MC FL-820S, 7.6K miles, 2012 F-250
by car51
07/24/16 04:41 PM
Scion tC Radiator Fan troubleshooting
by sky
07/24/16 03:59 PM
Does Americastire sell tires from the DTD list?
by zorobabel
07/24/16 03:54 PM
My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
91 registered (A1O, AIRJAC3, 2165, Anduril, alanwayne1908, 4WD, 7 invisible), 1998 Guests and 13 Spiders online.
58578 Members
66 Forums
252196 Topics
Page 2 of 6 < 1 2 3 4 5 6 >
#3228554 - 12/26/13 06:20 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
Roadkingnc Offline
Loc: NC USA
Go to a local ford dealer, ask a trans tech if he has one laying around.
#3228586 - 12/26/13 06:56 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
eljefino Online   content
Loc: ME
It's in here somewhere... wink
The good thing about metric is, it's a standard! Tons of stuff is 8mm and usually the thread pitch is close to universal too. Saturns make great donors of literal buckets of bolts.
#3228619 - 12/26/13 07:31 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
FXjohn Offline
Loc: NE Indiana
Just pay the 8.22 bucks. how did you lose them?
#3228629 - 12/26/13 07:48 PM Re: I need a single bolt. How hard can it be? [Re: FXjohn]
dishdude Offline
Loc: Phoenix
That's what I'd do. It's annoying, but get it over with and move on to life's next annoyance.
#3228648 - 12/26/13 08:12 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
Merkava_4 Offline
Loc: Clovis, CA
I you would post the size of the bolt (diameter, length, and thread pitch) I could find it easily. The Ford part number is worthless because it doesn't give me the size.
#3228653 - 12/26/13 08:18 PM Re: I need a single bolt. How hard can it be? [Re: Merkava_4]
yonyon Offline
Loc: NJ, USA
Originally Posted By: bdcardinal
dimensions are M8 x 1.25 x 19.
#3228657 - 12/26/13 08:23 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
FXjohn Offline
Loc: NE Indiana
if they don't match, it will be kind of childish. it may work, but it will look like the little rascals worked on your car.
Edited by FXjohn (12/26/13 08:24 PM)
#3228658 - 12/26/13 08:27 PM Re: I need a single bolt. How hard can it be? [Re: yonyon]
Merkava_4 Offline
Loc: Clovis, CA
Thank you. I found one that is 1mm longer but it should work:
http://www.dormanproducts.com/gsearch.aspx?type=keyword&q=459-420
http://www.oreillyauto.com/site/c/detail...1&ppt=C0344
#3228660 - 12/26/13 08:31 PM Re: I need a single bolt. How hard can it be? [Re: Merkava_4]
FXjohn Offline
Loc: NE Indiana
Thank you. I found one that 1mm too long but it should work:
it should "work" after you grind it. how much? I see O reilly is a box of 10 for 10.50. that's stickin it to the man.
Edited by FXjohn (12/26/13 08:32 PM)
#3228663 - 12/26/13 08:32 PM Re: I need a single bolt. How hard can it be? [Re: FXjohn]
yonyon Offline
Loc: NJ, USA
Why grind at all? It's already the wrong color so there's no harm in putting a washer on it.
#3228665 - 12/26/13 08:34 PM Re: I need a single bolt. How hard can it be? [Re: FXjohn]
Merkava_4 Offline
Loc: Clovis, CA
You're gonna grind off one millimeter? Why not just put a washer under the head?
#3228666 - 12/26/13 08:36 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
01rangerxl Offline
Loc: Birmingham, AL
Originally Posted By: gr8gatzby
I need a single trans pan bolt. Ford part #N605904-SA. Not sold at AZ/AA/O'Reily. This bolt, in a package of two can be found cheap online($2.50), but then shipping adds $11-$14 to the bill. The Ford dealer wants $8 per bolt. Anyone with an alternative solution here?
Go to Pull-A-Part on N. Tryon St., towards the University area. The bolt you need IS in there.
2002 Ford Ranger XLT | 3.0 V6 / 5-Speed Automatic / 2WD | 185K miles
1994 Ford Ranger STX | 4.0 V6 / 5-Speed Manual / 4X4 | 180K miles
#3228667 - 12/26/13 08:37 PM Re: I need a single bolt. How hard can it be? [Re: Merkava_4]
FXjohn Offline
Loc: NE Indiana
why not just use the right bolt so the pattern doesn't look like a kinder gardener did it?
#3228672 - 12/26/13 08:41 PM Re: I need a single bolt. How hard can it be? [Re: FXjohn]
yonyon Offline
Loc: NJ, USA
I'm so glad I don't know what color gr8gatzby's truck is because if I did I'd end up having nightmares about hordes of small children crawling around under his truck.
#3228679 - 12/26/13 08:47 PM Re: I need a single bolt. How hard can it be? [Re: gr8gatzby]
yonyon Offline
Loc: NJ, USA
OMG!!! That one got his tongue stuck in the rear differential fill hole!
