Strange failure: Starter AND flywheel cogs ripped
by lars11
07/29/16 02:22 PM
My email from Castrol about Magnatec
by Tech819
07/29/16 02:13 PM
Audi 5000 / Known Stop-Leak Compatible w/ CHF 7.1?
by Miles07PT
07/29/16 01:41 PM
Observations on Workplace corrosion
by Vdubuk
07/29/16 12:15 PM
Oil filter change NIGHTMARE
by MetalSlug
07/29/16 12:08 PM
First time flushing an 05 Tacoma
by Back40
07/29/16 11:53 AM
600-year-old plumbing works better than modern
by HTSS_TR
07/29/16 11:48 AM
Shopping for brand-new F-150
by jay929
07/29/16 11:35 AM
Audi Broken Oil Control Rings - Why???
by SonofJoe
07/29/16 11:27 AM
Royal Purple VS Mobil 1?
by 340six
07/29/16 11:09 AM
Condensing down to 1 vehicle
by krismoriah72
07/29/16 11:04 AM
Ford Focus door strip coming off
by FordBroncoVWJeta
07/29/16 10:41 AM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
95 registered (69GTX, Anduril, alanwayne1908, andrewlg, 2015_PSD, 4WD, 8 invisible), 2034 Guests and 10 Spiders online.
58632 Members
66 Forums
252405 Topics
#3231944 - 12/30/13 02:18 PM Valvoline -Premium Blue
Cudadude Offline
Loc: Texas
Greetings to all, I'm new to the forum. I have a question to the experts. I used to use the 15w 40 Rotella oil until I was talking to my dad and he had a dealer work on his diesel and told him he would be better off with the Valvoline oil brand. I have since then did some research and found this Valvoline 15w-40 Premium Blue synthetic blend oil.And have been using it with oil changes @ every 5000 miles.
The jury is still out on this oil, and really wanted to know if anyone else uses this. thx
#3231965 - 12/30/13 02:34 PM Re: Valvoline -Premium Blue [Re: Cudadude]
Rolla07 Offline
Loc: MTL, CANADA
Try and give us more information. Why was he told Valvoline is better? Better than what? Why 15W-40? What vehicle are you talking about?
Edited by Rolla07 (12/30/13 02:35 PM)
2007 Corolla Red Pearl 138k miles
Pennz Ultra 0w40 & Napa Proselect
#3231984 - 12/30/13 02:48 PM Re: Valvoline -Premium Blue [Re: Cudadude]
Phishin Offline
Loc: Indiana
Valvoline is EXCELLENT oil. Probably just as good as Rotella. Those oils are equals I'd suppose.
I run the same stuff, repackaged as Napa brand, in my truck. I like it.. .
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3231992 - 12/30/13 03:00 PM Re: Valvoline -Premium Blue [Re: Cudadude]
RF Overlord Offline
Loc: Cape Cod, MA
Cummins/Onan spec Valvoline Premium Blue for their generators. We had a 250kW (since replaced with twin 400kW CATs) that would consume Rotella. I switched to Premium Blue and it consumed noticeably less. Not terribly scientific I know, but there it is. The CATS are too new for me to have established any baselines.
Supercharged '03 Mercury Marauder - Trilogy Motorsports #61
PP 5W-30 / MC FL820S
Y2K Grand Marquis GS - daily driver
QSUD 5W-20 / MC FL820S
#3232029 - 12/30/13 03:46 PM Re: Valvoline -Premium Blue [Re: Cudadude]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
Thought premium blue was Dino, extreme was syn
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
#3232057 - 12/30/13 04:27 PM Re: Valvoline -Premium Blue [Re: Cudadude]
Dufus2 Offline
Loc: Virginia
I tore down some CAT engines that ran NAPA oil and there was no buildup or funny wear as this is a top of the line oil. Valvoline is just not as popular as the other diesel oils (Delvac, Rotella, Delo). Premium blue is just a little harder to find on store shelves and not on sale very often... I would run it if Valvoline Premium Blue was easy to obtain.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#3232571 - 12/31/13 08:06 AM Re: Valvoline -Premium Blue [Re: Cudadude]
dnewton3 Offline
Loc: Indianapolis, IN
Cudadude - welcome to the site welcome
I'll counter the advice your dad got.
I would disagree that VPB is "better" than Rotella. I would also say that Rotella is not "better" than Delvac, or Delo. I have seen excellent UOAs from all brands, and none of them indicate that one brand is superior to another. I've also see UOAs that indicate a problem, and none of them have ever shown that it was a brand-related issue (typically a mechanical issues manifesting into problems).
