Huffy
by Shellman
8 minutes 29 seconds ago
2012 VW Tiguan; Castrol 0W-40; 54,500 // 4,800 OCI
by motech
27 minutes 58 seconds ago
2004 Chevy Aveo- Auto 1.6L
by AirgunSavant
Today at 08:51 AM
Filter cover?
by Shellman
Today at 08:19 AM
Anyone remember the show "The Moment of Truth"?
by skyactiv
Today at 08:16 AM
2010 Tahoe Z71 Oil, etc.
by SteveP
Today at 07:59 AM
Purolator One and Puro Boss 14006 "Not Cut Open"
by bandz7
Today at 07:04 AM
Nikola Semi
by AirgunSavant
Today at 06:57 AM
Oil Pressure with M1HM 10w30
by lukejo
Today at 05:56 AM
Clay Based HTB Grease
by SR5
Today at 04:33 AM
Which M1 oils are true synthetics
by FordCapriDriver
Today at 04:06 AM
That's unfortunate...or maybe bypass filtration?
by linksep
Today at 02:24 AM
karpouzi, Tapan, shindery, Josh_Westwood, Brogan
58283 Registered Users
78 registered (2010Civic, AirgunSavant, A_Harman, ABerns, ag_ghost, 2015_PSD, 5 invisible), 1784 Guests and 13 Spiders online.
58283 Members
66 Forums
250868 Topics
Page 1 of 2 1 2 >
#3228786 - 12/26/13 11:17 PM royal purple gear oil hard to shift when cold
macy1188 Offline
Loc: seattle, wa
Hi guys
so I have a 2012 Mazda speed three. Just replaced the transmission fluid with the 75w-90 two days ago.
for about 5 minutes when the engine is cold it is difficult to shift, it does not grind unless forced but it can be a pain to get into 2nd.
from what I have read it seems to be because the oil is heavier then the oem oil and needs to warm up in cold weather like the red line mt90.
Is this normal for these types of gear oils? supposedly it is for the redline
Does anyone else have to deal with this with RP, or respond? Is your tranny still ok
#3228797 - 12/26/13 11:38 PM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
GutsyGecko Offline
Loc: Youngstown, OH
Almost all transmission that spec a gear oil fill be a bit stiff in the cold. I haven't had the problem in years due to using ATF in my last 3 manual trans. The problem should become a little les noticeable as the oil shears some.
#3228799 - 12/26/13 11:47 PM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
Chris142 Offline
Loc: apple valley, ca
What oil does the trans call for?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3228801 - 12/26/13 11:55 PM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
macy1188 Offline
Loc: seattle, wa
The transmission calls for gl4 75w-90 and the RP IS gl-4or 5 compatible.
thanks for the reply gutsygecko
#3228803 - 12/26/13 11:59 PM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
Rand Offline
Loc: NE,Ohio
the car calls for a lightweight 75w80 GL-4
if you put in RP 75w90 GL-5 that is your problem.
the extra additives in gl-5 will usually negatively affect syncho operation.
in addition to it being much thicker.
owners manual page 489 (section 10-4)
For the best shift feel I'd recommend Gl-4 only and the proper viscosity
such as
http://www.redlineoil.com/product.aspx?product=50204
Redline 75w80 GL-4 Transmission oil.
2015 Forester I-Premium 6MT
#3228812 - 12/27/13 12:17 AM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
macy1188 Offline
Loc: seattle, wa
Thank you rand
I just went by what some in the Mazda forums have said. I will be switching it out first thing.
#3228827 - 12/27/13 12:49 AM Re: royal purple gear oil hard to shift when cold [Re: GutsyGecko]
dparm Offline
Loc: Chicago, IL
Yep. A higher viscosity index fluid may help a tiny bit, but manual transmissions are always a bit clunky and sloppy when cold.
2011 BMW M3 sedan ZCP
#3228840 - 12/27/13 01:22 AM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
macy1188 Offline
Loc: seattle, wa
Probably a good idea to stay away from the Gl4-5 combo stuff? Now do people run the 75w-90 do to better performance when hot then and just deal with the scrappy shifting when the engine is cold? Doesn't make sense to me seems like the 75w-80 would be best all around unless your going to the track or something.
#3228845 - 12/27/13 01:44 AM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
Olas Offline
Loc: Manchester, England
If Mazda call for a 75w90, stick with that grade. They spent millions in R&D and they know what fluid their gearbox needs!
IMO, the very best 75w90 on the market that meets GL4 is this stuff here (two links included depending on wether you have an open diff or a LSD)
http://www.opieoils.co.uk/p-60230-miller...ission-oil.aspx
(above link is the open diff version)
or
http://www.opieoils.co.uk/p-60232-miller...ission-oil.aspx
(this link is the same stuff but for use with LSD)
I use it, it's silky smooth hot or cold! I've used a lot of different gear oils in 75w90 and nothing has ever come close to the Night-and-Day difference in smoothness when cold AND hot that I've experienced with this stuff.
Millers have a customer for life smile
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3228851 - 12/27/13 02:06 AM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
Olas Offline
oops! i re-read and saw that they need a 75w80, in which case MTL is the daddy!
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3228860 - 12/27/13 03:10 AM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
michaelluscher Offline
Loc: Tri States Little Italy
How about GM FM'ed Syncromesh fluid?
The general consensus seem's to be MTX +GM FM Syncro fluid = thumbsup
Put that [censored] in everything
Shop local GM dealers for pricing though...
Amazon
'06 Toyota Camry SE V6 3MZ-FE 51k
'01 Mercury Villager Estate VG33E 48k
'06 Ford Taurus SE Vulcan 48k
'13 Chrysler 300 3.6 Pentastar 45k
2012-2015
#3228930 - 12/27/13 06:55 AM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
Cujet Offline
Loc: Jupiter, Florida
I use Redline http://www.redlineoil.com/product.aspx?pid=45&pcid=7 fluid in my Jag X-Type. It's the proper spec fluid and works quite well. It's also a good choice for your Mazda.
In fact, my trans has been 100% trouble free, something that other jag X-Type owners cannot say (those that don't change fluids regularly)
It shifts better than the other fluids I've tried. Hot or cold.
Check this out:
http://www.bobistheoilguy.com/forums/ubbthreads.php/topics/3228789/Gear_Oil_study While it does not directly apply, it does show the oil you used as being extremely out of grade when cold.
Edited by Cujet (12/27/13 07:04 AM)
Turbo's rule.
#3229158 - 12/27/13 01:21 PM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
camelCase Offline
Loc: Southeastern, USA
Fellow MS3 owner here - 2008 with over 120,000 miles.
Royal purple fluid is garbage.
Go with Redline if you can. Otherwise pick up some syncromesh. The manual in the MS3 can run ATF fluid all day with no problems.
#3229166 - 12/27/13 01:38 PM Re: royal purple gear oil hard to shift when cold [Re: camelCase]
Rand Offline
Loc: NE,Ohio
The redline recommendation is not their d4 or d6 atf, but their GL-4 MTL 75w80.
#3229223 - 12/27/13 02:59 PM Re: royal purple gear oil hard to shift when cold [Re: macy1188]
dparm Offline
Loc: Chicago, IL
There is no reason to avoid a dual-rated GL-4/GL-5 fluid. There are many good ones such as Motul Gear 300.
Page 1 of 2 1 2 >
