The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
CEL Code P2097, 2010 Mazda 6 with 2.5L I-4
by Snyperx
04/30/16 08:01 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
20 registered (Blkstanger, bbhero, ajchien, 4 invisible), 646 Guests and 329 Spiders online.
57758 Members
66 Forums
248281 Topics
#3221143 - 12/18/13 10:25 PM Maintenance Dosing Gasoline
Ramblejam Offline
Loc: Kentucky
For continual cleanliness & lubrication -- is TC-W3 the choice?
#3221147 - 12/18/13 10:28 PM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
Finz Offline
Loc: Northern NJ
This group certainly seems to think so: sarge
Edited by Finz (12/18/13 10:29 PM)
God Bless America... We really need it about now
06 Odyssey
06 Civic coupe
05 Accord 2.4 sedan
11 Civic 1.8 sedan
98 Accord 2.3 sedan
#3221310 - 12/19/13 07:17 AM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
toneydoc Offline
Loc: War Eagle
Techron is a good choice as well
1994 Jeep 145k Castrol 0w40
2014 Camry 13k TGMO 0w20
2010 Sebring 39k Penn Plat 5w20
2014 HD Ultra 16k Valv20w50
2012 Toyota Rav4 21k Mobil 1 0w30AFE
#3221660 - 12/19/13 01:11 PM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
gaijinnv Offline
Loc: Nevada, USA
If you plan on adding something with every fill-up, then I would recommend Chevron Techron at 1/10 the strength recommended on the bottle.
The dose recommended on the bottle is for a one-time cleaning, but one tenth of that is approximately the level of Techron that Chevron puts in their pump gas.
That 1/10 dose added at every fill-up should be a great maintenance dose.
thumbsup
#3221672 - 12/19/13 01:25 PM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
Eddie Offline
Loc: Florida, Cape Coral
1/10 sounds much higher than I would expect in Chevron gas. Where did this number come from? Ed
CX5 Touring 2.5L :-)
#3221734 - 12/19/13 02:29 PM Re: Maintenance Dosing Gasoline [Re: Eddie]
y_p_w Offline
Loc: SF Bay Area
I think the reference is to 1/10th the concentration recommended on the bottle. There are different versions out there, but the latest I remember is a 12 oz bottle with a recommendation to use it for up to 15 gallons of fuel. I also remember when the 12/20 oz bottles were recommended for 12/20 gallons. So for that one it would be 1 oz for ever 10 gallons.
#3221742 - 12/19/13 02:33 PM Re: Maintenance Dosing Gasoline [Re: toneydoc]
y_p_w Offline
Loc: SF Bay Area
TC-W3 is a standard for marine 2-stroke oil. I think they're asking if it's a good idea to use this in a 4-stroke vehicle.
http://www.nmma.org/certification/certification/oil/tc-w3.aspx
http://www.nmma.org/assets/cabinets/Cabi...rine%20Oils.pdf
#3221749 - 12/19/13 02:44 PM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
surfstar Offline
Loc: Santa Barbara, CA
Techron/Regane/etc + TCW3 FTW!
Clean and lube. I prefer to run a few tanks on, then a few tanks off and play "can I detect a MPG gain" with my data. I did see some improvement with the above mix. ~ 3:1 ratio or so and ~ 1oz/3gal dose.
2000 Civic HX 1.6L MTX ~42mpg | 2005 Saturn Vue 2.2L MTX ~27mpg
2016 Golf Sportwagen 1.8T 5MT =)
#3221832 - 12/19/13 03:53 PM Re: Maintenance Dosing Gasoline [Re: Eddie]
gaijinnv Offline
Loc: Nevada, USA
The bottles of Techron I have are the 20 oz. bottles which indicate they will treat 20 gallons. This equals 1 oz. / gallon.
My recommendation, based on information gleaned over the years from various sources (trust it or not, it's free advice and definitely worth at least what you're paying for it) is to use 1 oz. / 10 gallons as a continuous treatment dose. This is 1/10th the dose recommended on the bottle.
What makes you think 1 oz. / 10 gallons is higher than the amount in pump gas?
Edit to add:
If you are too lazy to Google it, here's what Chevron has to say on their Techron web site:
What is the difference between TechronŽ at the pump and Techron Concentrate Plus in the bottle?
The principal difference is additive concentration and rate of deposit clean-up. Gasolines with Techron over multiple fill-ups will help clean deposits on intake valves and minimize harmful combustion chambers deposits. When added to a full tank of gasoline, a bottle of TechronŽ Concentrate Plus results in an additive concentration roughly 10 times stronger. This mega-dose of Techron provides a much quicker clean up of intake valve deposits left by lower quality gasolines. In addition, the high concentration of Techron reduces combustion chamber deposits, which can help eliminate deposit-related engine knock.
Here's the link: Techron web site
Edited by gaijinnv (12/19/13 03:59 PM)
#3221972 - 12/19/13 06:29 PM Re: Maintenance Dosing Gasoline [Re: gaijinnv]
y_p_w Offline
Loc: SF Bay Area
Edit to add:
I was actually thinking perhaps a little bit lower. There's already at least the EPA mandated amount of detergent in fuel. Most would be synergistic since they're similar in makeup (usually PEA).
And if you're already using a fuel that's advertised as Top Tier or that's advertised as having a high dose (Costco Clean Power) then it may not be necessary.
#3221989 - 12/19/13 06:48 PM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
Artem Offline
Loc: Florida
I pour in an oz of Redline's Fuel System Cleaner into my 13.2 gallon tank at every fill up. Even though I use Shell or BP 95% of the time, I still add the cleaner at small doses simply to add a bit more cleaning additives into the mix.
I haven't done any testing to see if it adds gas mileage due to upper cylinder lubrication because my driving style is all over the place and my average MPGs jump around -7-8 points at practically every fill up... Hahaha.
2015 Lexus ES300H with all the goodies - Factory Fill
2014 Mazda 3 Hatch i Touring 2.0L & 6spd - Mazda 0w20
#3221995 - 12/19/13 06:55 PM Re: Maintenance Dosing Gasoline [Re: Ramblejam]
Eddie Offline
Thank you. I love real data and so much on these sites are opinion, given a fact. Ed
