Thin oil, thick oil, synth or dino,
by Cruzingoose
02/13/16 11:25 PM
Compete today? Modernize your skills on own time
by spackard
02/13/16 11:23 PM
Castrol 0w30 leaving Advance Auto Parts
by bbhero
02/13/16 10:53 PM
Oil Change Marathon Today
by BlueOvalFitter
02/13/16 10:01 PM
Raybestos Advance Tech or Police Rotors?
by shiny
02/13/16 09:57 PM
Oil filtration and circulation question
by Doublehaul
02/13/16 09:41 PM
Anyone ever replaced brake fluid on Honda Pilot?
by Islandvic
02/13/16 09:19 PM
Unused WIX 51372-051815C2 cut & post
by WellOiled
02/13/16 08:37 PM
-31 this morning...without the wind chill!
by Doublehaul
02/13/16 08:00 PM
Cleaning Throttle body, necessary service now?
by Colt45ws
02/13/16 07:33 PM
[Cut Open] Ford OE (FL500S equivalent) 4948mi
by DuckRyder
02/13/16 07:20 PM
[Cut Open] Fram XG3600 - 9098mi
by DuckRyder
02/13/16 07:16 PM
Tsr71, SubaFool, dookchoppa, Formula413, Cruzingoose
56910 Registered Users
49 registered (bdcardinal, B320i, bigdawg74, 11 invisible), 941 Guests and 128 Spiders online.
56910 Members
66 Forums
244670 Topics
#3235665 - 01/03/14 09:26 AM Amsoil DEO 5w40, 8K, 04 Dodge 2500HD
dhellman12 Offline
Loc: Keller, TX
Owner previously maintained 5k mile OCI using Valvoline Premium Blue. Will suggest he run the 10K on this fill as indicated by Blackstone, and then push him to switch over to AME.
Make/Model: Cummins ISB 5.9L
Vehicle: 2004 Dodge 2500HD
Code:
OIL             DEO 5w40
MILES IN USE    8K
MILES ON UNIT   178,400
SAMPLE TAKEN    12/3/13
MAKE UP OIL	0
ALUMINUM	3
CHROMIUM	2
IRON		44
COPPER		4
LEAD		1
TIN		1
MOLYBDENUM	41
NICKEL		0
MANGANESE	1
SILVER		3
TITANIUM	4
POTASSIUM	3
BORON		29
SILICON		4
SODIUM		6
CALCIUM		900
MAGNESIUM	1232
PHOSPHORUS	1091
ZINC		1222
BARIUM		0
SUS @ 210F	81.2
Visc @ 100C	15.83
Flashpoint	450
Fuel %		0.5
Antifreeze %	0.0
Water %		0.0
Insolubles %	0.4
Blackstone comments:
A mildly high viscosity was the only unusual find in this sample. It's still close to the 15W/40 range, and we're guessing the only reason it's up is that you used a little Lucas or something like that. Heat on the oil can cause the viscosity to thicken up, though we aren't seeing any of the other typical signs of heat (damage to the additives or lots of insolubles). And wear looks good. You're running your oil longer than average, and that's why wear is higher than average. The averages are based on ~6,700 miles on the oil. We'd change this fill at 10K.
04DMax 6.6L - Amsoil AME 15w40 180k
04Tahoe 5.3L - Amsoil ASL 5w30 187k
#3235712 - 01/03/14 10:06 AM Re: Amsoil DEO 5w40, 8K, 04 Dodge 2500HD [Re: dhellman12]
Donald Offline
Loc: Upstate NY
I am not sure I would move up to 10K OCI without getting a TBN.
But it looks good otherwise.
2015 Subaru Forester 2.5 engine/CVT PP & M1
2001 Jeep Grand Cherokee Laredo 4.0 - PP & M1
1999 Dodge Ram 2500 w/Cummins - Rotella T6 & M1
#3237507 - 01/04/14 06:48 PM Re: Amsoil DEO 5w40, 8K, 04 Dodge 2500HD [Re: dhellman12]
dnewton3 Offline
Loc: Indianapolis, IN
That Fe seems high for the 8k miles. It's not at a point of condemnation, but it's high. One UOA is not worthy of any decisions yet. Run a couple more and see if the Fe is typical or an anomaly.
Do you have any UOA history under the VPB? Would be interesting to see how it ran with the other lube.
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3237810 - 01/04/14 10:57 PM Re: Amsoil DEO 5w40, 8K, 04 Dodge 2500HD [Re: dhellman12]
dhellman12 Offline
Loc: Keller, TX
Donald, I'm not too worried about the TBN at 10K with this oil. Much more and I would agree with you.
dnewton, this was his first and only UOA on the truck. I agree, wish I had a little more background on the Fe. Hopefully I can get him to run a few more and see improvements in the metals and get the viscosity back down.
