Premium Guard Filters
by CapitalTruck
04/30/16 01:54 PM
Wheel centering ring
by Donald
04/30/16 01:22 PM
tight pocket knife
by spasm3
04/30/16 01:04 PM
Any Jack Russell owners?
by chrisri
04/30/16 12:10 PM
Tire ply description as listed on sidewall
by Cressida
04/30/16 11:43 AM
spec that measures ability of oil to cool an engin
by paulri
04/30/16 11:41 AM
Best USA Produced Olive Oil
by hatt
04/30/16 11:29 AM
How often do you run malware bytes?
by Doog
04/30/16 11:03 AM
F250 Rear Diff Fill Plug Seized
by Mantooth
04/30/16 10:48 AM
What oil should I use for 2000 cavalier that burns
by SeasonalEclipse
04/30/16 10:47 AM
Why is HDEO better for OPE, than regular oil?
by NH73
04/30/16 09:53 AM
CASTROL EDGE 5W-40 FST no ACEA A3/B4 ?
by alcyon
04/30/16 09:53 AM
paydase, Scopx, speedysmitty, hdwizard21, raihan
57751 Registered Users
77 registered (bdcardinal, Astro14, AirgunSavant, Atesz792, Bill_G, 5 invisible), 2056 Guests and 327 Spiders online.
57751 Members
66 Forums
248252 Topics
#3228500 - 12/26/13 05:15 PM Installing Aftermarket Stereo 2001 Ford Taurus SES
actionstan Offline
Loc: Ohio
Hello All,
My brother is attempting to install a aftermarket radio into a Ford Taurus SES 2001. Instructions he has read, and also what I am seeing is.. people are running cables to a amp in the trunk to the front of the vehicle.. why in the world is it set up like this? Couldn't you just get wiring harnesses that terminate at the front of the vehicle?(in past installs Ive had wiring harnesses that would just connect into the OEM plugs, that I would solder to the aftermarket stereo)
Or is running this long cable necessary? Does anyone have any experience with installing a aftermarket radio into a Ford Taurus ?
Any help is welcome thanks!
1999 Saturn SL1
2013 KIA Forte
#3228514 - 12/26/13 05:34 PM Re: Installing Aftermarket Stereo 2001 Ford Taurus SES [Re: actionstan]
Jimmy9190 Offline
Loc: Clermont, Florida
You have to run wires and an antenna extension cable to the trunk because that is where the "brain" of the factory radio is located. It's mounted in the left rear side of the trunk behind the trunk liner material. Here is a link to a few pics:
http://www.crutchfield.com/App/Car/outfitmycar/car.aspx
The factory radio is only a control head that supplies input signal and radio/source function switching to the radio brain. The speaker outputs and power wires all have to be routed from the brain up to the dash location to wire in to a new aftermarket deck. It also takes a specialized installation kit for the new deck in the dash, usually you can get the dash kit, antenna extension and a speaker/power wire kit for about $80.00 or $90.00. I would say call Crutchfield, Sonic Electrinix or maybe a good independent car audio shop to be sure you get the right parts and help with the installation.
Jimmy9190
2013 Honda Civic LX Sedan
Napa Synthetic 0W20, Napa Gold 7356
