What product was that?
by another Todd
38 minutes 36 seconds ago
choice between reciprocating corded saws
by edwardh1
53 minutes 52 seconds ago
Is the driving experience getting worse?
by fdcg27
Today at 06:24 PM
Scratched wheel
by gabriel9766
Today at 05:52 PM
Gear oil added to motor oil in engine
by TiredTrucker
Today at 05:52 PM
Purolator 10111 Cut Open- Red Can- NEW
by FordBroncoVWJeta
Today at 05:51 PM
A Tesla Model S on auto-pilot was in a fatal crash
by JimPghPA
Today at 05:49 PM
Motorcraft 5/20 Blend - 2015 3.7l TiVTC. (5316Mi)
by DuckRyder
Today at 05:00 PM
By law, do owners have to comply with recall ?
by HTSS_TR
Today at 04:54 PM
Stuck ring?
by TurboFiat124
Today at 04:16 PM
Protectant 303 vs. Wax on fiberglass surfaces
by mbacfp
Today at 03:17 PM
Jeep brakes
by buck91
Today at 03:10 PM
MNfarmer33, doublegarage, goatrancher, jameson223, graywolf001
58322 Registered Users
98 registered (Blkstanger, anl0109, 01rangerxl, 901Memphis, AMC, another Todd, 11 invisible), 1717 Guests and 7 Spiders online.
58322 Members
66 Forums
251057 Topics
Page 1 of 2 1 2 >
#3227839 - 12/25/13 10:05 PM Making a gasket
ram_man Offline
Loc: southern mo
My 95 ram the one that sat for four yrs well the passenger side valve cover is leaking . I don't want to have to buy a valve cover gasket set. But they don't sell them individually.
What is the best way to Make one?
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3227843 - 12/25/13 10:09 PM Re: Making a gasket [Re: ram_man]
Merkava_4 Offline
Loc: Clovis, CA
They don't sell them individually? I got one by itself from NAPA.
#3227846 - 12/25/13 10:13 PM Re: Making a gasket [Re: ram_man]
Zaedock Offline
Loc: Massachusetts
The roll of cork will cost about as much as the $20 gasket set from Parts Geek.
2012 F150 Ex-cab 5.0L/2004 Malibu Maxx LT
1992 YJ "The Heep"/1994 Olds Cutlass Ciera 3.1/auto
1975 Ford Bronco/1959 Willys CJ5/20XX Custom rock crawler
#3227849 - 12/25/13 10:19 PM Re: Making a gasket [Re: ram_man]
tommygunn Offline
Loc: usa
Why wouldn't you get the set? The other one is probably on its way out too.
Is the other gasket that difficult to replace? (like most FWD transverse V6/V8 engines can be)
i am a [censored] who hides behind bugmenot.
i also like applying negative pressure to a certain male appendage.
#3227876 - 12/25/13 10:49 PM Re: Making a gasket [Re: ram_man]
Merkava_4 Offline
Loc: Clovis, CA
I was bored so I looked up the set.
NAPA Part Number: FPG VS50419R $30.89
#3227885 - 12/25/13 10:59 PM Re: Making a gasket [Re: ram_man]
Kruse Offline
Loc: Kansas
A quick peek at RockAuto shows your valve cover gaskets at $17 and $20, plus shipping. If one valve cover is going out, chances are the next one will be right behind.
I suspect that by making your own gaskets the material will almost be that high and you haven't even figured in your own time yet. I'd bite the bullet and buy a pre-made set.
#3227913 - 12/26/13 12:18 AM Re: Making a gasket [Re: ram_man]
ram_man Offline
Loc: southern mo
Well to be honest this truck will eventually be stripped and all redone (it was my grandfathers) so the engine will be torn apart eventually amd redone. So cheaper is preferred. The other side isnt leaking for now and its not a daily driver. It went 1500 miles this year so its not used a lot. So right now cheap is preferred.
#3227918 - 12/26/13 12:37 AM Re: Making a gasket [Re: ram_man]
donnyj08 Offline
Loc: Cincinnati, OH
20$ is pretty cheap, just replace both while your at it.
2008 Silverado Z71 LT 75k Kendall FS 5w30, Hastings LF613
#3227923 - 12/26/13 12:49 AM Re: Making a gasket [Re: ram_man]
Merkava_4 Offline
Loc: Clovis, CA
Permatex Right Stuff might be an option for you.
#3227966 - 12/26/13 03:35 AM Re: Making a gasket [Re: ram_man]
eljefino Online   content
Loc: ME
They sell make a gasket in 6 x 8 inch sheets where you trace and cut what you need. Good for obscure small engine intake manifolds etc. But a valve cover gasket is huge. Just buy the correct part already.
#3228018 - 12/26/13 06:43 AM Re: Making a gasket [Re: ram_man]
Char Baby Offline
Loc: Western NY
RTV may be your cheapest choice!
"Retired"
'80 Firebird FORMULA V8/4bbl-NEW
'06 Mazda 3i 2.0L-Pre Owned
'15 Nissan Altima 2.5 SV-CPO
Still looking for a car for my wife(new, used, CPO)
#3228023 - 12/26/13 06:49 AM Re: Making a gasket [Re: ram_man]
Rick in PA Online   content
Loc: Southeastern, PA
I'm cheap and I'd consider making a gasket, but not in this case, too big.
A. Buy the right one.
B. Goop it with some silicone stuff.
My 2 cents.
A wise man told me:
"Heat is your friend." and "Any oil is better than no oil."
#3228077 - 12/26/13 08:11 AM Re: Making a gasket [Re: ram_man]
Loc: ME
If you lack the ambition to use a proper gasket, and have to ask here what to use, perhaps overhauling this engine (in the non-committed future) may not be for you.
#3228156 - 12/26/13 10:37 AM Re: Making a gasket [Re: eljefino]
ram_man Offline
Loc: southern mo
I really don't need a smart mouth comment. This is pretty straight forward! I would like to make one gasket. I don't need both. The other side isn't leaking and on a vehicle that isn't used much and in less than 3yrs will be completely torn down and redone.
I just didn't want to buy a set when i only need one. The other side could start leaking tomorrow or it may not ever leak . No sense in pulling a gasket that's doing it's job just fine. Especially when the vehicle is used less than 2,000 miles a yr.
#3228157 - 12/26/13 10:39 AM Re: Making a gasket [Re: eljefino]
ram_man Offline
Loc: southern mo
Also maybe you could explain why me not wanting to replace both gaskets and preferring to make one of my own if it can be done correctly and cheap enough to justify itself means I lack ambition? I would think me wanting to make my own which is more labor would probably mean I have a fair amount of ambition.
Page 1 of 2 1 2 >
