cstoremotoroil.com
by AirgunSavant
Today at 09:37 AM
What's good/bad about a 2006 Mazda 5?
by 55Test
Today at 09:30 AM
My 1st air impact - go with 3/8" or 1/2" drive ?
by Cressida
Today at 08:55 AM
Silly me
by jay929
Today at 08:41 AM
15K oil & filter
by marine65
Today at 08:36 AM
Battery or starter
by Dallas69
Today at 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
Today at 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
Today at 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
Today at 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
Today at 04:54 AM
Coolant Question.
by Farmer
Today at 04:20 AM
Stocking up for the Eco
by buck91
Today at 12:25 AM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
61 registered (AKA, AnthemBassMan, AirgunSavant, 1JZ_E46, 97f150, 2004tdigls, 5 invisible), 1661 Guests and 36 Spiders online.
58935 Members
66 Forums
253619 Topics
Page 1 of 2 1 2 >
#3225890 - 12/23/13 07:39 PM 05 Chevy Colorado T-Stat change?
Keith_Stone Offline
Loc: NC
Anyone changed a stat on these trucks? Have to remove the drivers side tire and splash guard, it's a side access with the I5 engine. The housing/stat is one piece. I'm getting a P0128 code on cool days with the temp coming up slowly. I'll get heat only after 6-8 miles. Cooling system is full with clean coolant. Guess I've got a lazy stat that won't fully close.
NRA Lifer
#3225897 - 12/23/13 07:48 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
Chris142 Offline
Loc: apple valley, ca
I have done a few on hummer h3's with that same engine. Not too bad on those, definatly not as bad as the 3.1 and 3.4 stat
02 Wrangler Chevron 10w30
87 F250 napa 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3225900 - 12/23/13 07:50 PM Re: 05 Chevy Colorado T-Stat change? [Re: Chris142]
Keith_Stone Offline
Loc: NC
I understand one of the 10mm bolts is hard access. Will I need a universal joint and couple of extensions? Does the stat gasket require gasket compound?
NRA Lifer
#3225902 - 12/23/13 07:51 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
GMBoy Offline
Loc: Texas
I am with Chris142 as I also have changed these in both H3's and Colorado/Canyons. Not a bad job.
#3225903 - 12/23/13 07:52 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
GMBoy Offline
Loc: Texas
No, the gasket is an o-ring. No need for anything to be applied to it.
It's been awhile since I did one, but I think I did use a universal socket and you do need an extension for sure.
Edited by GMBoy (12/23/13 07:53 PM)
#3225904 - 12/23/13 07:53 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
salv Offline
Loc: Cadyville, NY
not difficult, but tedious.
2003 Trailblazer: Mobil Super HM 5w30 L25288
2000 Ford Focus Wagon: Mobil Super 5000 DW-5230
#3225908 - 12/23/13 07:54 PM Re: 05 Chevy Colorado T-Stat change? [Re: salv]
Keith_Stone Offline
Loc: NC
Would you guys suggest a OEM stat?
NRA Lifer
#3225915 - 12/23/13 08:02 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
ram_man Offline
Loc: southern mo
Cant you just buy a t stat? My saturn has the style where the t stat twists and pops into the housing.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3225918 - 12/23/13 08:04 PM Re: 05 Chevy Colorado T-Stat change? [Re: ram_man]
Keith_Stone Offline
Loc: NC
I think I read it's one piece.
Edited by Keith_Stone (12/23/13 08:07 PM)
NRA Lifer
#3225943 - 12/23/13 08:32 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
Chris142 Offline
Its a 1 piece stat and housing so you cant just buy the stat. The oe ones seem to be failing often. We have been using aftermarket ones and so far they are not any worse than the oe.
87 F250 napa 15w40
Z400 Lucas 10w30
KLR250 Maxima 10w40
#3226057 - 12/23/13 11:02 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
crazyoildude Online   content
Loc: New Jersey
get it from the stealer they are better sometimes its better to get oem forget that you will be paying 40%-50% more if its not good there goes your engine
Will Not Use Oil Filters With Those Tiny Restrictive Looking Louvers! Also Not A Fan Of Oil Jugs That Don't Have A Security Inner Seal..
#3226323 - 12/24/13 09:38 AM Re: 05 Chevy Colorado T-Stat change? [Re: crazyoildude]
Keith_Stone Offline
Loc: NC
I found this tutorial on the stat change. Should I retain the oem clamps or replace with regular screw style?
http://www.355nation.net/forum/how-performance-maintenance/68410-how-changing-your-thermostat.html
NRA Lifer
#3226879 - 12/24/13 09:47 PM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
GMBoy Offline
Loc: Texas
I bought one for an H3 on Rockauto - AC DELCO that was cheaper even with shipping then the Autozone part.
#3227007 - 12/25/13 05:00 AM Re: 05 Chevy Colorado T-Stat change? [Re: Keith_Stone]
George7941 Offline
Loc: Toronto, Canada
I have had the OE GM and one RockAuto Delco replacement stat fail, so last time I got the Stant stat from RockAuto and the Stant seems to be holding up well. So at least on the 4.3l engine, my advice is to avoid the Delco stat.
2006 GMC Sierra 4.3l, NV3500,G80 , Formula Shell Synthetic 5W30,Dexcool.
1987 BMW R80 - sold
2015 Honda CBR300R
Staying out of the right lane a lot.
#3233227 - 12/31/13 08:41 PM Re: 05 Chevy Colorado T-Stat change? [Re: George7941]
Keith_Stone Offline
Loc: NC
Changed the stat yesterday. Much to my surprise the stat was fully closed. However in a hot water test it started to open at only 158. I now have a normal temp gauge reading and the P0128 did not reappear. I had 196 near the coolant sensor when checked with my IR gun.
NRA Lifer
Page 1 of 2 1 2 >
