2008 F150 2wd Lariat crew cab tire thoughts
by George Bynum
06/26/16 07:10 AM
New Supertech jugs?
by dlundblad
06/26/16 06:16 AM
Fram ph3657 cut open
by jhellwig
06/26/16 05:07 AM
Don't discount coal for a long while yet...
by Shannow
06/26/16 03:10 AM
Decent Wireless Computer Headset?
by 99Saturn
06/25/16 11:41 PM
Need Fuel Pump Assembly for Camry
by Nick1994
06/25/16 11:36 PM
2015 Accord V6 VCM engine UOA 36,680 mi / 9812 OCI
by TNM1982
06/25/16 10:55 PM
Why did Toyota recommend a winter and summer oil?
by BrianApp
06/25/16 10:00 PM
Fram TG 7317 6k miles
by bbhero
06/25/16 09:57 PM
Sta-Lube Moly-Graph Grease
by JHZR2
06/25/16 09:20 PM
Dead battery locks me out of Altima!
by Tom NJ
06/25/16 08:56 PM
Second lawn mower blade
by greasegunn
06/25/16 08:11 PM
paul2005tb, Martyaus, carmelo, Shellman, SSO
58272 Registered Users
73 registered (Bandito440, beanoil, 123Saab, A310, AandPDan, alcyon, 10 invisible), 1536 Guests and 12 Spiders online.
58272 Members
66 Forums
250823 Topics
#3219303 - 12/17/13 08:29 AM CV joint grease - which one in general
MAHLE_Collector Offline
Loc: Hungary
I could not find any informative topic in this case. I would like to know what are the requirments in this section. No I'm not happy with the answer 'go and buy the satchet stuff in a parts store'.
What are the basics regarding viscosity, additives, base oils etc?
To begin with here is a leaflet. Which one would You suggest?
My Unit Is Metric
#3219398 - 12/17/13 09:34 AM Re: CV joint grease - which one in general [Re: MAHLE_Collector]
Dufus2 Offline
Loc: Virginia
I usually buy the stuff sold for that application, its slimy and some type of synthetic.
I sell Amsoil and their Racing Grease is acceptable but I do not know what is required as this is a fill-for-life grease.
The grease needs to be soft and still protect under heavy loads.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#3219633 - 12/17/13 12:56 PM Re: CV joint grease - which one in general [Re: MAHLE_Collector]
Quest Offline
Loc: beaver land EH?
Going through that link, the closest one I see that "may" fit your bill would be Multis MS2.
Again, this is just a close call, with no factory supplementary notes or application-specific sheets to reference to.
While the outside Rzeppa joint doesn't require much other than high-pressure (shock proof) with moly (common practice RE: CV grease), the other concern would be the proper grease to be used on the inside joint (Tripod joint) where in addition to friction reduction, shocks, high temp, it has to "slide" as well due to the nature of the joint design).
I have been using those black CV grease pouch that came with aftermarket CV boots for over 20 yrs now, no issues with them that I'm aware of.
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3220183 - 12/18/13 01:11 AM Re: CV joint grease - which one in general [Re: MAHLE_Collector]
default Offline
Loc: Michigan
The tripod joint isn't very demanding for lubrication, Fiat invented the modern FWD setup and ran the tripod in the trans oil, which was straight 90wt GL3.
#3220237 - 12/18/13 05:30 AM Re: CV joint grease - which one in general [Re: default]
Rollins Offline
Loc: Europe
Edited by Rollins (12/18/13 05:31 AM)
#3220984 - 12/18/13 07:38 PM Re: CV joint grease - which one in general [Re: MAHLE_Collector]
artificialist Offline
Loc: Florida
Valvoline Durablend states that it is suitable for CV joints. Since it is only 6-7 dollars for a standard size grease gun tube, I would choose Valvoline Durablend.
Valvoline Synpower might also be suitable, I never looked because Durablend already exceeds the minimum requirements for practically every car I work on.
It seems like all CV greases recommend have large amounts of moly.
2010 Lancer Ralliart Sportback
