Hi All, Its my understanding that the Prestone Dexcool and the normal Prestone Entended Life coolant and pretty much the same. I got this email from Prestone about it.
Good Afternoon Don,
You would be perfectly fine to switch your vehicle over to Prestone Extended Life Antifreeze, or even to use that coolant to top off the Dex-Cool antifreeze currently in your truck. Those two coolants are extremely similar as they use all the same corrosion inhibitors, the Dex-Cool simply has a higher concentration of some of them in order to meet the GM spec.
We offer the GM Dex-Cool so that people can have the peace of mind that comes with filling their car with a manufacturer approved coolant, but we are fully confident in the Prestone Extended Life's ability to provide your cooling system with all the corrosion protection and heat transfer capabilities it requires. Please let me know if you require anything further.
Sincerely,
Aaron Jones
Prestone Consumer Relations Representative
Phone: 203-731-8191
So, After reading this email, It seems the Prestone DEXCOOL has more additives? Whats the deal. Learning up on coolants. Thanks all
Good Afternoon Don,
Sincerely,
Aaron Jones
Phone: 203-731-8191
