PL10241 Cut Open
by Vegoose
02/11/16 11:15 PM
Seems like common sense to me......
by Doog
02/11/16 11:14 PM
Thinking of buying an old diesel Benz
by Diego3336
02/11/16 10:46 PM
Mobil 1 5W30 5279 Miles 06 Toyota Tacoma V6 401k
by qnyla
02/11/16 09:43 PM
2007 corolla oil pan steel or aluminum?
by Rolla07
02/11/16 09:07 PM
Taiwan DMV "Mechanical Knowledgee" Test Question
by Ducked
02/11/16 08:56 PM
Paint correction
by mjoekingz28
02/11/16 08:55 PM
Filtertran Filter From My Vehicle 96K Miles
by oil_abuser
02/11/16 08:53 PM
Bleeding brakes cleanly
by mjoekingz28
02/11/16 08:51 PM
Any thoughts on the Super Bumper? (Hitch Bumper)
by Fsharp
02/11/16 08:37 PM
Ransomware.....
by BrianF
02/11/16 08:22 PM
Electic motor lube oil
by Ztill
02/11/16 07:39 PM
engus, Rob_Pol, Nick24w, SkipKaye, MikeHancho
56899 Registered Users
70 registered (bbhero, BTLew81, bdcardinal, 01rangerxl, akela, Bandito440, 3 invisible), 881 Guests and 214 Spiders online.
56899 Members
66 Forums
244576 Topics
#3237949 - 01/05/14 06:52 AM Keeping up the AC in winter FYI
mjoekingz28 Offline
Loc: The Stack Rankin County
I've heard that you should exercise the AC so the seals do not get brittle and leak, but how is this possible if the AC won't kick on in cold temps.
Also, what do you think? If temps are above 40F or so, running it for 5 minutes once a month would suffice.
I got lucky 2 years ago, our winter stayed relatively warm and I had to run the ac throughout the season and I didn't even need to add the usual can of freon in the following summer. But this last year I tried adding 2 cans and the compressor did kick on, but the air never got cold.
Thanks for all the help over the years BITOG.
"...all go no quit....."
Armageddon
"...remember; this hurts us more than it hurts you"
House Arrest
#3237950 - 01/05/14 06:54 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
Quakish Offline
Loc: Ontario, CA
every time i turn on the defroster my ac kicks in. car is 10 yrs old and never a problem with ac (i think i may have just jinxed myself though)
#3237953 - 01/05/14 07:08 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
Donald Offline
Loc: Upstate NY
Once a month for the oil to splash against the O-rings. Most cars turn on the AC when you go to defrost. Even if the light does not come on.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3237954 - 01/05/14 07:08 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
dave180 Offline
Loc: Milwaukee, Wisconsin
The A/C is designed to cycle when in the defrost position for this very purpose. It circulates Freon and the air you are blowing on the windshield is dehumidified.
If two can of Freon were added and air never got cold you may have a leak, the high pressure switch may be bad, receiver/dryer is bad, etc. I would suggest a competent/proper A/C shop diagnosis with pressure gauges, Freon dye, etc.
2014 Dodge Journey 3.6 (Pentastar)
2000 Ford Windstar SEL 3.8
2000 Toyota Corolla LE 1.8
2003 Nissan Altima 2.5
#3237955 - 01/05/14 07:09 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
Donald Offline
Loc: Upstate NY
But its no guarantee. There are 2 sides to the O-ring and you only condition the inside surface. So it helps with O-ring failure, but does not prevent it.
#3237966 - 01/05/14 07:32 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
Chris Meutsch Offline
Loc: Cincinnati
After seeing this topic discussed before and a guy said he turns it on when he buys a new car and never turns it off again, I've done just that. Mine is always on now and I simply adjust the temp as needed.
"I have a plan:
Please send snacks."
---surfstar, 2/3/16
#3237998 - 01/05/14 08:18 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
JHZR2 Offline
Loc: New Jersey
Mine is always on for the most part. I do turn off all accessories before starting the car,but as soon as the car is on, so is the AC.
Mercedes recommends running it once a month minimum, and I don't see what the big issue is. Why only 5 minutes? The system hasn't stabilized in 5 minutes. Run it for a long while.
#3238004 - 01/05/14 08:22 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
sciphi Offline
Loc: Upstate NY
It runs anytime you run the defroster. Our cars take a bit to clear the windows with this humid winter environment, so the A/C gets a good workout regularly.
2009 Honda Fit Sport
2012 Chevrolet Cruze Eco
#3238031 - 01/05/14 08:59 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
KrisZ Offline
Loc: Toronto, Canada
In winter I use defrost a lot so the AC turns on quite often. I noticed that even when it quite cold outside, like -10C, that AC will not turn ON when the car is cold, but at the end of my ~30 minute commute, when I'am at a red light or in slow moving traffic, the AC will kick in. I guess the underhood temps. must get just above freezing at that point.
Edited by KrisZ (01/05/14 09:00 AM)
2015 Dodge//Grand Caravan-Factory Fill
2006 Mazda 3-135k miles
#3238069 - 01/05/14 09:39 AM Re: Keeping up the AC in winter FYI [Re: mjoekingz28]
edwardh1 Offline
Loc: Coastal South Carolina
if you have a garage, park car in garage after driving it fully- engine hot.
wait 30 min, engine heat should heat the a/c compressor, back out of garage, then cut on the a/c for 5 min
I know women who are always late, they do not allow travel time, they think like Star trek, you leave one place and materialize somewhere else.
#3238420 - 01/05/14 02:58 PM Re: Keeping up the AC in winter FYI [Re: edwardh1]
Tosh Offline
Loc: Silicon Valley
Why does one need to actually back out of the garage during this voodoo ritual?
#3238492 - 01/05/14 03:50 PM Re: Keeping up the AC in winter FYI [Re: Tosh]
TFB1 Offline
Loc: VA
As already mentioned most vehicles activate the compressor when in defrost(for aiding defrost not just to cycle the compressor)... Outside of BITOG these ritualistic procedures are rarely observed...
