MC FL-820S, 7.6K miles, 2012 F-250
by car51
07/24/16 04:41 PM
Scion tC Radiator Fan troubleshooting
by sky
07/24/16 03:59 PM
Does Americastire sell tires from the DTD list?
by zorobabel
07/24/16 03:54 PM
My $250 Saturn climbed Mt Washington
by eljefino
07/24/16 03:07 PM
Coolant change issue
by renegade_987
07/24/16 03:05 PM
Shell X100 30/40?
by FordCapriDriver
07/24/16 02:59 PM
Do you reuse ring gear bolts?
by buck91
07/24/16 02:54 PM
Wonder if anyone with NASCAR has noticed...
by mrsilv04
07/24/16 02:42 PM
Brake Pad Anti Rattle Clips
by Miller88
07/24/16 02:02 PM
Video: Napa Proselect 21334 cut open
by cronk
07/24/16 01:12 PM
what viscosity on a new build? 351W/408 street
by tomcat27
07/24/16 12:14 PM
What is this plant?
by skyactiv
07/24/16 11:16 AM
Matt_P, tpragski, 182RG, BillHuang, jwilliamson185
58578 Registered Users
91 registered (A1O, AIRJAC3, 2165, Anduril, alanwayne1908, 4WD, 7 invisible), 2006 Guests and 12 Spiders online.
58578 Members
66 Forums
252196 Topics
Page 1 of 3 1 2 3 >
#3210971 - 12/09/13 06:51 AM JP-8 in a diesel
Groundhog Offline
Loc: Wadmalaw island SC
I have learned that JP-8 can be converted for use in a Diesel engine if certain esters are added. My question is what products contain these esters? Diethyl Azelate, Diethly adipate, or bis2 ethyl- hexyl sebacate. These esters lower the wear scar value below what ULS diesel's value is. There are Some other esters as well but these stuck out at me. Any ideas?
#3210997 - 12/09/13 07:34 AM Re: JP-8 in a diesel [Re: Groundhog]
JHZR2 Offline
Loc: New Jersey
IIRC they are part of the fuel additive package. JP-8 adds can be highly toxic.
#3211210 - 12/09/13 12:31 PM Re: JP-8 in a diesel [Re: Groundhog]
SrDriver Offline
Loc: Southeast Alabama
All I know is when the switch was made from JP-5 to JP-8 in aircraft engines problems were many.
Unless you have access to free JP-8 I can't see any benefit in trying to use it in any diesel engine unless the engine is multi-fuel rated then the is no need in adding anything in that application.
Some military multi-fuel engines come to mind.
#3211500 - 12/09/13 05:04 PM Re: JP-8 in a diesel [Re: Groundhog]
Rat407 Offline
Loc: North Carolina
I ran JP-8 in my old 91 jetta diesel with no issues. Didn't run it much, just a tank full here and there so no long term effects where noted.
#3211679 - 12/09/13 08:17 PM Re: JP-8 in a diesel [Re: SrDriver]
Groundhog Offline
I did pretty much get it free, had to haul it out . I've wondered about adding 2 stroke oil like Klotz or Castrol?
#3212848 - 12/10/13 08:50 PM Re: JP-8 in a diesel [Re: Groundhog]
fdcg27 Online   content
Loc: OH
How much of this fuel did you snag?
What's wrong wih it, since normally nobody is looking to give away jet fuel?
It would probably be pretty safe to mix this with regular ULSD.
What kind of a diesel would you use it in?
I'd bet it would be just fine in an old mechanical injection engine and maybe not as great in a modern common rail one.
12 Accord LX 53K HGMO 0W-20
09 Forester 67K PU 5W-30
02 Accord 144K GOil 5W-30
01 Focus ZX3 112K M1 5W-20
95 BMW 318iC 159K Delvac 15W-40
#3214247 - 12/12/13 08:34 AM Re: JP-8 in a diesel [Re: Groundhog]
bullwinkle Online   confused
Loc: Cincinnati, OH, USA
I would run it in the old IDI diesels mixed with 50:1 two-stroke oil. The military 6.2 diesel injection pumps have hardened internal components to stand up to the "dry" fuel, I've heard of airline mechs running pumped out Jet-A with an extra fuel/water separator to remove the excess water.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3214719 - 12/12/13 05:05 PM Re: JP-8 in a diesel [Re: Groundhog]
MolaKule Offline
Loc: Iowegia - USA
Methyl soyate.
Life begins at the end of your comfort zone. smile
#3216160 - 12/14/13 03:08 AM Re: JP-8 in a diesel [Re: Groundhog]
Shannow Online   content
Loc: Oz
I'd use Rapeseed Ethyl Ester personally Mola...can make either in a coke bottle 'though.
#3217601 - 12/15/13 05:26 PM Re: JP-8 in a diesel [Re: Shannow]
MolaKule Offline
Loc: Iowegia - USA
Either Rapeseed Ethyl Ester or Methyl Soyate would be good additives. In fact, just about any veggy methyl or ethyl ester would work.
Up here in the northern hemishpere, soybean esters seem to dominate as an additive for the medium distillates.
FOr JP-8, I think about 15% by volume of a veggy ester would be sufficient.
Edited by MolaKule (12/15/13 05:26 PM)
#3218051 - 12/16/13 03:03 AM Re: JP-8 in a diesel [Re: Groundhog]
Loc: Oz
Sorry Mola, was trying (unsuccessfully) to be humerous...
Interesting to see who's lobby groups get what through, as your biodiesel specs pretty much make soy oil the only primary contender...ours make conola the preferred feedstock. Use anything else, and there's something that needs modifying to get it right.
I made a quart in a bottle at work some many moons ago while presenting at a meeting on sustainability...simple stuff, but it made an impact.
Premium diesel usually has 2% RME in it around here.
#3220974 - 12/18/13 07:27 PM Re: JP-8 in a diesel [Re: fdcg27]
Groundhog Offline
Well about 1k gals. It was used at an engine plant and was considered waste. So being on a farm and not highway use I just had to haul it away. Now I'm all over the road with what to add.
As far as engines I've got everything from a single cyl diesel 8000 hrs pump to an 7430 John Deere.
JD is CR but my others are not
Maybe a dumb question but isn't rapeseed oil same as canola?
#3221016 - 12/18/13 08:17 PM Re: JP-8 in a diesel [Re: Groundhog]
Loc: Oz
Sort of...Conola is a modified rapeseed, and is typically the "R" in Australian biodiesel.
#3224343 - 12/22/13 07:35 AM Re: JP-8 in a diesel [Re: Groundhog]
Loc: OH
A thousand gallons for the cost of hauling it off?
Great score!
It might be best not to use it in the CR Deere, but I'd bet that the mechanical IDI engines wouldn't much care.
To Mola and Shannow, what would be a good commercial source for a methyl or ethyl ester to blend with this fuel?
Canola or soybean oil off the grocer's shelf?
#3224463 - 12/22/13 09:16 AM Re: JP-8 in a diesel [Re: Groundhog]
Loc: Oz
Anywhere that sells 100% biodiesel...as long as it's pure and clean.
Page 1 of 3 1 2 3 >
