Lowes charcoal sale
by Bandito440
05/28/16 10:17 PM
Jeepers Creepers! (Jeep Patriot)
by daves87rs
05/28/16 10:10 PM
Need a tire
by Leo99
05/28/16 09:58 PM
Small Engine Oil Pressure
by funflyer
05/28/16 09:06 PM
Any harm in using a Motorcraft FL910S on a Tacoma?
by jongies3
05/28/16 08:50 PM
A/C performance woes...
by SEMI_287
05/28/16 08:49 PM
Red Line 10W30 Motorcycle oil particle count
by bulwnkl
05/28/16 08:08 PM
Microgard 51334 cut open
by dlundblad
05/28/16 08:07 PM
Differential Fluid Selection..
by Warstud
05/28/16 07:13 PM
The morality of riding a bike married with kids
by fdcg27
05/28/16 07:00 PM
Best synthetic oil for cleaning out an engine.
by anylettuce
05/28/16 06:58 PM
2013 ford fusion AC stank.
by leeaspell
05/28/16 06:46 PM
mungchimp, troutwest66, AIRJAC3, bpete65, LEVY
58001 Registered Users
76 registered (AirgunSavant, 69GTX, 4WD, 2015_PSD, albertdi, 5 invisible), 1166 Guests and 332 Spiders online.
58001 Members
66 Forums
249543 Topics
Page 1 of 2 1 2 >
#3230231 - 12/28/13 06:57 PM VW TDI Spec Oil 505.01
Nick1994 Offline
Loc: Phoenix, AZ
My aunt has a 2004 VW TDI with 152k miles, always serviced at the dealer with 10k miles OCI with synthetic. I've noticed the last 2 changes the paper says it is VW 504/507 oil. Is this oil spec back to the 505.01 it requires? I asked the service guy who has managed the service on her car for all these years and he said 507 back specs and works in this car. Is this true? Also the service sticker in the windshield says 5w30 on this oil change but the old ones used to say 5w40. Did they mess up?
2000 Toyota Camry 2.2L 211k
Pennzoil Platinum HM & Fram Ultra
#3230234 - 12/28/13 07:03 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
dparm Offline
Loc: Chicago, IL
The TDI forums seem to shy away from 505.01 oils. Apparently they cause premature cam wear -- I haven't followed the issue closely, but there is a lot of discussion around it. They seem to stick with 5w40 diesel truck oils.
A 504/507 oil would work just fine. There are a few 5w30s with that approval (they are thick-30s, along the lines of Castrol Edge 0w30).
2011 BMW M3 sedan ZCP
#3230240 - 12/28/13 07:11 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
What about 5W30 synpower XL 3
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
#3230242 - 12/28/13 07:14 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
Nick1994 Offline
Loc: Phoenix, AZ
The car will only be dealer serviced, she won't budge on it and they treat her well in the service department.
#3230243 - 12/28/13 07:15 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
Danno Offline
Loc: Northern Ontario, Canada
Then move on - nothing to see here.
#3230251 - 12/28/13 07:24 PM Re: VW TDI Spec Oil 505.01 [Re: Danno]
Nick1994 Offline
Loc: Phoenix, AZ
No, not move on. Im asking if they used the wrong oil. What's wrong with that?
#3230253 - 12/28/13 07:31 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
RamFan Offline
Loc: Illinois, U.S.A
504/507 is the current VW diesel spec. Sleep tight, the car is in good hands.
06 Monte Carlo LT
+3.9l V6 - 176k - Super S Multi-Flo 5w30 - Napa Silver - OLM
16.5 CX-5 Touring
+2.5l I4 - 6k - Mag1 0w20 - Mazda - OLM
#3230256 - 12/28/13 07:36 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
NMBurb02 Offline
Loc: Crowntown, CA
If they put in that oil, they are the only ones servicing it, and it suffers premature oil-related failure, then it is on them. If she will not go elsewhere, I see no point in stressing about it.
2002 Chevy Suburban 1500, G-Oil 5W-30, Fram TG3675
2006 Pontiac Grand Prix GT, M1 0W-40, Fram TG3387A
#3230264 - 12/28/13 07:46 PM Re: VW TDI Spec Oil 505.01 [Re: NMBurb02]
2004tdigls Offline
Loc: maple ridge, bc
vw 507 supersedes all previous diesel oil requirements, that being said most PD engines eat their cams when X/30 oils are used
#3230295 - 12/28/13 08:24 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
bigjl Offline
Loc: London, England
505.01 is what is specced for PD diesels in the UK
Since that spec was introduced the only PD's that have had top end issues were ones that were serviced with the wrong oil
Lots of vehicles used the PD engine, the early 1.9 version and the later 2.0
Everybody that I knew that had a PD engines Ford Galaxy, made in the same plant as the VW Sharan and Seat Alhambra till the joint venture ceased in around 06/07, used 5w40 though.
