Trailer wiring connector.
by wolfehunter
06/29/16 07:10 AM
Oil for High Performance Turbo Application
by T_Bortz
06/29/16 06:52 AM
Walmart.com Valvoline WB 6x1Quart 10W-30 $7.22
by Farmer
06/29/16 06:41 AM
Dyade, Eurol, Ravenol Lubricants
by RaM30
06/29/16 04:46 AM
'88 Caddy Brougham - dark oil + lifters noise
by momo
06/29/16 02:57 AM
Which Oil for Duramax?
by Jamn
06/29/16 02:11 AM
Oil for Binding Foundry Sand
by smw
06/29/16 01:38 AM
Found a good high zinc breakin oil
by 1977c10phxdriver
06/29/16 01:12 AM
What is this radio modulating sound?
by Pontual
06/29/16 01:00 AM
The reason brake fluid can be Dot 3&4 - Viscosity!
by CharlieBauer
06/29/16 12:56 AM
No injector pulse, '92 Prelude, F20B, GSR ECM
by redhat
06/29/16 12:02 AM
Finding #1 Cylinder
by motorguy222
06/28/16 11:31 PM
dpaldino, T_Bortz, rebelx, dougsangster, CrazyCalvinW
58314 Registered Users
73 registered (97K15004WD, Bear, Asterix, barkingspider, AandPDan, 97f150, 5 invisible), 1501 Guests and 9 Spiders online.
58314 Members
66 Forums
250970 Topics
Page 4 of 4 < 1 2 3 4
#2558433 - 03/05/12 10:17 PM Re: P0420 Code... CAT or O2 sensors? [Re: Vikas]
TFB1 Offline
Loc: VA
Here's how to fix that P0420...
#2558481 - 03/06/12 12:01 AM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
MysticGold04 Offline
Loc: CA
ok.. so I found the last smog check.. done on 7/20/10 so it will most likely have to be tested again in July as CA does biannual inspections.
Here were the readings - keep in mind they put cars on the dyno.
15MPH Test: [email protected] HC PPM:37 (MAX:50) C0: 0.27 (MAX 0.64) NO PPM:444 (MAX:508) PASS
25MPH Test: [email protected] HC PPM:9 (MAX:34) C0:0.00 (MAX 0.78) NO PPM:22 (MAX:761) PASS
does it seem like the converter either wasn't fully warmed up... or does it seem to need replacement? Or can you even tell from these results?
I priced sensors today.. about $220 for both upstream and downstream Denso (OEM style sensors)
drive
'02 Saturn SC2 94,348 Maxlife 5w30
'04 Highlander 2AZ 178,842 Mobil 1 HM 5w30
'06 Focus 5MT 2.0 108,205 Maxlife 5w30
#2558586 - 03/06/12 06:41 AM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
Trav Offline
Loc: MA, Mittelfranken.de
Its hard to tell from these reading if there is any problem.
IMHO keep this as simple as possible. O2 sensors do get slow, in fact for many years some companies recommended 30K change intervals.
Today they can go much longer but personally over 100K i change them if i suspect a problem.
Whenever you change a cat its a good idea to swap them out anyway especially if they are in the 100k range, so swapping the O2's first makes sense.
If that doesn't cure the problem then you can change the cat. +1 on the Denso O2's, they are quality units.
#2559034 - 03/06/12 01:55 PM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
Loc: CA
Thanks Trav..
I think I will run a bottle of techron, go burn some mileage on the highway, and get the O2 sensors on order, and go from there.
James: I just replaced the spark plugs with OEM Iridiums at 100k and also cleaned the TB at that time.
drive
#2560753 - 03/08/12 02:07 AM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
ltslimjim Offline
Loc: WatUpDoc
^As a note, the longer a PEA containing fuel system cleaner can remain in the gas tank the better. It isn't a stripping solvent but a detergent that is best used on a full tank that you will use over a longer during of time.
92 Civic Hatch (stolen frown RIP)
07 Honda Fit Sport (A/T) WELCOME thumbsup
#2566212 - 03/13/12 11:40 AM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
Loc: CA
Update:
I took the car out for a nice drive this past weekend with lots of high RPM miles to heat things up. Then as luck would have it, got a flat tire (sidewall) and interrupted my work. Anyhow, I replaced both O2 sensors, and reset the ECU. I also cleaned the MAF and cleared the codes. We will see what happens. I *did* notice the exhaust had a different smell when letting the car idle. Before the sensor changes, the exhaust smelled in excess of fuel. Now, not so much, so hopefully things are better! If not, I suppose a cat replacement is in order!
drive
#2566226 - 03/13/12 11:59 AM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
Loc: CA
Sidebar on the Flat: I jacked the car up and put the spare on.. and continued working on the planned o2 sensor changes on Sunday. Yesterday I took the car and tire to Americas Tire since I bought the tires (and replacement certs) from them. They ended up replacing the tire for free, so I just had to pay the CA environmental tax, and a new certificate. I also opted to purchase a second new tire to have a "matched" set of tread since the other tires are at about 4-5 32nds of tread left. I hope I'm done spending money on this car for awhile, but it is the wife's car... It is comfortable, safe and is relatively inexpensive to drive - less than a new car payment every month, and safe for her and the kids to run around in.
drive
#3228625 - 12/26/13 07:40 PM Re: P0420 Code... CAT or O2 sensors? [Re: MysticGold04]
mitmaks Offline
Loc: WA
I was wondering if replacing o2 sensors fixed your issue?
