection to about 10 F.
That's the freezing point of pure ethylene glycol, but when you mix ethylene glyclol with water, the mixture does not readily crystallize and the freezing point of the mixture is depressed. So a mixture with water is better than pure antifreeze.
The other problem pure ethylene glycol presents is that it does not transfer heat as well as water. For a cooling system with pure ethylene glycol the circulated volume must be increased compared to a system with clean water alone.
Ethylene Glycol Heat-Transfer Fluid
The optimum mix for antifreeze purposes is about 2/3 ethylene glycol to 1/3 water.
Page 1 of 2 1 2 >
