Is Legalizing Marijuana Safe????
by qwerty1234
05/30/16 03:44 AM
Why it's a bad idea to ignore wheel-bearing noises
by Tegger
05/30/16 03:29 AM
Water decarbonization, does it work?
by FordCapriDriver
05/30/16 01:56 AM
Do I need a better tire for PNW trip?
by The_Eric
05/29/16 11:51 PM
Turtle Beach PC headset hack
by asand1
05/29/16 11:34 PM
Lengthy question for the seasoned oil gurus
by Jetstreamz06
05/29/16 11:10 PM
Jeep Cherokee Heater Valve - Brands?
by Nick1994
05/29/16 11:00 PM
Hyundai Entourage/Kia Sedona minivans
by Number_35
05/29/16 10:41 PM
Oil in air breather tubing
by Nissan101
05/29/16 10:06 PM
Dust caps needed to protect wheel bearings?
by Drew99GT
05/29/16 09:51 PM
2014 Mazda CX5 SkyActiv
by Matt_V
05/29/16 09:38 PM
getting rid of pwc with intermittent problem?
by motor_oil_madman
05/29/16 08:36 PM
kevinstoyhauler, jimx1169, W9HDG, LloydChristmass, dodge96
58019 Registered Users
18 registered (bernau, ASW338, bubbatime, asand1, bbhero, 2 invisible), 560 Guests and 310 Spiders online.
58019 Members
66 Forums
249584 Topics
Page 2 of 9 < 1 2 3 4 5 6 7 8 9 >
#3220883 - 12/18/13 05:02 PM Re: 0W-20 in a BMW M-60 [Re: edyvw]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Originally Posted By: edyvw
[quote=kschachn]I'd put there GC 0W30 or M1 0W40.
It is old fashioned European engine that simply loves heavier oils.
That's an old wife's tell.
Both GC and M1 0W-40 are heavier than necessary for optimum winter use. The M1 0W-30 he is using now actually exceeds the specified viscosity requirements of his engine as it does for my somewhat newer M52 engine.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3220891 - 12/18/13 05:25 PM Re: 0W-20 in a BMW M-60 [Re: kschachn]
97tbird Offline
Loc: Fayetteville, NC
tale.
Sufficiently Caffeinated...
Cars: 1997 Thunderbird v8 sports(sold), 2003 Elantra GLS, 2005 BMW 330Ci ZHP, 2014 Mazda 6 Touring
#3221021 - 12/18/13 08:18 PM Re: 0W-20 in a BMW M-60 [Re: edyvw]
LotI Offline
Loc: America's Dairyland
Originally Posted By: kschachn
Well that is how it is being driven. My daughter uses it at school and I found out that she has been driving it between the dorms and school most days - often in below zero weather. So a lot of short tripping with an occasional trip home. The school is far north in Wisconsin where it has been very cold lately.
No pressure gauge unfortunately, I knew that would be a good indicator. I might see about adding one and testing the oil over Christmas when I will have the car for a month.
Idk, man. Do whatever you think you should do, but I would put there GC 0W30 or M1 0W40.
I think with the short tripping, any oil will be heavy.
03 Honda VFR800VTEC .8L RT6
04 Kawasaki Vulcan Nomad 1.5L RT6
12 Ford E450 6.8L PU
14 Honda Accord Sport 2.4L PPPP
#3221035 - 12/18/13 08:29 PM Re: 0W-20 in a BMW M-60 [Re: LotI]
CATERHAM Offline
Lotl you're right which means TGMO 0W-20 would still be too heavy, but on the hwy trip it won't be.
As the car is being driven conservatively I think a 0W-20 would be an ideal winter engine lube.
#3221041 - 12/18/13 08:34 PM Re: 0W-20 in a BMW M-60 [Re: CATERHAM]
kschachn Offline
Loc: Upper Midwest
I'll post it on Saturday when I see the vehicle next. I think the chart does allow 5W-20 for cold weather, but that was most certainly some inferior dino oil available in 1994. I think old charts are pretty much useless these days, irrespective of the fact that a lot of automakers seem to persist publishing them in today's manuals. I've seen some that really don't make sense.
I never know what people mean when they say an engine likes a certain oil. Everybody always says BMWs "like" thick oil but what is that supposed to mean?
