How do you guys do it?
by Duffyjr
05/03/16 07:04 PM
House electrical panel buzzing
by Mr Nice
05/03/16 06:15 PM
Happy Birthday Merkava_4
by Trav
05/03/16 04:56 PM
When should you use grease with moly?
by Jetstreamz06
05/03/16 04:54 PM
VOA Motul 4100 Power 15W50
by GermanAutohaus
05/03/16 04:31 PM
Ace Hardware Pennzoil Yellow May 4th to 9th $2.99
by BigD1
05/03/16 04:23 PM
How often to get tires balanced?
by 2010Civic
05/03/16 03:17 PM
Manual says every 10 K on oil changes
by ceast
05/03/16 02:42 PM
Brake fluid ageing?
by LucasDK
05/03/16 02:39 PM
If Anybody has 60K Lying around
by GumbyJarvis
05/03/16 02:03 PM
144$ lot of 48 Fl-400s/L20195 Eq Filters
by GumbyJarvis
05/03/16 01:29 PM
AT Whine
by DWC28
05/03/16 01:14 PM
myfarmertan, coachvonyo, ionix, Amtecol, DRAX392
57779 Registered Users
102 registered (Al, 06AllAmerican, 01rangerxl, 2015_PSD, 19jacobob93, 97prizm, 11 invisible), 1893 Guests and 290 Spiders online.
57779 Members
66 Forums
248419 Topics
Page 2 of 2 < 1 2
#3219911 - 12/17/13 07:19 PM Re: Can I skip filter change? [Re: Flareside302]
Joenpb Offline
Loc: San Diego, CA
Originally Posted By: Flareside302
Man y'all are crazy.. Ain't no way if ever run more than 1 OCI on a filter..
X1000
A ton of bad advice here.
Once a filter is clogged it will go into bypass & stay in bypass without notification. Unless the filter is of the extended mileage type, do not go beyond your normal OCI. Doing so risks extra wear on the engine. If you don't want to change the oil & filter in the cold, bring the car to someone suitable for the change.
#3219995 - 12/17/13 08:42 PM Re: Can I skip filter change? [Re: Joenpb]
rrounds Offline
Loc: SACRAMENTO, CA
X1000
If you clog a oil filter up to the point of going into bypass in 15k miles, a oil filter change isn't going to fix that engine that is eating it's self to death.
I go 15k on my Honda with a Baldwin oil filter(two 7.5k mile oil change) and 20k miles(two 10k mile oil changes) on my GM 3.8L supercharged engine with over 250k miles on it.
ROD
'06 S2000
'00 SSEi sold at 252k miles
'08 Ford F53 V10
'13 Jeep Sahara 2 door
#3220084 - 12/17/13 10:41 PM Re: Can I skip filter change? [Re: ruxCYtable]
Joenpb Offline
Loc: San Diego, CA
I generally follow OEM specifications. Motorcraft filters aren't recommended for reuse. I wouldn't go for extended OCIs with a paper media filter, only with a filter that is designed to do so. The minimal cost makes changing the filter a no brainer for me. smile
#3220124 - 12/17/13 11:32 PM Re: Can I skip filter change? [Re: ruxCYtable]
Joenpb Offline
Loc: San Diego, CA
#3220128 - 12/17/13 11:34 PM Re: Can I skip filter change? [Re: Flareside302]
crazyoildude Offline
Loc: New Jersey
i always run two
In Automotive class when i was a kid i had a shop teacher that always said ..Its Nice To Be Nice! That is one thing i always remembered..
#3220504 - 12/18/13 10:08 AM Re: Can I skip filter change? [Re: Joenpb]
bubbatime Offline
Loc: South Florida
How exactly is a filter going to get clogged on a well maintained, non-sludged engine? Answer: it won't. The filter actually filters better over time. And since regular cheap filters have no problem going 20K miles on a Honda (every other 10K mile oil change), I think the idea of every other filter changes needs to be explored further.