East to find as most oil manufacturers helpfully label it up as PD oil!
Could the issue be more to do with the 5w30 being a little on the thin side when the engine is hot.
But as already said as it has been dealer serviced from new any issue related to oil will be the responsibility of the dealer
I would ask for 5w40 to go in next time though
Has worked fine so far
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3233659 - 01/01/14 12:13 PM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
bobbydavro Offline
Loc: 3rd rock from the sun
Diesel dilution is the enemy here. Hence a 5W-40 with 505 01 is a good choice for PD engines.
The approval tests are ran on PD engines but the drive cycle doesn't really generate massive levels of fuel dilution like is seen on some road cars
#3233778 - 01/01/14 02:57 PM Re: VW TDI Spec Oil 505.01 [Re: RamFan]
UG_Passat Offline
Loc: NJ
Yes, it is the current spec, but with a lower TBN, the next question would be.... is the 10,000 mile OCI still suitable? For that.... it needs UOA's to be done.
#3233873 - 01/01/14 05:09 PM Re: VW TDI Spec Oil 505.01 [Re: RamFan]
bigjl Offline
But doesn't this spec relate to later Common Rail engines?
Surely they have different oil needs?
#3235802 - 01/03/14 11:16 AM Re: VW TDI Spec Oil 505.01 [Re: Nick1994]
Zambee500 Offline
Loc: Roswell, GA
VAG has made it unnecessarily complicated, and it's their own doing, but it's no wonder the dealerships are confused too.
The PD motors (2004-2005.5 TDIs in N. America) require 5w40 oil certified 505.01. It says so right in the owner's manual, and probably on the oil cap as well. The confusion started when VW later (2006 or after) began certifying many 5w30 oils as 505.01. It still doesn't change that your PD motor requires the 5w40 flavor. Again, says so in your owner's manual. Adding to the confusion, VW's next diesel oil certification requirement was 507.00, which VW eventually started also saying was indeed backward compatible with 505.01. But 507.00 only comes in 5w30, so again, it is not suitable for a PD motor that requires 505.01 in the 5w40 weight. And I am not aware of any VW car sold in North America that requires 505.01 that allows 5w30 weight, so that adds to the confusion. But your car still requires 5w40.
Bottom line is 5w30 eats cams in PD motors. Don't use it or let the dealership put it in your aunt's TDI with the PD motor. I wouldn't bother arguing with the dealership about whether it is the correct oil or not. It is futile. They feel it is. VWoA probably agrees. But 5w30 will kill the cam. There is even a separate VAG part number for the 505.01 in 5w40: G-052-167-M2. It's a Castrol. Just have your aunt tell the dealership that is what she wants in her car and don't argue about the 5w30 505.01 or 507.00 oils. You have to spoon feed the VW dealerships... you will probably teach the parts department something new when you give them the part number.
That's if she insists on having the car serviced at the dealership. That Castrol 5w40 product the VW dealerships use is fine, but there are many other excellent 5w40 oils certified 505.01 that are readily available including Pentosin, LubroMoly, etc. Also, many TDI owners with the PD motor over at tdiclub.com have found great luck with some 5w40 diesel oils not certified by VW at all, including Mobil 1 Turbo Diesel Truck, Shell Rotella T6, Mobil 1 ESP Formula M, Schaeffer 9000. Those would all be much much better than using a certified 505.01 that is 5w30. The key is 5w40.
Edited by Zambee500 (01/03/14 11:18 AM)
2005 Volkswagen Passat GLS TDI
2009 Volkswagen Routan SEL (Chrysler 4.0L V6)
#3236219 - 01/03/14 04:25 PM Re: VW TDI Spec Oil 505.01 [Re: Zambee500]
Nick1994 Offline
Loc: Phoenix, AZ
Thanks! It does say in the owners manual to use 5w40 but 5w30 is allowed. The next oil change I will have her have them use 5w40 because I already went in and asked what oil they used and they said 507 5w30 and that it back specs. Vey frustrating.
Page 1 of 2 1 2 >
