I have a quick question about SuperTechs Multi Duty High Temp Grease. I just rebuilt a 1950 GMC 3 speed manual transmission, and during the assembly I used a little bit of SuperTech's Grease (bought at Walmart) on the synchronizers. Mainly just because I didn't want to put the synchro rings in dry, and I had some of that grease on my bench. My question is, will this grease ruin the soft metal synchronizers (I believe they are brass)? I didn't think of that while I was putting in on there, but after reading a few post online about modern greases containing sulfur, which will harm the synchros, I got a little worried.
Is this grease ok on the brass synchros? It will probably be on there for a few months until I put the entire driveline back together and fill the tranny with gear oil. Should I tear it back apart and wipe that stuff off?
Also, would you recommend Penzzoil's Synchromesh GL4 gear lube, or is there a better GL4 lube you would recommend? I know other's recommend Red Line's GL4 lube. Which is better?
Any info you could provide me would be great.
Thanks in advance,
Jake
Thanks in advance,
Jake
