Chrome polish for spoke wheels
by gman2304
07/02/16 01:52 AM
'09 Nissan Sentra-Eni i-Sint XL 4AM 5w-30-10k.
by montero1
07/02/16 01:11 AM
Questions about manual transmission sounds
by Why_Anything
07/01/16 11:09 PM
HOW to learn PINSTRIPING & lettering ??
by SumpChump
07/01/16 11:08 PM
'96 Nissan Maxima - Intake R&R - EGR tube bent
by 92saturnsl2
07/01/16 11:00 PM
Anybody want a lot of 6 Carquest Blue 84060?
by CapitalTruck
07/01/16 10:38 PM
new Tundra color
by lawnman
07/01/16 10:36 PM
Bought A Yamaha XSR900 today!
by donnyj08
07/01/16 10:21 PM
Akebono ProACT vs EBC Ultimax "Blackstuff" pads
by slacktide_bitog
07/01/16 10:08 PM
Replace oxygen sensor by mileage ?
by Merkava_4
07/01/16 10:02 PM
I was slightly wrong on the Purolator transition
by slacktide_bitog
07/01/16 09:57 PM
Things your dogs have eaten.....
by OVERKILL
07/01/16 09:45 PM
Aidil, dandandan, dbertheau, Jennyp, dcdodge
58341 Registered Users
31 registered (bobt2382, Blkstanger, bdcardinal, chrisri, 3 invisible), 861 Guests and 17 Spiders online.
58341 Members
66 Forums
251131 Topics
#3221026 - 12/18/13 08:22 PM Snowmobile 2T fuel additive
dblshock Offline
Loc: WI.
Have a couple older Yamaha sleds ('97,'02)..the redhead triple ones..anyway one backfires on a hot start the other slightly burbles thru mid-range rpm 3-5k of 8.5k I suspect the carbs, Last year ran non-ethanol 91 and Marine Stabil..these units seem to run good..I don't worry they won't start or get me home I want the carbs clean without the time, expense or aggravation of tearing them off then apart..so
What fuel additive or chemical and dose gives me the best bang to insure these carbs are clear?
TIA
06 Highlander 2.4 2WD 74k
640:1 TCW-3
5/40 Delvac 1
FPS-4386
LTX/Altimax Artic
3k mi. per month
#3221032 - 12/18/13 08:27 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
Phishin Offline
Loc: Indiana
Nothing. Cleaning them requires a bit of work. You gotta saddle up cowboy. Suck it up. Only elbow grease is gonna work. Get busy.
2010 Accord-LX K24: PU 5w30
2009 Subaru Forester 2.5X: M1 TDT
1990 Chevy K1500 350TBI: Frankenbrew
2008 Ruckus 50ccGET: M1R Mix
#3221057 - 12/18/13 08:50 PM Re: Snowmobile 2T fuel additive [Re: Phishin]
dblshock Offline
Loc: WI.
I'm willing to try a safe dose of acetone or anything prior to carb rebuild....worried about lean meltdown..12 gal tanks
Edited by dblshock (12/18/13 08:51 PM)
640:1 TCW-3
5/40 Delvac 1
FPS-4386
LTX/Altimax Artic
3k mi. per month
#3221082 - 12/18/13 09:20 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
Brybo86 Offline
Loc: Chicago, IL
I would check the mixture screws, make sure they are the same across the carbs
08 Honda Accord EX-L 2.4L RP 0w20 116k
01 Kymco People 50
95 Lexus LS400 M1 AFE 0w30 178k
95 Yamaha Jog
86 Kawasaki 454Ltd Valvoline 20w50 18k
#3221090 - 12/18/13 09:29 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
The_Eric Offline
Loc: Iowa
Usually you can get away with removing the bowls and cleaning pilot and main jets and also remove the air and/or fuel screws (if equipped) and spray in there too with spray cleaner. It's only in cases where the carbs are really gunked up that you need to completely disassemble them. Otherwise, I agree with Phishin, roll your sleeves up and dive in. The best thing you can do is make it part of your pre-season routine. I always did my carbs in late fall, just before the snow flew. They were always clean, so a rinse with spray clean and shop air kept them working perfect.
As for spray cleaner, Berryman's B12 spray cleaner is about the best I've seen so far.
2005 Lincoln Aviator 4.6 DOHC
2000 Honda Accord 2.3
2001 Hyundai Elantra 2.0
1979 Ford F-150 351M
#3221097 - 12/18/13 09:35 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
MolaKule Offline
Loc: Iowegia - USA
I would not use acetone alone as it will melt some plastics and rubber compounds.
You try this before a carb rebuild:
Berryman's Motor Tune-Up
Due to recent setbacks, my beach body will be postponed for another year. As usual, your patience is appreciated. smile
#3221132 - 12/18/13 10:10 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
MolaKule Offline
Loc: Iowegia - USA
Another fuel add that has gentle cleaning is LCD's FP PLUS.
FP PLUS
#3221840 - 12/19/13 03:57 PM Re: Snowmobile 2T fuel additive [Re: MolaKule]
dblshock Offline
Loc: WI.
I'll try this because it's $3.99 and opinions are it's stronger than SeaFoam which I already have in stock..is it normally available at major auto part stores?
640:1 TCW-3
5/40 Delvac 1
FPS-4386
LTX/Altimax Artic
3k mi. per month
#3221871 - 12/19/13 04:34 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
Ramblejam Offline
Loc: Kentucky
I take it you're looking for something that can be poured in the tank? If so:
http://www.redlineoil.com/product.aspx?pid=116&pcid=12
"Compatible with both pump gas and race fuel, pre-mixed or injected two-strokes"
This is the same thing as their SI-1 product (just a smaller bottle), which is highly regarded and well discussed on the forum here.
#3222022 - 12/19/13 07:27 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
dblshock Offline
Loc: WI.
Motorcraft Carburetor tune-up cleaner PM-3 FIR No 159220
MSDS:
https://www.fcsdchemicalsandlubricants.com/main/msds/us159220us.pdf
Directions say not to mix with fuel..please someone take a look and opine on if thats just a epa or carb regulation..I know this product works
640:1 TCW-3
5/40 Delvac 1
FPS-4386
LTX/Altimax Artic
3k mi. per month
#3223649 - 12/21/13 12:40 PM Re: Snowmobile 2T fuel additive [Re: dblshock]
dblshock Offline
Loc: WI.
MSDS:
Must be able to burn eventually if you pouring it down the carb..wonder why they advise not to add to fuel..toxic?
640:1 TCW-3
5/40 Delvac 1
FPS-4386
LTX/Altimax Artic
3k mi. per month