10 Acura TSX 2.4L Quaker State syn 5W20 Fram Ultra
09 Chrysler Town & Country 4.0L Chevron Supreme 10W30
06 GMC Sierra 4.8L QSGB 5W30 Delco PF46
#3220545 - 12/18/13 10:51 AM Re: Can I skip filter change? [Re: bubbatime]
Joenpb Offline
Loc: San Diego, CA
Here at Bob is the oil guy, like politics, there are extremes. People who change filters and not oil, to peeps who change oil and not filters. If manufacturers thought a filter would provide good filtering for an extened period they would market it as so. They don't because its likely some type of problem would occur. As with many things in life moderation tends to do better over time than extremes. Its well known sludge build up occurs when oil isn't changed frequent enough. It also can occur if a filter is compromised either through blockage or torn media. Oil & filters just aren aren't expensive enough to risk sludging up an engine to go two or three times the recommended mileage.
#3220546 - 12/18/13 10:52 AM Re: Can I skip filter change? [Re: ruxCYtable]
sir1900 Offline
Loc: Regina, Saskatchewan
I think the element of fear, and fear alone, drives people to discourage changing the filter every other OCI.
Unless your engine has a history of sludge issues due to manufacturers defect or poor maintenance, there is no reason why you cannot keep the filter on for more than one OCI. There are so many options for an extended OCI -- Fram Ultra, Mobil 1, Napa Platinum, etc.
To answer the OP's question, yes, if your engine is well maintained with no issues, keep the filter on until the spring when you do your next oil change.
2015 Infiniti Q50
VWB 5W30 + CARQUEST 85358
2012 Honda Civic
QSUD 0W20 + NAPA PS 21356
2004 Accord EX V6
Castrol EDGE 0W20 + Promotive 14612
#3220761 - 12/18/13 02:34 PM Re: Can I skip filter change? [Re: sir1900]
fpracha Offline
Loc: MA
Friends have asked WHY on earth you use synthetic 0w20 and 5w20 oils, in honda civic and honda accord, when they are doing just fine with using a synthetic 5w30 in the civic and 5w40 in the accord. I told them I live in cold climate so cannot even consider using the 5w40 grade oil. But I am not sure to recommend them to switch to 0w20 or 5w20 oils in their Honda civic and Honda accord.
They are living in tropical to hot climate areas with average outside temperatures of 70-80F (near about 30 degrees Celsius average temperature).
Will it be unwise and dangerous to try using the 0w20 or 5w20 oils in these warm climates ?
Are today's modern xW-20 grade oils not stout enough to replace the 5w30 and 5w40 oils in these year-round warm climate temperatures ?
#3220944 - 12/18/13 06:52 PM Re: Can I skip filter change? [Re: fpracha]
y_p_w Offline
Loc: SF Bay Area
The cooling system regulates oil temps. While higher ambient temps will result in marginally higher oil temps, it's not really anything to be concerned. If a cooling system can't handle a certain climate, that's something that a heavier oil won't solve.
#3221006 - 12/18/13 08:03 PM Re: Can I skip filter change? [Re: ruxCYtable]
hattaresguy Offline
Loc: CT
On a clean modern engine the oil filter doesn't really do much. When they do the engine is half shot anyway.
Its cold and snowing, I'd leave the filter. Life will go on, and the sky will not fall.
#3221054 - 12/18/13 08:49 PM Re: Can I skip filter change? [Re: ruxCYtable]
Eddie Offline
Loc: Florida, Cape Coral
I think that synthetic oil and a Napa Gold filter should be good for the max recommended by your Rav4 or 10K? I would not be concerned about going out to 8,000 miles with this combo. Ed
CX5 Touring 2.5L :-)
#3225804 - 12/23/13 06:14 PM Re: Can I skip filter change? [Re: Phishin]
BlueOvalFitter Offline
Loc: Cajun Country, La.
Originally Posted By: Phishin
I'm on my 3rd 7-8k mile OCI on my Purolator Synthetic filter on my Nissan.
I think I am going to be sick!
2007 F150 XL, 4.2 V6, 4R75E Transmission
Pennzoil Platinum HM 5W30, M1-209 Oil Filter
"One Filter, One OCI!"
USA
#3225878 - 12/23/13 07:22 PM Re: Can I skip filter change? [Re: Phishin]
rrounds Offline
Loc: SACRAMENTO, CA
It would be great if you would cut it open and post the pic's when you do change that filter. I run 15k miles on my filters and they look great after 15,000 miles.
ROD
'06 S2000
'08 Ford F53 V10
Page 2 of 2 < 1 2
