How to cut power to breaker box ?
by Merkava_4
06/28/16 02:21 AM
Spark plugs in hi-per applications
by mjoekingz28
06/28/16 01:07 AM
OK, before I lube it ...
by BrocLuno
06/28/16 12:53 AM
Toyota Japan Fluid SDS
by SXE10
06/27/16 11:28 PM
Online Oil Viscosity Selectors
by Merkava_4
06/27/16 11:25 PM
Considering a differential swap
by buck91
06/27/16 10:18 PM
HVAC Evaporator Cleaning Results
by sleddriver
06/27/16 09:51 PM
Car Acronyms
by Marco620
06/27/16 09:46 PM
Vibration with new tires - your thoughts
by Bandito440
06/27/16 09:41 PM
Carpet cleaning methods.
by Run
06/27/16 09:26 PM
Fram XG16 4522mi 5.7 Hemi
by AntsinmyEyes
06/27/16 09:26 PM
Emtrac Plus Battery
by Tapan
06/27/16 09:25 PM
peg, CornbreadMan, JoelB, alostaunau, alanwayne1908
58295 Registered Users
22 registered (edhackett, car51, Bill_G, bbhero, ac_tc, 1 invisible), 709 Guests and 11 Spiders online.
58295 Members
66 Forums
250917 Topics
Page 2 of 2 < 1 2
#3228342 - 12/26/13 02:09 PM Re: Additive that is closest to ARX in effectiveness? [Re: kschachn]
SteveSRT8 Offline
Loc: Sunny Florida
Originally Posted By: kschachn
Why have you used it for years? What are you doing to your engine to require its use? Assuming it does anything in the first place, of course.
Glad you love it as you are making the sellers happy too. Just explain why you need it so much.
Originally Posted By: gr8gatzby
Have used ARX for years now and have only good experiences to share. Love the stuff. Recently though, I joined the ranks of the unemployed and cannot afford the price of admission. Are there competing additive packs that approach ARX effectiveness and quality, but at a lesser price? Thanks.
This really is an EXCELLENT question.
"In a democracy, dissent is an act of faith."
J. William Fulbright
Best ET-12.79 @ 111 mph
4340 pounds, Street tires
Just like we go to Publix
#3228396 - 12/26/13 03:04 PM Re: Additive that is closest to ARX in effectiveness? [Re: Shannow]
Clevy Offline
Loc: Saskatoon canada
Originally Posted By: Shannow
You could (and I have) take some Canola, some methanol (eg heet - I've used anhydrous ethanol before), some caustic, and manufacture RME (Rapeseed Methyl Ester)...google biodiesel soda bottle...AutoRx patent is lanolin, esterised with various alcohols.
Which will be an ester, with very high solvency....in fact changing to high levels of biodiesel in an older fuel system can stir up all sorts of junk.
I've added it to engines for the last 1,000km of an oil change, and had remarkably similar results to my runs of AutoRx...pretty much nothing noticeable.
Oil would need to be thick enough to handle the thinner solvent.
There you go op. Make your own
2006 Charger RT
Miles x 2 per oil filter
#3228865 - 12/27/13 03:45 AM Re: Additive that is closest to ARX in effectiveness? [Re: gr8gatzby]
ac_tc Online   content
Loc: sweden
a quart of appropriate redline...here you have all the
esters you need.
My blend: 80-100% HDEO and the rest is redline xw-y (havent found 0w-20 yet, but when i do iŽd use it to thin the hdeo down a bit)
-98 Dodge Durango 5.9 4*4 HDEO 10w- 40 ci4
-04 PT Cruser GT 10w- 40 HDEO ci4
-Everything else HDEO 10w- 40 ci4/STOU 10w-30/THF
#3229863 - 12/28/13 09:06 AM Re: Additive that is closest to ARX in effectiveness? [Re: Donald]
Trav Offline
Loc: MA, Mittelfranken.de
Originally Posted By: Donald
I think a synthetic oil would provide a similar cleaning in a slow manner which is what ARX is all about.
+1 Some of the modern oils like PU, PP and some Mobil 1 have excellent cleaning abilities.
I had an engine apart a few months ago that had lots of varnish and some buildup, the Mobil 1 did a great job. The oil literally had a red tint from the varnish.
It does take time though and is not dependent so much on miles driven from what i saw.
#3229949 - 12/28/13 11:08 AM Re: Additive that is closest to ARX in effectiveness? [Re: gr8gatzby]
KCJeep Offline
Loc: Mahzurrah!
The new Castrol gold bottle apparently has some bio-esters in it and would be an interesting candidate for this as well.
2004 Jeep Grand 4.0 @ 133k Pennzoil HM 10w30 w/ 1 qt 10w40
Fram PH8A
KIA Sedona 60k, Ford Focus 115k, Chrysler Sebring 186k, Chrysler Concorde 115k
#3235833 - 01/03/14 12:02 PM Re: Additive that is closest to ARX in effectiveness? [Re: gr8gatzby]
gr8gatzby Offline
Loc: Charlotte, NC
Thoughts on LC20?
'95 Ford F150 | 4x4 | 5.8 | 13MPG
'96 Volvo 850 Wagon | I5 | 5SP | 24MPG
#3235860 - 01/03/14 12:13 PM Re: Additive that is closest to ARX in effectiveness? [Re: gr8gatzby]
ChrisD46 Offline
Loc: GA.
What about MMO or Seafoam - both avilable locally as well ?
#3235949 - 01/03/14 01:08 PM Re: Additive that is closest to ARX in effectiveness? [Re: gr8gatzby]
MolaKule Offline
Loc: Iowegia - USA
LC20 will remove carbon over time.
While it does clean carbon, it does not affect seal swell.
I got up this morning and ran around the block. Then I got tired so I put the block back in the Toy Box. smile
#3236739 - 01/04/14 04:32 AM Re: Additive that is closest to ARX in effectiveness? [Re: Shannow]
sprintman Offline
Loc: Canberra ACT Australia
I always go up a grade if using Arx (2 - 2 1/2 bottles), and run it 8-10,000 kms. 1,000 kms is pointless imo.
#3237209 - 01/04/14 01:28 PM Re: Additive that is closest to ARX in effectiveness? [Re: steveh]
Ken2 Offline
Loc: Washington St.
Originally Posted By: steveh
All additives are very effective. They all do a excellent job of cleaning out your wallet!!
But, the car runs faster due to your lighter wallet.
If the engine has a specific problem, use the additive that is designed for that problem. Otherwise, save your money and just use any top brand oil.
Every gun that is made, every warship launched..a theft from those who hunger and are not fed, those who are cold and not clothed.
Gen. Eisenhower
#3238728 - 01/05/14 08:17 PM Re: Additive that is closest to ARX in effectiveness? [Re: gr8gatzby]
andyd Offline
Loc: Marshfield , MA
Heh heh I add a pint of MMO to the oil to thin it for the winter. Any cleaning it does is a bonus. And I spilt a little so I got a good whiff of wintergreen. 6 bux wont break the budget and a pint sure wont kill anything. Happy New Year!
1988 BMW 528e 20w50 dino, STP filter
'09 Camry SE, Valvoline bulk 5w30 and ? filter
Page 2 of 2 < 1 2