Opinions run far and wide on lubes and filter, but there is data available, if you're willing to go find it. Unfortunately, even the data is often misinterpreted. I suggest you start by reading this:
http://www.bobistheoilguy.com/used-oil-analysis-how-to-decide-what-is-normal/
My point is that "best" or "better" can be proven, but ONLY after a long series of testing is done, and at much expense. Micro data analysis is probably the most reliable methodology, but it's also the most expensive and time consuming by far. Macro data analysis is reliable, too, but still takes a major investment. And when I say "long" and "expensive", I mean L-O-N-G and E-X-P-E-N-S-I-V-E. I seriously doubt the guy who gave your dad that advice has any credible data to back up the statement that VPB is truly better than any alternative.
The reality is that if you and your dad are going to follow the OEM OCI routine, then any properly qualified lube will do just fine, and no one oil (or filter) is going to distinguish itself above another. In short, any API certified HDEO that is spec'd for your application will suffice well more than good enough.
If you want to be brand loyal, there is nothing wrong with that approach. But it's not really going to help or hurt your engine one way or another.
You don't mention what equipment you're running the HDEO in, but presuming it to be a typical light duty diesel engine, 5k miles is probably very conservative for the OCI. I'd suggest using the least expensive HDEO you can find. When you use an API certified lube, you're assuring excellent protection regardless of the brand. That in mind, the "best" lube is the one that provides that assurance of good performance at the least cost.
Edited by dnewton3 (12/31/13 08:08 AM)
Conventionals vs. Synthetics isn't about which is "better"; it's about which lasts longer, while assuring safe operation, in relation to cost. Any product can be over or under utilized. The same applies to filters.
Make an informed decision; first consider your operating conditions, next determine your maintenance plan, and then pick your lube and filter. Don't do it the other way around ...
#3233223 - 12/31/13 08:35 PM Re: Valvoline -Premium Blue [Re: Cudadude]
SilverC6 Offline
Loc: Southeast
Valvoline is good stuff. Use it if you believe in it.
'04 Mazda RX8 5W30 Valv Synpwr
'10 &'11 Camry 5W-20 PU
'11 Landcruiser 5W20 PU
'13 BMW 550IX BMW 5W30
'08 BMW Z4M Coupe TWS 10W60
'13 BMW M6 BMW 5W30
#3234795 - 01/02/14 02:33 PM Re: Valvoline -Premium Blue [Re: Cudadude]
Cudadude Offline
Loc: Texas
Thank you everyone for some great feedback and the warm welcome.
Sorry I didnt give all the information that I could have to better suit a good answer. I do feel for the most part my question was answered. Im probable over thinking the oil quality Im looking for. The reason I say this, is because I own a 2005 ton 4x4 Dodge with a cumin motor, with 109Mmile on it. I purchased the truck new and I have put all the miles on it along with all lube changes and repairs. I use all wix filters in this truck and am very satisfied with it's performance. This engine has no chips in it and never will. It may haul a load twice a year.
With that said, I am never label loyal to anything. I do allot of research aka reading allot. I figure out what bang I can get for my buck, and quality. I will pay more for quality, if I see the payback.
*Can I get more miles from the VPB between oil changes that Im currently doing? I know when I pull this oil it is blacker than black. I also change the oil filter with every change and the fuel filter every three oil changes.
P.S Thanks dnewton3 for the link ( good read)
Again thanks to everyone that replied.
Edited by Cudadude (01/02/14 02:41 PM)
#3243201 - 01/09/14 06:34 PM Re: Valvoline -Premium Blue [Re: Cudadude]
Suzuki Phil Offline
Loc: California
I run 15W-40 of whatever major brand is on sale, OCI's are at 7500 miles on my 07 Duramax. I tow a 8K TH loaded all over the country no issues.
#3243488 - 01/10/14 04:49 AM Re: Valvoline -Premium Blue [Re: Cudadude]
dnewton3 Offline
*Can I get more miles from the VPB between oil changes that I’m currently doing? I know when I pull this oil it is blacker than black. I also change the oil filter with every change and the fuel filter every three oil changes.
Sounds like the maintenance has been well done; no reason to think your right won't last as long as you intend to keep it and then some. Wix is a good brand, but they are not the only filter worthy of consideration. Any good brand name will suffice. The topic of filters is not unlike that of lubes; brand loyality will sway opinions, but facts and data tell us that it does not matter overall. Keeping it stock helps as well. Highly perf-modded engines can suffer other effects that alter wear at times. (I am speaking of chips, tuners, compounds, etc that pump up the power heavily for competition or extreme peformance criteria).
As for the OCI for the VPB, only a few UOAs will give you that answer. I highly suspect that you could safely extend your OCI, given that you keep the vehicle in good condition. But guessing and knowing are two totally different things. Get a few UOAs and get a real answer. Post them up when you get them and we'll help decipher. Odds are that you could extend for sure.
Edited by dnewton3 (01/10/14 04:51 AM)
