Mobil 1 ESP 5W30 on MY12 Jeep Grand Cherokee CRD
by Swampyy
4 minutes 33 seconds ago
Party Time
by widman
5 minutes 7 seconds ago
303 application process for engine bay
by buster
34 minutes 14 seconds ago
F1 - 2016 Russian Grand Prix
by gofast182
Today at 06:03 AM
VR1 Only suitable for 3 month / 3000mi oci's?
by FordCapriDriver
Today at 04:07 AM
4-year old oil in a sealed container
by rickeroo
Today at 12:05 AM
Cowboys fans should be happy tonight.
by deven
Yesterday at 11:03 PM
2012 Civic - MaxLife ATF update
by sw99
Yesterday at 10:58 PM
Champ PH820 on closeout at Rockauto
by sw99
Yesterday at 10:52 PM
Is two years too long?
by kohnen
Yesterday at 10:34 PM
Keep getting TR.APK popup on S III cell phone...
by daves66nova
Yesterday at 10:16 PM
Curse You Road Salt Version 2
by Oldtom
Yesterday at 07:34 PM
Dmax7901, carver1, Handy7rick, sicilien, Crater_77
57738 Registered Users
74 registered (alarmguy, Al, badtlc, A_Harman, ARCOgraphite, 951Indy, 4 invisible), 1615 Guests and 127 Spiders online.
57738 Members
66 Forums
248200 Topics
Page 1 of 2 1 2 >
#3237750 - 01/04/14 10:02 PM Antifreeze question
Plumber Offline
Loc: USA
Prestone antifreeze tester says the liquid is rated to -15 degrees. Is this when it actually freezes solid, or gets slushy?
#3237760 - 01/04/14 10:11 PM Re: Antifreeze question [Re: Plumber]
Donald Online   content
Loc: Upstate NY
I would put a little in a Dixie and see how it does at 0F which is what your freezer should be.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- 4-sale
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3237854 - 01/05/14 12:13 AM Re: Antifreeze question [Re: Plumber]
Kuato Online   confused
Loc: In transit...
Considering the precision of those testers, err on the safe side and figure it will eventually freeze at -15, with the normal transition from liquid to slush to soft ice to hard frozen.
If you have the chance and location, maybe a radiator drain and refill with 100% coolant is in order. (Adjusted for system capacity)
You like what you like.
Amsoil
13 F150, 5.0, 78000km (48k mi)
04 Wrangler, 2.4, 312000km (194k mi)
#3237880 - 01/05/14 12:51 AM Re: Antifreeze question [Re: Kuato]
crazyoildude Offline
Loc: New Jersey
100% coolant? Never a good idea Never! 50/50
#3237907 - 01/05/14 03:31 AM Re: Antifreeze question [Re: crazyoildude]
KitaCam Offline
Loc: SunnySouthFlorida
Yes! 50-50 is good to -34F (I think that's about -37C)
Kitacam is an 05 Camry LE/I4/MT; 3/16 @ 137,000....MaxLife Syn Blend 5w-30...with P1 filter
#3237911 - 01/05/14 03:49 AM Re: Antifreeze question [Re: crazyoildude]
shDK Offline
Loc: Denmark
perhaps the guy meant he should drain a bit of the coolant in the system. maybe a litre, and then refill with concentrated coolant. To adjust the freezing point. i think that what what he meant.
#3237964 - 01/05/14 07:25 AM Re: Antifreeze question [Re: Plumber]
NHGUY Offline
Loc: USA
100% will freeze.Water is the carrier of thermal conductivity.
#3238017 - 01/05/14 08:41 AM Re: Antifreeze question [Re: Plumber]
JHZR2 Offline
Loc: New Jersey
Slush and solid is just a matter of time. The differentiation is thermal mass (how much heat the engine block retains.
You could make a practical assessment of how often and for how long is the temperature actually -15? Maybe not long or never.
Still, to me that means your as is a little light, as it still gets quite cold in IL. I'd just siphon a small amount of your current AF and replace it with neat AF and call it a day. You can do a calculation to determine how much you need, and you definitely don't want to get too much glycol in there, but you should add some.
#3238064 - 01/05/14 09:35 AM Re: Antifreeze question [Re: Plumber]
Plumber Offline
Loc: USA
Severe cold is hitting tonight. I plan on warming up the 54, then dilute some more antifreeze.
A month ago I figured -15 would be fine! Ugh....
#3238154 - 01/05/14 11:15 AM Re: Antifreeze question [Re: Plumber]
doitmyself Offline
Loc: MI
My Prestone antifreeze tester pictured below turned out to be incorrect.
Try to find a shop that has a refractometer to test your juice. It takes less than 5 minutes time.
"There are things you do that put food on the table, and there are things you do that feed your soul." I am blessed to have them be the same things.
#3238247 - 01/05/14 12:27 PM Re: Antifreeze question [Re: Plumber]
Plumber Offline
Loc: USA
I just got back from the yard. The beater 54 took 5 cranks to start, I let it run for 30 minutes, added about a gallon of 60/40 and let it run another 10 minutes. My biggest gripe would be a cat or critter making a home on the warm engine!
Running a 5w-30 National brand oil, and a blue bottle of STP...sounded great upon start up! Not bad for a 230 flathead from 1954 in bad temps!
Edited by Plumber (01/05/14 12:33 PM)
#3238495 - 01/05/14 03:51 PM Re: Antifreeze question [Re: shDK]
Loc: In transit...
Precisely. I wish people would read for content.
I said, "radiator drain and refill...adjusted for capacity". We don't need to do the math for OP but an adjustment from the current protection to a 50/50 situation would be a good idea.
And to be fair I should have said to adjust to 50/50 in the first post.
Edited by Kuato (01/05/14 04:05 PM)
Amsoil
#3238757 - 01/05/14 08:36 PM Re: Antifreeze question [Re: doitmyself]
Jiblet Offline
Loc: Massachusetts
A decent coolant refractometer can be bought for around $25.
Those floating ball things are worse than useless.
#3238893 - 01/05/14 11:00 PM Re: Antifreeze question [Re: Jiblet]
Loc: New Jersey
we use those exact type testers and have no issues with them
In Automotive class when i was a kid i had a shop teacher that always said ..Its Nice To Be Nice! That is one thing i always remembered..
#3239055 - 01/06/14 07:30 AM Re: Antifreeze question [Re: Kuato]
Wilhelm_D Offline
Loc: Tacoma, WA
100% ethylene glycol would result in protection to about 10 F.
That's the freezing point of pure ethylene glycol, but when you mix ethylene glyclol with water, the mixture does not readily crystallize and the freezing point of the mixture is depressed. So a mixture with water is better than pure antifreeze.
The other problem pure ethylene glycol presents is that it does not transfer heat as well as water. For a cooling system with pure ethylene glycol the circulated volume must be increased compared to a system with clean water alone.
Ethylene Glycol Heat-Transfer Fluid
The optimum mix for antifreeze purposes is about 2/3 ethylene glycol to 1/3 water.
Page 1 of 2 1 2 >
