Merry christmas everyone.Question on my 08 dodge dakota 4.7L transmission oil cooler hose.The return hose (hot) was leaking from the factory one at the crimp and i took it off and put a new transmission hose on where the metal tube flare (meets) and put a worm clamp on bothe ends and still leaks..now there are two flares on each end on the metal tube should i just push the hose over top of the metal flares and use one clamp or two each end..could this do the trick?
