Spark plug tube gaskets
by supton
05/26/16 01:22 PM
IBM System I and 8" Floppy Disks for MDS
by MolaKule
05/26/16 01:20 PM
Replacing cap bolts- bolt strength?
by ford46guy
05/26/16 12:49 PM
What's worse? Walmart or eBay direct from China?
by CharlieBauer
05/26/16 12:30 PM
When did BITOG start?
by camrydriver111
05/26/16 11:56 AM
Equipment/Calibratio
n Tracking
by racer12306
05/26/16 11:55 AM
Microgreen Oil Filter 50% Off Discount Code
by kohnen
05/26/16 11:24 AM
Mobil Delvac 1 ESP 5w-40 for 2011 TDI?
by ruleof72
05/26/16 10:49 AM
Husquvarna YTH2046 riding mower
by Donald
05/26/16 10:47 AM
Any machinists?
by NavyVet88
05/26/16 09:28 AM
new XG750R flat-tracker
by Mik
05/26/16 08:55 AM
Walmart Supertech 5w20 full synthetic $8.12
by paulswagelock
05/26/16 08:51 AM
watergate528, iamtheanimal, 1991300sl, Rdyno, Darsahn
57993 Registered Users
91 registered (340six, Alfred_B, 2015_PSD, AirgunSavant, 1JZ_E46, 440Magnum, 9 invisible), 1809 Guests and 320 Spiders online.
57993 Members
66 Forums
249432 Topics
Page 2 of 2 < 1 2
#3221100 - 12/18/13 09:37 PM Re: slight miss at idle [Re: ram_man]
Nick1994 Online   content
Loc: Phoenix, AZ
Although they are new, have you pulled the plugs to see if one is fouling or running lean from possibly a bad injector?
2000 Toyota Camry 2.2L 211k
Pennzoil Platinum HM & Fram Ultra
#3221104 - 12/18/13 09:42 PM Re: slight miss at idle [Re: ram_man]
ram_man Online   content
Loc: southern mo
They looked ok. Will pull again and gets pictures.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3221112 - 12/18/13 09:53 PM Re: slight miss at idle [Re: ram_man]
Loc: southern mo
Good thing I rechecked. They all look good and ran except that fourth plug it's solid black. So it's the fourth cylinder what do you guys think?
#3221120 - 12/18/13 09:56 PM Re: slight miss at idle [Re: ram_man]
beast3300 Offline
Loc: Ohio
Did you start this up for less than 5 minutes before removing the spark plugs? If so then it's hard to tell for sure if cyl4 isn't burning all the fuel. Is this a SOHC or DOHC 1.9?
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#3221168 - 12/18/13 11:38 PM Re: slight miss at idle [Re: ram_man]
Loc: southern mo
No it ran a good 20 mins before being parked for several hours . I pulled them out stone cold. And it's a sohc
#3221315 - 12/19/13 07:23 AM Re: slight miss at idle [Re: ram_man]
meep Offline
Loc: Southeast
i'm running in that--- over-carboned, valve getting ill, or hotspot direction ...
2006 Tundra 2wd
2002 MDX (wifey!)
2005 s60 2.4L
#3221367 - 12/19/13 08:20 AM Re: slight miss at idle [Re: meep]
Loc: southern mo
Could you elaborate as to why?
#3224106 - 12/21/13 09:11 PM Re: slight miss at idle [Re: ram_man]
redbone3 Offline
Loc: Reno, NV
I had a similar problem with my Neon.
The spark plug wires checked good and looked fine but, I changed them anyway (had 100K miles on them). That fixed my problem.
2014 Passat Wolfsburg, 1995 Miata.
Page 2 of 2 < 1 2