Originally Posted By: CATERHAM
kschachn, I'm curious what you're '94 BMW M60 oil recommendation chart and related literature says from your drivers manual.
Can you post it?
1994 BMW 530i, 205K
1996 Honda Accord, 216K
1999 Toyota Sienna, 344K
2000 Toyota ECHO, 252K
#3221059 - 12/18/13 08:52 PM Re: 0W-20 in a BMW M-60 [Re: kschachn]
CATERHAM Offline
I have some older vehicle charts and I've never seen one didn't make total sense to me.
The following I posted in another thread but it's applicable I think:
"Even for cars built in the 70's and 80's the 20W-20 grade was still spec'd as an option for fall, winter and spring use.
For my first car, a '72 Ford Capri, 20W-20 was spec'd for ambient temp's from 25F to 70F. My '86 Porsche has similar recommendation for the 20W-20 grade from -10C (14F) to 15C (60F).
Interestingly enough the 5W-20/30 grades were specified for my Capri only for sub-freezing temps from 32F down to -40.
Much the same for my Porsche with the 5W-20 grade from -10C (14F) and lower and a dino 5W-30 from -30C (22F) to 32F.
The 20W-20 grade had fallen out favour by that time because the now common 10W-30 grade had much better cold start performance, spec'd down to -25C (13F) although only up to 70F for both of these European cars.
Obviously manufacturers didn't have a lot of confidence in light multi-grade mineral oils of the day.
Porsche spec'd a 0W-30 up to 30C (86F)."
#3221124 - 12/18/13 09:59 PM Re: 0W-20 in a BMW M-60 [Re: CATERHAM]
Doug Hillary Offline
Loc: Airlie Beach Australia
Hi,
CATERHAM - I can confirm the early popularity of the 20W-20 viscosity (one was Castrolite). This viscosity was popular in 356 Porsche and VW cars (as HD20) and most BMC A and B Series engines survived on it. The 20W-50 viscosity was especially developed by Duckhams (and later Castrol) for the Mini - totally due to the integrated power unit. The 20W-50 caused oil pump failure in these engines too!
Later, 20W-50 became the "fix it" lubricanst for all and sundry!
10w-30 became popular in Oceania and Europe from the mid 1950s (Mobiloil Super in Gold one pint cans was one)!
It was made increasingly popular in Europe because of the US Personnel involved there in "cold war" activities. Their US cars needed it!!
During the 1960s in Scandinavia and Germany for instance 20W-20 and SAE30 were still front runners and 10W-30 was a backstop. By this time Porsche, MB and some others were busily commencing promoting their Approved Lubricants (Marketplace Name etc). Very comprehensive Handbooks on this subject were produced by the Manufacturers for many years
My philosophy has always to use the lowest permissible viscosity as decreed by the engine's Manufacturer for its application
Regards
Doug
#3221150 - 12/18/13 10:34 PM Re: 0W-20 in a BMW M-60 [Re: CATERHAM]
edyvw Offline
Loc: Colorado Springs
Yeah, I know. paper says one thing, practice another. Well, sure just go ahed, use that!
Personally, if someone put 0W20 in my BMW with any engine, let's say he would loose a job!
At that time people in Europe used 10W40 in those engines.
But what they know, they just made that engine!
13' BMW X5 35d (M1 5W30 ESP + OEM filter)
11' VW Tiguan 2.0T (Castrol 0W40+OEM filter)
#3221230 - 12/19/13 02:54 AM Re: 0W-20 in a BMW M-60 [Re: CATERHAM]
Shannow Online   content
Loc: Oz
What ARE the "specified viscosity requirements" for the engine, and where does one find this information ?
cst please, as that's viscosity.
#3224452 - 12/22/13 09:04 AM Re: 0W-20 in a BMW M-60 [Re: CATERHAM]
kschachn Offline
Loc: Upper Midwest
Here you go. The typical old BMW multi-arrow chart and the loose specs:
Can you post it?
1994 BMW 530i, 205K
#3224676 - 12/22/13 02:05 PM Re: 0W-20 in a BMW M-60 [Re: kschachn]
CATERHAM Offline
Thanks for posting that.
