Power Steering Fluid
by DWC28
52 minutes 23 seconds ago
Troy-Built 4.5hp running problem
by Kestas
Today at 09:26 AM
Conventional oil instead of synthetic
by corndogzombie
Today at 08:05 AM
kohler courage 15 issues
by tomm22
Today at 07:58 AM
Small overlap crash test?
by Huie83
Today at 07:39 AM
Top Tier Fuels and Tailpipe deposits
by virginoil
Today at 07:20 AM
Honda GX35 question
by dirtydannyd
Today at 02:08 AM
Need advices for oil filter inspection
by ST2008
Today at 01:45 AM
Supertech- ST3387- Virgin cut open
by FordBroncoVWJeta
Today at 01:06 AM
Clean battery with garden hose?
by SavagePatch
Yesterday at 11:55 PM
Toyota 5w20 blend?
by researcher
Yesterday at 11:36 PM
Smoked some baby backs today
by BeerCan
Yesterday at 10:28 PM
Ken_Clifton, HotDog15, curiousaboutoil, 01CAMRY, corndogzombie
58589 Registered Users
93 registered (1foxracing, 4WD, 18LateModelFan, 2015_PSD, 2002 Maxima SE, AIRJAC3, 7 invisible), 1869 Guests and 14 Spiders online.
58589 Members
66 Forums
252228 Topics
#3237784 - 01/04/14 10:31 PM winter weight oil for coleman powermate generator
docdavid Offline
Loc: michigan
I have a 10 year old Coleman Powermate generator with a 10 hp Tecumseh 4 cycle engine. Up until now it has only been used in warm weather and the manufacturer specified 30 weight oil has worked fine. I now want to be able to use the generator in winter weather but I cannot locate the owners manual and don't know what the proper viscosity oil would be. Any suggestions as to viscosity and conventional vs synthetic would be greatly appreciated.
#3237786 - 01/04/14 10:33 PM Re: winter weight oil for coleman powermate generator [Re: docdavid]
SuperDave456 Offline
Loc: Dallas, Texas
0w30, best oil for it year round.
Maybe a 0w40 if you think it is a little worn and want to have awesome protection in the Summer.
Either way, the oils have "freezing point" of something around -47 degrees F most of the time and a very robust synthetic base that is great at higher temperatures.
#3237795 - 01/04/14 10:41 PM Re: winter weight oil for coleman powermate generator [Re: docdavid]
mattwithcats Offline
Loc: Virginia
Agreed...
First number is viscosity when cold, 0W is the most fluid (liquid ) when cold,
Second number is viscosity when hot...
A 30 weight oil is ???W30, no idea what it's like cold, 30 weight when hot...
Use a synthetic, much longer run time (200 hours) vs Dino (60 hours).
Use an vibration hour meter to keep track of the run time...
Edited by mattwithcats (01/04/14 10:43 PM)
2009 Smart Pure
Pennzoil Platinum Euro 5W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#3237798 - 01/04/14 10:43 PM Re: winter weight oil for coleman powermate generator [Re: docdavid]
Donald Offline
Loc: Upstate NY
I think I have the same generator as my backup (to my propane) generator. I use Amsoil 4-Stroke 0W30 small engine oil in it. I have also used the Amsoil 4-Stroke 0W40 which I think was the original Amsoil 4-Stroke oil weight.
The carb is off right now being cleaned as it needed a little choke to keep it running halfway decent. But have yet to find anything that really looks dirty. Unfortunately they sell almost no parts for the carb. The gasket for the bowl is a little hard and needs replacement.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3237808 - 01/04/14 10:54 PM Re: winter weight oil for coleman powermate generator [Re: docdavid]
Ramblejam Online   content
Loc: Kentucky
If I told you it doesn't really matter (to a certain degree...), would you believe me?
Seriously though, look at Donald for a prime example -- it's always the fuel system that people have problems with on infrequently used small engines. Focus your attention on this system, and keep it in the best shape you can.
#3237812 - 01/04/14 10:57 PM Re: winter weight oil for coleman powermate generator [Re: mattwithcats]
Rand Offline
Loc: NE,Ohio
um no thats not even remotely correct.
crush crush
Originally Posted By: mattwithcats
Agreed...
2015 Forester I-Premium 6MT
#3237857 - 01/05/14 12:16 AM Re: winter weight oil for coleman powermate generator [Re: SuperDave456]
Kuato Offline
Loc: In transit...
^this.
Your oil's condition is speculation until you get a UOA done.
2013 F150, 5.0 4x4, 52k Schaeffer 9000
#3237959 - 01/05/14 07:12 AM Re: winter weight oil for coleman powermate generator [Re: docdavid]
cronk Offline
Loc: Watertown, New York
Rotella 5w40 synthetic, available at any Walmart.
or if your so inclines Amsoil makes a small engine oil, I think its a 10w30.
1998 GMC C1500
2003 Chevy Cavalier
2011 Nissan Quest
1986 Pontiac Trans Am
1940 Ford 9N Tractor
#3237973 - 01/05/14 07:44 AM Re: winter weight oil for coleman powermate generator [Re: docdavid]
Cujet Offline
Loc: Jupiter, Florida
Those engines are sensitive to oil viscosity during hot and heavy use. Choose your oil carefully. Plenty of Tecumseh engines broke connecting rods due to "dino" 5W-30 after the FL hurricanes. The local shop had nearly 100 of them for repair for the exact same issue.
Winter ops: Chose something like Mobil 1, 5W-40 Turbo Diesel Truck or Rotella T6. If you pick a super thin, cheap oil, there is a risk it will remain in the engine during summer ops.
Summer ops: 5W-40 or 15W-50M1.
Turbo's rule.
#3238039 - 01/05/14 09:06 AM Re: winter weight oil for coleman powermate generator [Re: docdavid]
KD0AXS Offline
Loc: Nowthen, MN
I'd put Rotella T6 in it and use it year round.
2014 Hyundai Elantra Coupe 2.0 GDI-PUP 0W-40
2013 Jeep Wrangler JKU-PUP 5W-20
2005 Ford F-350 4x4 5.4-Maxlife 5W-20
2000 John Deere 425-Rotella T6
#3238150 - 01/05/14 11:10 AM Re: winter weight oil for coleman powermate generator [Re: docdavid]
tig1 Offline
Loc: Illinois
I use M1 10-30 in my Powermate with the Subaru engine. It performs very well in all temps.
2007 Ford Fusion 184,000 miles
M1 0-20 AFE
2007 Ford Focus 156,000 miles
M1 0-20 AFE
M1 ATF
M1 10-30 in all OPE
MC filters
