any harm done to Ranger?
by mobilaltima
23 minutes 0 seconds ago
Obsolete Freeway on ramps
by jimbrewer
26 minutes 3 seconds ago
Ideal-Tridon Hose Clamp Display
by Merkava_4
Today at 08:52 PM
Want to hear from turbo owners that go 10k + oci
by Sw296inchblue
Today at 08:31 PM
When you have found the right combo
by bbhero
Today at 08:25 PM
High Mileage diesel oil?
by Hysilver
Today at 08:23 PM
Barium
by Hullthumper
Today at 07:25 PM
Oil filters suggestions for a 10' Hyundai .......
by Oregoonian
Today at 06:32 PM
Is the spin-on filter's days numbered?
by jongies3
Today at 06:28 PM
Mobil 1 75w90 LS for 2010 Camaro SS
by AIRJAC3
Today at 05:51 PM
2013 Tacoma ATF Change?
by CrackyWainwright
Today at 05:42 PM
Blackfire Wet Diamond
by BlueOvalFitter
Today at 05:42 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
70 registered (6lbsoft, AIRJAC3, 2015_PSD, ABomb369, ag_ghost, 7 invisible), 1341 Guests and 344 Spiders online.
58031 Members
66 Forums
249647 Topics
Page 1 of 2 1 2 >
#3229698 - 12/28/13 04:30 AM "break in" oil for turbo subaru
91camarosRS Offline
Loc: oklahoma
I'll be getting a used motor soon for my Subaru. It will most likely have around 50k miles. But has been sitting for who knows how long. My plan was to run xxxxx oil for xxxx miles then switch to rotella t6 for 5 k and get oil analysis.
Question, what steps should I take for new motor? Old trick of spraying marvel into cylinders before starting? Do I use a cheap supertec oil first? How long should I run it? Thank you
2012 Hyundai veloster 6speed 115k and climbing
2002 Subaru wrx wagon auto 220k
1988 Camaro waiting for powertrain...
#3229699 - 12/28/13 04:39 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
91camarosRS Offline
Loc: oklahoma
Side question... I'm also getting an oil temp/pressure gauge. I got temp so I make sure car is truly warm before any halfway spirited driving. What temp should be the low? 100? What should my pressure be?and my normal temp?
#3229714 - 12/28/13 05:58 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
SteveSRT8 Offline
Loc: Sunny Florida
Since it's used there is no break in required. While it's out of the car you should at least consider a look around to be sure it is a good candidate, otherwise it's a bit of a gamble.
As to break in, I believe in no lower gears but LOTS of full throttle in the higher gears for best ring seal. Oil temps once over 120 degrees or so are fine unless you run heavy oils for some strange reason.
Once you get some pressure versus temps data we can tell you more. There's a lot of Scooby folks here...
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3229732 - 12/28/13 06:26 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
91camarosRS Offline
Loc: oklahoma
I'm looking and have been looking for awhile.
A little nervous on spending all this money!
So no cleaner oil? Something to get anything out to freshen it up?
I'll be running t6 like I.said its 5w-40
Highly recommended for subies.
I have an auto...... Can't do the only high gear thing..
#3229737 - 12/28/13 06:32 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
Kuato Offline
Loc: In transit...
I would simply change to the T6 right after you buy it, and maybe have a shorter interval the first time. Good oil is good oil.
As far as hard acceleration in a higher gear...well...that's speed related so get up to highway speed, and accelerate hard, expecting a single downshift.
Your oil's condition is pure speculation until you get a UOA.
13 F150 5.0, 48k mi
04 Wrangler 2.4, 197k mi
Schaeffer convert...
#3229770 - 12/28/13 07:28 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
Cujet Offline
Loc: Jupiter, Florida
T6 is a perfect choice. If you are really worried, change it out a bit early and continue using T6. No need to worry about break in. And T6 will maintain a clean engine.
You will get another 200,000 miles as long as the head gasket and other issues don't cause problems.
Edited by Cujet (12/28/13 07:29 AM)
Turbo's rule.
#3229792 - 12/28/13 07:46 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
91camarosRS Offline
Loc: oklahoma
That's why I'm replacing..... Head gasket. And I can't keep things stock......
#3229818 - 12/28/13 08:14 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
toneydoc Offline
Loc: War Eagle
Do you really have 110k miles on the 2012 Hyundai already?
1994 Jeep 146k Castrol 0w40
2014 Camry 14k TGMO 0w20
2010 Sebring 39k Valvoline 5w30
2014 HD Ultra 18k Valv20w50
2012 Toyota Rav4 22k Mobil 1 0w30AFE
#3229833 - 12/28/13 08:25 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
91camarosRS Offline
Loc: oklahoma
Yes.....
Wife is a phlebotomist and drives 200+miles a day to collect samples from nursing homes
Oil changes have been neglected(wifes car) getting one in the next hour. I will ne on top of that! Plan on getting oil analysis done on it with the new change. We are in for long haul(my car too... She put the miles on my subie) I want/need a oil that that car needs. Ran Quaker for the first 40k or so then dealer switched to Mobil. We get free changes
#3229902 - 12/28/13 10:02 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
whip Offline
Loc: ohio
If the engine has 50,000 miles, it's already "broke in". Run the oil you want to normally run.
On the internet, people can be anything they want. Why do so many choose to be stupid?
#3229912 - 12/28/13 10:22 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
91camarosRS Offline
Loc: oklahoma
I was concerned about time it sat.
Not typical "break in" just bringing back to life
#3230454 - 12/28/13 10:53 PM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
Kuato Offline
Loc: In transit...
Yes.....
If those are highway miles, it's a good candidate for extended drain...
13 F150 5.0, 48k mi
#3230480 - 12/28/13 11:16 PM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
Clevy Offline
Loc: Saskatoon canada
A single used oil analysis is pointless. They are used to establish trends which can then be analyzed for any anomalies so save your money unless you plan on doing them consistently.
As far as the first start some mmo into the cylinders via the plug holes wouldn't hurt. Once it's started I'd do an mmo intake cleaning via a vacuum hose just to insure the top end isn't dried out or dirty.
None of this is required it's merely a suggestion.
2006 Charger RT
Miles x 2 per oil filter
#3230541 - 12/29/13 02:44 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
91camarosRS Offline
Loc: oklahoma
I was thinking,for both cars, to get a baseline. See if anything looks abnormal.
Put oil that "should" normalize. Then check again.
Or in my Hyundai, see how long I can go between changes. Or should I get a better oil etc
#3230606 - 12/29/13 07:42 AM Re: "break in" oil for turbo subaru [Re: 91camarosRS]
toneydoc Offline
Loc: War Eagle
I would use Mobil 1 extended performance in the wifes car and use it for 12000 miles or so which in her case will be 4 months or so. And rest assured that that car is ok.
Page 1 of 2 1 2 >
