Walmart ST Full Synthetic 5W30 & 10W30 5QT $12.00
by Jonny5alive
7 minutes 43 seconds ago
Keep America's Nuclear Power Stations Running
by Shannow
Today at 12:14 AM
Lubegard Biotech,my thoughts
by Marco620
Today at 12:03 AM
Frivolous lawsuit loser pays court cost !
by HTSS_TR
Yesterday at 11:49 PM
cold seizure on a small air cooled engine?
by motor_oil_madman
Yesterday at 11:20 PM
Walmart.com PUPP 5W-20 $22.47
by mike718
Pick my oil '75 Plymouth Gran Fury 400 big block
by gallydif
Yesterday at 08:40 PM
Spark plug resistance R5 vs R6
by Ndx
Yesterday at 08:39 PM
Firestone TF2876 C&P
by holdorf333
Yesterday at 08:38 PM
Castrol High mileage or Valvoline Maxlife
by NH73
Yesterday at 08:30 PM
Got to experience cornering ABS today
by LoneRanger
Yesterday at 08:10 PM
Engine Heat Soak - What causes sluggishness
by ryan2022
Yesterday at 08:03 PM
EdandSherry, Shalmaneser, Shipmate29, garytcosta, lifteddiesel90
58332 Registered Users
28 registered (BigRalphie, alcyon, 2009Edge, bvance554, barkingspider, bdcardinal, 2 invisible), 981 Guests and 11 Spiders online.
58332 Members
66 Forums
251067 Topics
#3221123 - 12/18/13 09:58 PM blue Kevlar V-belts
Donald Offline
Loc: Upstate NY
Was looking on Amazon for some spare belts for my snowblower and they sell blue Kevlar belts (PIX brand) where they say they are stronger than a normal belt. About the same price. Any experience?
These will be sitting on a shelf for a year or more, so I will not know how good/bad they are until I break the current one.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3221135 - 12/18/13 10:13 PM Re: blue Kevlar V-belts [Re: Donald]
Rand Offline
Loc: NE,Ohio
I used those on my JD318 then all blew up for some reason.
went back to JD brand belts.
2015 Forester I-Premium 6MT
#3221176 - 12/18/13 11:57 PM Re: blue Kevlar V-belts [Re: Donald]
djb Offline
Loc: Maryland
Kevlar is strong and stretches less than polyester by volume and weight. But it generally has a shorter life when flexed.
The lack of stretch (lower modulus of elasticity) make the exact weave and layup of fibers much more important. You can end up with just a few fibers carrying the concentrated stress, with the over-stressed strands changing as the belt moves. With a fiber that stretches more the load can be spread over more strands.
#3221279 - 12/19/13 06:46 AM Re: blue Kevlar V-belts [Re: Donald]
Donald Offline
Loc: Upstate NY
OK, so nix on the blue Kevlar belts. Are replacement belts OK, or go for actual Airens belts? I do not see Gates or Dayco belts for the snowblower.
Edited by Donald (12/19/13 06:47 AM)
#3221381 - 12/19/13 08:30 AM Re: blue Kevlar V-belts [Re: Donald]
jeepman3071 Offline
Loc: Storrs, Connecticut
Go for the Ariens belt. I have had problems with aftermarket belts saying they are a certain size and they won't fit properly. Not something you want to happen with a spare belt when in a jam. Now when I replace belts on snow blowers I use an OEM belt, and have not had any more fitment issues. The OEM belts also seem to last a bit longer.
2000 Jeep Cherokee Sport 4.0L (165k) - Pennzoil HM 10w30, Napa Gold 1516, Magnefine trans filter
#3221598 - 12/19/13 12:10 PM Re: blue Kevlar V-belts [Re: Donald]
bubbatime Offline
Loc: South Florida
I work on a lot of equipment and change a lot of belts. I find that aftermarket belts can be ok, and they can be junk. Also, they sometimes are too small or too big. I price the aftermarket and factory belt. If they factory belt is much more expensive, I will give an aftermarket belt a shot. On critical equipment that I can't afford to have down, I will always go with an OEM belt,because it fits right the first time and should last a while.
10 Acura TSX 2.4L Quaker State syn 5W20 Fram Ultra
09 Chrysler Town & Country 4.0L Chevron Supreme 10W30
06 GMC Sierra 4.8L QSGB 5W30 Delco PF46
#3221902 - 12/19/13 05:17 PM Re: blue Kevlar V-belts [Re: Donald]
Cujet Offline
Loc: Jupiter, Florida
The scooter guys love the Kevlar drive belts for high performance scooters. (remember, they use a belt type CVT) Take a maxi scooter, and install a big bore kit, and some other mods and it easily overheats the OEM rubber belt.
The Kevlar ones will slip until warm on such applications. Then they work properly.
However, Kevlar is hygroscopic and will actively absorb water. In my scooter example above, the belt is well protected and runs hot. So water is generally not an issue.
Turbo's rule.
#3223467 - 12/21/13 09:23 AM Re: blue Kevlar V-belts [Re: Donald]
bchannell Offline
Loc: WV
I've found over the years that it's far better to pay the price and use the factory belts. I'm guessing the design calls for them and anything else wouldn't last as long. You might also get lucky and buy an equivalent, and it would work fine, but it's a [censored] shoot.
On my current Husqvarna tractor, cheap belts from local auto stores work good for a while, but the factory belts tend to last a lot, and I do mean a lot longer.
