Paint Brushes - Home Improvement
by Merkava_4
Yesterday at 11:46 PM
How do you determine the proper HTHS rated oil?
by 79sunrunner
Yesterday at 11:29 PM
Saved a puppy
by barkingspider
Yesterday at 10:39 PM
Slick 50
by CrackyWainwright
Yesterday at 09:28 PM
Bmw twin power 5w30
by BTLew81
Yesterday at 09:08 PM
Older car but low mileage. Change or not?
by Martin10
Yesterday at 08:07 PM
F1 - 2016 Belgian Grand Prix
by gofast182
Yesterday at 07:55 PM
Ethernet card uograde needed?
by NHHEMI
Yesterday at 07:27 PM
2012 Suzuki DL1000 VStrom Oil Recommendations
by RHALL
Yesterday at 07:24 PM
Audio/Micro Adapter Help
by coopns
Yesterday at 07:18 PM
Purolator boss 2222 6,200 miles
by gabriel9766
Yesterday at 06:49 PM
Fram Ultra paint peeling
by Run
Yesterday at 06:26 PM
ShadowSix, warfire, Brutus232, gojoneeded, jimmyangst
58911 Registered Users
36 registered (bbhero, 3800Series, 67baccaruda, Arob, Andy636, Benoit, 2 invisible), 913 Guests and 7 Spiders online.
58911 Members
66 Forums
253517 Topics
#3228556 - 12/26/13 06:25 PM O2 bolt removal
chartrue2 Offline
Loc: marlton, new jersey, usa
Hi all--suggestions needed as to how to remove the rusted nuts off the studs that hold the O2 sensor on my '92 Toyota truck. Have tried soaking in PB Blaster and Liquid Wrench but the very rusted condition has prevented my removing them so far. What do you suggest?
#3228569 - 12/26/13 06:43 PM Re: O2 bolt removal [Re: chartrue2]
Burny Offline
Loc: Chesapeake
get a dremmel with a grinder wheel and try to notch a groove in the top for a flat head screwdriver. I had this issue on my 91 4runner and ended up doing that.
#3228578 - 12/26/13 06:50 PM Re: O2 bolt removal [Re: chartrue2]
Chris142 Offline
Loc: apple valley, ca
Heat
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3228609 - 12/26/13 07:21 PM Re: O2 bolt removal [Re: chartrue2]
yonyon Offline
Loc: NJ, USA
Is this one of those Toyota O2 sensors with the two little nuts?
Usually by the time those nuts need to be removed they're a lot smaller and rounder than they used to be. Find a socket that's too small to fit and try to hammer it on. If you get the socket on, take it back off and try to hammer on a smaller socket. Use a socket that won't go on so you can hammer at it until the rust starts to break up a little. Once you've done that you should be able to use a fluted bolt removal socket (socket that fits round-head bolts) to take it right off.
If the nuts are just too small to do that use a tiny straight screwdriver to peel the nuts off the studs.
