Smoked some baby backs today
by BeerCan
52 minutes 39 seconds ago
Ford FWD axle replacement
by 2009Edge
54 minutes 6 seconds ago
Saturn ac compressor
by spasm3
Today at 10:20 PM
looking for spray guns - analysis paralysis
by tomcat27
Today at 10:18 PM
WIX 51372 ADBV Failure
by WellOiled
Today at 10:11 PM
moly + engine coatings
by benjy
Today at 09:57 PM
Worth the upgrade?
by daves87rs
Today at 09:47 PM
Mr. Funnel does in fact work!
by TurboFiat124
Today at 09:46 PM
Will ATP205 help with a head oil leak
by NattyBoh
Today at 09:11 PM
Why is 100% gas more expensive in the city?
by TurboFiat124
Today at 09:06 PM
Trouble getting a copper pipe sweat fitting sealed
by NateDN10
Today at 08:58 PM
Murphy oil
by TurboFiat124
Today at 08:53 PM
NJ1911, SneakyTacos, DaveD, 8o8is, Texasdude74
58584 Registered Users
59 registered (AZjeff, abycat, ag_ghost, barkingspider, benjy, Blkstanger, 8 invisible), 1381 Guests and 8 Spiders online.
58584 Members
66 Forums
252216 Topics
#3228506 - 12/26/13 05:26 PM Cummins 6BT Thermostat Question
madibob Offline
Loc: Minnesota
I know there are more dedicated websites for this question, but there are a lot of smart folks here. I have the '96 Dodge with the 6BT. I found this fall that when I blocked off part of the radiator, the truck ran warmer and my MPG jumped. My guess is around 2 MPG (I haven't checked it real close yet).
Here's my question - The stock thermostat is 180*F. Cummins never made a hotter thermostat that I could find. From other forums, there is a thermostat for a gas engine that is 195*F that fits. Some of the WVO folks seem to be using these. What are the risks of going to this hotter temperature on this engine? I don't pull much and if I do it isn't very heavy.
Please post if you have any knowledge or experience....not looking for opinions.
Oh, and I should mention the newer 6.7L engines do have a 190*F option.
Edited by madibob (12/26/13 05:28 PM)
2002 Toyota Tacoma 3.4L 4X4
2000 Ford F350 7.3L
#3228515 - 12/26/13 05:35 PM Re: Cummins 6BT Thermostat Question [Re: madibob]
Chris142 Offline
Loc: apple valley, ca
Are you sure that it dont have a 195 stat? The one for the gasser is a big block dodge but it wont have the correct bypass restriction
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3228520 - 12/26/13 05:40 PM Re: Cummins 6BT Thermostat Question [Re: Chris142]
madibob Offline
Loc: Minnesota
I read to drill 2 holes in the one for the big block dodge for this. That was my understanding.
BTW - There's also a 200*F thermostat for the 6.7s
2000 Ford F350 7.3L
#3228555 - 12/26/13 06:23 PM Re: Cummins 6BT Thermostat Question [Re: madibob]
Ramblejam Offline
Loc: Kentucky
Gates Part # 33039S -- $4.93 on RockAuto.
Works great for your intended purpose. Just make sure to remove it when warmer temps return.
#3228562 - 12/26/13 06:34 PM Re: Cummins 6BT Thermostat Question [Re: madibob]
Boczech Offline
Loc: Norcal
Looks like the newer 6.7 engines starting in 2010 call for the 200*F thermostat. http://www.genosgarage.com/Cooling-System/products/219/ I have read some of the 2nd generation 24v folks on another forum trying the 200*F thermostat's in their truck with a slight gain in fuel mileage.
Cheers
B
1996 Dodge RAM 2500 5.9l diesel
#3228616 - 12/26/13 07:27 PM Re: Cummins 6BT Thermostat Question [Re: madibob]
bullwinkle Offline
Loc: Cincinnati, OH, USA
Remember that with an INTERCOOLED turbo diesel, you are introducing cooled intake air into the engine at all times-that's why a winter front on the grill is used in winter. Not sure the thermostat will make a big difference unless you are towing or hauling heavy loads-a lot of people just put something between the intercooler & radiator with a fan clutch sized hole in the middle to restrict airflow.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
