Will ATP205 help with a head oil leak
by NattyBoh
15 minutes 36 seconds ago
Why is 100% gas more expensive in the city?
by TurboFiat124
20 minutes 26 seconds ago
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
28 minutes 40 seconds ago
Murphy oil
by TurboFiat124
33 minutes 21 seconds ago
I think I'm getting pure gas again
by eljefino
57 minutes 37 seconds ago
CV boots ripped on Chevy Blazer
by dlundblad
Today at 07:02 PM
Built-in pour spout on Delvac jugs
by fdcg27
Today at 06:45 PM
Mobil 1 question
by Moondawg
Today at 06:36 PM
Mold & Moisture Resistant Drywall
by Warstud
Today at 06:36 PM
FRAM EG 3614, 5,000 miles, CUT OPEN
by car51
Today at 06:25 PM
FRAM XG2, 10,xxx miles CUT OPEN
by car51
Today at 05:33 PM
MC FL-820S, 7.6K miles, 2012 F-250
by car51
Today at 04:41 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
113 registered (182RG, 2015_PSD, 4WD, 69GTX, 901Memphis, 7 invisible), 1784 Guests and 14 Spiders online.
58584 Members
66 Forums
252208 Topics
Page 1 of 2 1 2 >
#3237743 - 01/04/14 09:57 PM Electric Vehicles and US' current cold snap
Shannow Offline
Loc: Oz
Seeing EVs touted as the future, the abandonment of discussions regarding cold start idle etc...and that cranking batteries may be down by over 50% on these extreme mornings.
Got me wondering about EVs in the US, particularly the cold.
First up, is it just lead acid that will lose 50% in the extreme cold ?
Secondly, heating how to ?
#3237759 - 01/04/14 10:11 PM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
Ramblejam Offline
Loc: Kentucky
"In general, Lithium-ion cells cannot be charged below 0 degrees Celsius, which would theoretically prevent charging in cold environments. To overcome this cold weather charging obstacle, the Roadster is designed with a heater to warm the cells (when plugged in) to an appropriate charging temperature. If there were no battery pack heater, drivers living in cold environments would have difficulty charging and experience stunted driving performance.
Likewise, the cells are designed to operate in high-temperature environments. High-performance driving is possible in even the hottest environments of the world. If the temperature rises above a set threshold, the air conditioning unit sends chilled coolant through the pack. Similar to the radiator fan of ICE-powered cars, the chilled coolant continues to circulate after the motor has been turned off to keep the temperature at an appropriate level. Cooling the pack enables a driver to quickly charge immediately after hard driving in hot climates. Without such a cooling system, recharging in hot weather would be delayed after each drive."
http://www.teslamotors.com/roadster/technology/battery
#3237791 - 01/04/14 10:37 PM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
mattwithcats Offline
Loc: Virginia
Leave car plugged in, start car and turn on the heat / defrost.
Once car is warm inside, (60 - 70) unplug and depart.
Some have a "Departure Time" feature that will pre-warm the car up and have it ready at a preset time...
Don't run the heat unless necessary, use the seat heaters. It's a lot less current draw...
2009 Smart Pure
Pennzoil Platinum Euro 5W-40, Purolator Synthetic PSL 14610, 45 mpg...
185/55R15 General HP tires, "H" speed rated, 44 psi (300 kpa)
#3237805 - 01/04/14 10:49 PM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
Happy Birthday Pablo Offline
Loc: Duvall WA - Pacific NW USA
I'm a bit paranoid. I brought my LiCoMn batteries inside. Well they are bike batteries so that was easy.
#3237864 - 01/05/14 12:25 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
dparm Offline
Loc: Chicago, IL
Most of them have battery warmers, but range will still suffer.
2011 BMW M3 sedan ZCP
#3237871 - 01/05/14 12:31 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
Garak Offline
Loc: Regina, Saskatchewan, Canada
Automakers love to brag and show videos of how they test their cars in Death Valley and in the Arctic. I would like to see the same with EVs, particularly in the Arctic. Let's see how warm an interior gets when it's -40 outside. wink
Plain, simple Garak.
2008 Infiniti G37 coupe - Mobil Delvac 1 ESP 5w-40, Wix 51358
1984 F-150 4.9L six - Quaker State GB 10w-30, Wix 51515
#3237888 - 01/05/14 12:59 AM Re: Electric Vehicles and US' current cold snap [Re: dparm]
Miller88 Offline
Loc: Onondaga County
The fit ev suffers really bad. Goes from like 60 mile to 15 mile range
A Lada with manually adjusted drum brakes sounds like a fantastic car.
2000 Cherokee / 2011 Focus
#3237913 - 01/05/14 04:23 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
oilmaven Offline
Loc: Northern Michigan
GM has had issues with the electric heating system in the Volt. Owners have complained of woefully inadequate heating during EV driving mode in cold temps. The only solution is stronger electric heaters with the higher draw/lower range penalty they exact (not sure if the newer models have addressed the heating issue). It's predicted to get to -25F here by tomorrow night...seat heaters don't cut it when it's that cold (though they help a lot during milder weather).
2010 Suzuki Kizashi-Pennzoil Platinum Pureplus 5W30
2013 Toyota Prius-Pennzoil Platinum 0W20
#3237915 - 01/05/14 05:11 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
Rick in PA Offline
Loc: Southeastern, PA
There's always a good old fashioned gasoline fired heater:
Oh yeah, there's the issue of getting gasoline to it, minor problem. grin
Edited by Rick in PA (01/05/14 05:12 AM)
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3237922 - 01/05/14 05:55 AM Re: Electric Vehicles and US' current cold snap [Re: mattwithcats]
dlundblad Offline
Loc: Midwest
So for good mileage you have to go without heat.. Hybrids are great! LOL
2003 Grand Cherokee 4.0 PYB 10w30/ PH16
2002 Volvo S60 2.4T M1 0w40/ Mahle ox149d
#3237942 - 01/05/14 06:34 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
Nebroch Offline
Loc: Finlandistan
...or you can improve insulation, AC behaviour and waste heat management to get the heat up. Traditional cars have plenty of waste heat to use for heating purposes, so it hasn't gained much attention until now.
#3237944 - 01/05/14 06:41 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
Shannow Offline
Loc: Oz
Starting at -30, insulation doesn't gain much while the interior thermal mass gets up to temperature...and all the heat that is required to do so comes from the grid...which has already given up it's inefficiencies.
#3237945 - 01/05/14 06:45 AM Re: Electric Vehicles and US' current cold snap [Re: Nebroch]
dlundblad Offline
Loc: Midwest
This is correct, but it also shows yet again that hybrids are still a work in progress. Great concept. I'm sure they do excellent in moderate temps where the AC and heat don't have to be ran.. but for the person who lives in the colder or hotter temps they might as well be driving a diesel Jetta for fuel economy.
#3237965 - 01/05/14 07:28 AM Re: Electric Vehicles and US' current cold snap [Re: Shannow]
NHGUY Offline
Loc: USA
I'm surprised some didnt install wood stoves in the back seat,so mileage wouldnt suffer.Oh yea,theres the issue of the emissions from burning the wood...EPA wouldnt approve...
#3237985 - 01/05/14 07:59 AM Re: Electric Vehicles and US' current cold snap [Re: NHGUY]
Cujet Offline
Loc: Jupiter, Florida
Hahahahaa! That sounds exactly like something I'd say.....
Turbo's rule.
Page 1 of 2 1 2 >
