I had a Generac 20kW Guardian generator. This system is installed in southwest area of Virginia and the record lows are near 0 and the highs can be in the 90's. The system rarely runs except for the 12 min cycle once a week. I will do a system test every few months to let it run for an hour or so.
For winter, I changed the oil using PYB 10W-30 and Generac brand oil filter. It is uses the a standard Kawasaki 3/4" X 16 2.7 in OD but specifies Generac 070185F which is the 3.5-in long version.
I talked with the installer and asked what others were doing and just said in some run Mobil 10w-30 synthetic.
Now Generac specs SAE 30 > 32 F, 10W-30 between 40 F and -10F, Syn 5W-30 for 10 F and below.
The manual oil change interval is 2 years or 200 hrs.
If you take the above literally, I would need to change the oil again in March to put in 30 wt. What I would like to do is run one oil 10W-30 and just change it at 6 months or if it gets close to the 200 hrs.. not every likely unless there is some ice storm that lasts a week or wind event during the summer.
I also have a utility vehicle and a riding 24 HP lawn mover (both spec 10w-30 0 F to 90+) so would like to use the same oil in all I have been running PYB in the mower and JD oil in utility that is what the dealer gave me initially.
I would say run 10w-30 dino (if I am cheap) or synthetic in all including the generator year round despite Generac's notes but if I have to two use diff 10w-30 oils the world does not end. I also thought about Rotella T5 since it is cheap and available locally.
Thoughts?
Thoughts?
