They might be in need of replacement, I am not sure. Some OEM platinum plugs go over 100,000 miles, some don't even go 60,000 miles. If your engine uses coil on plug ignition, buy new ignition coil boots at the same time.
Also, be sure to use a torque wrench, as some Ford V8 engines will blow out plugs if you don't use a properly set torque wrench.