I am surprised that you've got the same type of all grades recommendation chart as for my older Porsche. My only two MYs newer Bimmer only recommends two grades (other than the synthetic *Special- Oils) with an SG energy conserving 5W-30 dino up to 50F although the manual says "you can continue to operate the vehicle for short periods of time at temperatures above that..." as does your manual.
It looks like by 1996 BMW had a bit more confidence in the shear stability of the mineral 5W-30 by recommending it for higher max' temp's than for your car.
If you do decide to run a 20 grade oil you can have some fun properly claiming that's what BMW spec's for my car which will no doubt freak out the heavy oil only in BMWs set.
#3224755 - 12/22/13 03:36 PM Re: 0W-20 in a BMW M-60 [Re: CATERHAM]
Hi,
from the Chart it's easy to see why 20W-50 retained it's popularity in many marketplaces!
The Porsche 928 fraternity loved 20W-50 and here in OZ some "Porsche Specialists" even went higher to "..keep up hot idle OP in the summer.."". I ran 5W-40 Delvac in mine (32V)with great results even at 40C and on many long trips at very high speed. The 928 FF was Shell XMO 5W-40 from around 1990 - the first production cars to have a synthetic FF
A synthetic 5W-50 (or 15W-50) still has a lot to offer IMO in these cases
Regards
Doug
#3224801 - 12/22/13 04:13 PM Re: 0W-20 in a BMW M-60 [Re: kschachn]
kschachn Offline
Loc: Upper Midwest
OK, parsing that chart a bit - why would they say 5W-30 is only good up till about 25 degrees Fahrenheit? What was their rationale? Was it excessive consumption or some sort of diminished engine protection?
Also, what were the "special oils"? Synthetic? And without stating what the viscosity of the special oil is/was, how can they specify that it was good from -20 to the upper limit? Are they assuming the BMW dealer would specify more than one possible special oil depending on ambient temperatures? Did BMW ever have more than one special oil?
And why all the emphasis on ambient? I get why this is important for starting, but surely it can't be all that relevant for operation. Is it? This is a question I always have for any oil chart based on OAT.
This is why I find most oil charts to be confusing. And this one in particular.
Is a modern 5W-30 (synthetic or not) just that much better that you don't rip it out at 25 degrees?
1994 BMW 530i, 205K
#3224971 - 12/22/13 09:15 PM Re: 0W-20 in a BMW M-60 [Re: kschachn]
CATERHAM Offline
Wow lots of questions.
The reason a dino 5W-30 was "only" good to 25F was shear instability during long OCIs but remember they say it can still be used for short periods at higher temp's. My interpretation of BMW's qualification is that you can still use a lighter oil beyond the maximum temp' range on the chart but avoid using full power. Not using WOT particularly at lower rev's dramatically lowers the viscosity demands of an engine.
The importance of ambient temp's is that it does correlate with maximum oil temp's.
When the ambient temp's are below freezing it is very difficult to get oil temp's up even into the low normal range of say 80C with many vehicles and definitely Bimmers. Roughly speaking a 20 grade oil has the same operational viscosity at 80C that a 40 grade oil does at 100C.
The advantage of synthetic oils vs the cheaper dino oils of the day is that they are much more shear stable and therefore can maintain the required minimum viscosity at higher temp's.
Having oil pressure and oil temp' gauges is the only way to know what the actual operational viscosity in an engine is a any moment and how much it varies. Operational viscosity, once the coolant is up to temperature, is affected by many factors in addition to ambient temp's and oil shear. There's also fuel dilution and engine load and rev's, road speed and engine running time all will affect oil temperature.
I strongly recommend that all members who want to understand the topic install oil gauges. Quite frankly it is impossible to fully understand the subject of oil viscosity in an engine without the first hand experience gauges provide.
#3224982 - 12/22/13 09:32 PM Re: 0W-20 in a BMW M-60 [Re: kschachn]
nleksan Offline
Loc: Cincinnati, OH
I would not recommend using anything less than a 0/5w30 in any BMW, and I honestly don't see any reasonto. The ideal oil weight IME is 0/5w40 for non-M cars.
00 328Ci(419rwhp/392rwtq) RL/Motul/OS Giken
06 M3 ZCP/6MT - RL
01 325i - RL/RP
03 M5 - RL
88 M6 (Eu) - RL
95 M5 (Eu) - RL
