Foam gun?
by demarpaint
02/13/16 06:47 AM
How do you wash your tomatoes ?
by Merkava_4
02/13/16 05:26 AM
Ground effect
by mjoekingz28
02/13/16 04:36 AM
20w50 thick? i present to you Penrite's 50w70!
by FordCapriDriver
02/13/16 03:46 AM
08 caravan / oil seeping from spark plug
by Mark72
02/12/16 11:25 PM
Holley Accelerator pump probem
by nwjones18
02/12/16 10:56 PM
Sealant for threaded air hose fittings.
by BigD1
02/12/16 10:37 PM
on line data search programs - which is best?
by bmwjohn
02/12/16 10:11 PM
What size air compressor is needed
by ram_man
02/12/16 09:45 PM
DHS wants to force car owners to use OEM parts
by faltic
02/12/16 08:54 PM
Castrol Edge 5w30 no longer A5/B5
by slacktide_bitog
02/12/16 08:20 PM
Best Oil Analysis?
by countryboy9799
02/12/16 07:28 PM
wdleighton1, RTS, jhmed80, engus, Rob_Pol
56902 Registered Users
52 registered (BigCahuna, AlienBug, 2002 Maxima SE, Al, BlueOvalFitter, 04SE, 4 invisible), 803 Guests and 109 Spiders online.
56902 Members
66 Forums
244629 Topics
#3228583 - 12/26/13 06:54 PM '03 Dodge Ram HVAC issue
Colt45ws Offline
Loc: Central Washington
My sister has a 2003 Dodge Ram 1500. It has no heat coming out of the driver side vents. It has great airflow but its ambient temperature. On the passenger side the vents have heat coming out just perfectly. Im scratching my head trying to figure out what would cause that. Any ideas?
-Colton
2002 Ford Crown Vic PI, 174k "Highwayman" (Ex-Kootenai County, ID Unit #42)
#3228593 - 12/26/13 07:01 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Chris142 Offline
Loc: apple valley, ca
Blend door problem?
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3228606 - 12/26/13 07:20 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Colt45ws Offline
Yeah, it looks like the dash has to come out so the HVAC box can come out. Probably a broken blend door from what Ive found. [censored].
-Colton
#3228633 - 12/26/13 07:57 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
yonyon Offline
Loc: NJ, USA
If she can live with it until a warm day comes along it's really not that bad. It's about as easy as dashboards get. Take your time, note where everything goes, and you're looking at maybe 2 hours to yank the dash, 1 1/2 to put it in and if you vaccuum the carpet first you don't even have to get dirty.
#3228649 - 12/26/13 08:13 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Chris142 Offline
You may have to buy the whole box. Often they dont offer just the doors
87 F250 delo 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3228669 - 12/26/13 08:41 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Jimmy9190 Offline
Loc: Clermont, Florida
It might be a bad blend door actuator. If it is anything like a Dakota it will have 2 actuators on the outside of the hvac box and 2 on the inside of the hvac box. There may be a broken actuator on the outside of the box above the gas pedal. It's worth a look before pulling the dash.
Jimmy9190
2001 Dodge Dakota, 3.9 V6, 5-speed manual, 185K
Valvoline 10W30, Proselect 21085
#3228832 - 12/27/13 12:57 AM Re: '03 Dodge Ram HVAC issue [Re: yonyon]
Colt45ws Offline
Yeah, shes out of town for a week, and Im only here (Im at my Dad's place in Las Vegas) through Sunday so Im trying to do as much as I can. I already did spark plugs (the old ones were wider than I could measure with a gapper!) and the downstream O2 sensor that was setting a P0037. O'Rilleys is supposed to get me the door Saturday morning, so I will probably do the tear down tomorrow (Friday) so its ready to go in as soon as I get it.
They do. I have a Dorman replacement on order. Must be pretty common problem if they are making them.
I can see/hear the actuator moving so its fine, I guess they just break.
-Colton
#3229239 - 12/27/13 03:32 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Titan104 Offline
Loc: Tennessee
Heatertreater.net offers blend door replacements and instructions.
#3230183 - 12/28/13 05:40 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Colt45ws Offline
So the blend door isnt the problem. I got the HVAC box cut open and everything is in one piece. I have no idea; it makes no sense. I threw in the towel. She'll just have to live with closing the driver vents when she wants heat.
-Colton
#3231222 - 12/29/13 06:12 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
yonyon Offline
Loc: NJ, USA
Ouch! That was kind of a lot of work to come up with nothing.
#3231484 - 12/29/13 10:19 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Colt45ws Offline
Little bit, yeah.
-Colton
#3234734 - 01/02/14 01:22 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
951Indy Offline
Loc: Indy
Did you pull the actuator off the shaft to verify the shaft was moving the door (internally)?
#3234842 - 01/02/14 03:34 PM Re: '03 Dodge Ram HVAC issue [Re: Colt45ws]
Colt45ws Offline
Yup. Both doors are moving.
-Colton
