Originally Posted By: Pablo
Originally Posted By: JHZR2
My rhino ramps haven't slipped on smooth concrete or blacktop, but I would go for the metal ultra ramps with extender myself. And, in fact I'll probably pick up,a pair.
The way it's almost bipolar on the slipping I wonder if Rhino used different material for the feet. All I can say mine were like ice skating inside my garage, you could just slide them with a few ounces of force. They were just OK on my back pad which is rougher/more weathered and with proper technique didn't just skid or worse shoot through and under. My neighbor knows to only use them outside. And I'm sure they would not slip on blacktop.
Anyway, is this what you are mentioning:
http://www.autoramps.com/ultra_ramps.htm
Hmmm. Ive used them in my smooth concrete garage without issue too. Mine have a very gummy rubber pad under the front and rear. Its soft so I guess it compresses flat under load, and it does get chewed up...
I know they sometimes fall out. Wonder if the issue is that some folks lost theirs?
Yes, those are the ramps. The extenders are hard to find as was mentioned above, but with a 20% off HF coupon, the ramps could be had fairly cheap, and all four pieces will nest and store far easier and cleaner than rhinos or race ramps.
I also just posted about jackpoint jack stands. Might want to check them out.
