Post your latest oil change
1997 Dodge Dakota 5.2L 98K
Valvoline Max Life 10W-30 out/in
Mopar filter
I will be switching to Pennzoil next time with a Wix filter
2003 Chevy Trailblazer 4.2 I6
Out: SuperTech Synthetic 5w30 M1-206
In: Gulfpride Advanced Fuel Efficient Semi-Synthetic 5w30 ProGuage PGO-5288
4.5 quarts of M1 AFE 0w30 and Wix filter for the Wrangler. Extreme short tripper (1000 miles in 6 mos, driven almost daily) so plan on a UOA in the spring after 6 months.
2014 Ford Explorer Limited 3.5L
1,905 miles on engine
1,905 miles on oil/filter
Out:
Factory fill (Assumed to be MC 5W-20)
OEM MotorCraft Filter
In:
MS5K 5W-20 SN
MC FL-500s
2001 Honda civic hx, 154550 , wix filter, german Castrol, 0w30 syn, October 25th
will change around late april or may 1, going with carquest basic filter and a cheaper syn.
Since my back is a bit tweaked out, and instead of waiting maybe a couple weeks or so...
Wife's 01 Escape - for the 1st time took it in for a oil/filter change and tried the recent open Firestone nearby.
Kendall blend and their stock filters, and they gave a discount making it $25 and some change. Tempting at such a price.
I know I won't take my DD there because of a TSB on the filter and they won't use my brought in filter although I bought them at the Hyundai dealer.
oil changed on 30th November 2013
Car : 1991 Proton Saga, mileage on overhauled engine 118,000km
Out - Mobil 1 5W-50 ,filter bosch, 9500km
In - Castrol Edge titanium 0W-40, filter Eneos.
UOA will be done on this Edge on next OCI.
2004 dodge ram 1500 hemi 191K. Changing out RP 10w30 at 11,500 miles of use K&N 3001 filter.
Filling with Mobil 1 5w30 EP and Mobil EP filter.
05 Chevy Express 3500 6.0L 28,900 miles
Out: Something from Mobil 1 Express Lube PF46E filter
In: 5qt PU 5w30/1 qt QSUD PF61E filter.. may need to add a little more.
Pressure gauge sure does move alot more now! The oil filter gasket came off also 2nd time had that in almost 20 years.
So I missed putting the last change on my LX in here.
3/08/13
2004 Ford Crown Vic LX, 68.5kmi
5qts Pennzoil Ultra 5W20 (SM)
0.5qt Shell Rotella T6 5W40
Old (2008) Amsoil EAO11 (reused for 2nd time)
12/28/13
2004 Ford Crown Vic LX, 75kmi
5qts Pennzoil Ultra 5W20 (SN)
Old (2008) Amsoil EAO11 (yup, using it a third and final time)
Out: an eclectic mix containing liqui-moly 0w-40,a quart of pp 0w-20 and a couple quarts of devlac elite 222 0w-30 that I put in after pumping a few quarts out.
Filter was a pure 1 left on for 12000 miles.
In: pennzoil ultra 5w-20 and a quart of devlac elite 222 0w-30 and a fram ultra filter. Filter will go the 25000 miles since I know this engine is spotless.
Hi Clevy good luck on the 25000 on the Fram Ultra filter and your special blend of choice.Let us know how you made out on your charger when you do the next oil change..best of luck bro
