Looking for info on two quick spray waxes.........
by demarpaint
05/01/16 04:43 AM
The Heroin Epidemic In The U.S....
by qwerty1234
05/01/16 01:28 AM
Air filter wrap
by Duffyjr
04/30/16 10:21 PM
15W-40 Delo, Delvac or Rotella For KUBOTA turbo
by pburchett
04/30/16 09:50 PM
Traveler synthetic oil a slow seller?
by Electromotive
04/30/16 09:34 PM
Tyre rubber, methanol, and bore wear
by Shannow
04/30/16 09:34 PM
What to use in 99 Buick Lesabre OCI?
by Duffyjr
04/30/16 09:26 PM
Help w/Transmission Drain/Fill 08 Honda CR-V 4wd
by klt1986
04/30/16 08:58 PM
pennzoil ultra platinum pure plus
by Brayden
04/30/16 08:10 PM
Group 5 synthetic oil
by Brayden
04/30/16 08:07 PM
Pennzoil Ultra platinum at Walmart
by RubentheIowan
04/30/16 08:03 PM
G-05 Change intervals, 3 or 5 years?
by Canadastang
04/30/16 08:03 PM
Doxxy, Jetstreamz06, TalNum, Spinnizle, JustinL
57758 Registered Users
16 registered (Bookmaker, eddy21, bmod305, billt460, FFeng7, 1 invisible), 620 Guests and 119 Spiders online.
57758 Members
66 Forums
248282 Topics
#3216296 - 12/14/13 09:06 AM Coolant for 1994 Accord LX
imcharlescee Offline
Loc: canada
Canadian here, looking for a good coolant for my 1994 Accord. My thermostat just got messed up and I believe it is stuck open since my temp. gauge stays on cool but climbs to normal during idle then goes back down when I'm in high speeds. I guess I might as well replace the coolant. Any suggestions?
#3216344 - 12/14/13 10:22 AM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
ram_man Offline
Loc: southern mo
Zerex Asian formula.
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3216364 - 12/14/13 10:56 AM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
05LGTLtd Offline
Loc: Va
Or Peak Global
2005 Legacy GT, Synpower 5w-40
2010 Forester SOHC, Edge 0w-30
#3216376 - 12/14/13 11:18 AM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
bullwinkle Offline
Loc: Cincinnati, OH, USA
'94 Honda is old enough that you can run old school green or pretty much anything you want. Try to flush out as much as possible, though-that's what seems to mess up my thermostats.
06 Ram 3500 CTD 4X4(FG Venturi), 93 GMC C3500 6.2, 89 F-450 7.3, 98 XJ 4.0(XG8A), 05 xB(XG3600), 15 Transit 3.7, 03 Merc Grand Marquis 4.6 2V(CQ Blue)
#3216490 - 12/14/13 01:20 PM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
Loc: canada
Will prestone do the trick?
#3216613 - 12/14/13 03:44 PM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
Tanama Offline
Loc: KY, USA
Yes, Prestone will do the trick. However, it contains 2EHA. I have not seen a formal release, but some say Honda does not endorse said acid in its engines. Actually, any good coolant will do the trick, as long as you change it frequently enough. Checking your engine ground cables and battery negative wire will also help.
Edited by Tanama (12/14/13 03:45 PM)
#3218827 - 12/16/13 06:11 PM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
artificialist Offline
Loc: Florida
Conventional green destroyed the water pump on my dad's '95 Accord, and the '94 Accord is very similar. I would use Zerex Asian, Beck/Arnley green, or OEM Honda coolant only.
2010 Lancer Ralliart Sportback
#3219516 - 12/17/13 11:20 AM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
Loc: canada
hey guys, so I went to walmart and looked for zerex asian but they didnt have any. I found prestone and STP Asian.... which one should I buy?
#3220978 - 12/18/13 07:32 PM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
Loc: Florida
Since STP Asian is a hybrid OAT coolant, I would choose STP.
Prestone is an OAT coolant, so it doesn't have the same inhibitors as STP or the OEM coolant.
I'm glad to see more Asian vehicle coolants out there. Why so many cars can be on our roads, and yet have so few coolants that match OEM really surprises me.
#3221603 - 12/19/13 12:19 PM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
Wilhelm_D Offline
Loc: Tacoma, WA
Neither.
The STP Asian is made by Recochem and is a premix - water and coolant in a 50/50 solution. If you're doing a complete flush and change, you won't be able to get a 50/50 mix with it since there is always a bit of water left after the flush.
Prestone contains 2-EHA, a plasticizer. I tried it some years ago in a 1990 Civic with very bad results vis a vis the gaskets.
Go with any of the OEM Asian coolants or G-05 (Mercedes, Chrysler, and Ford have used it).
#3231828 - 12/30/13 12:12 PM Re: Coolant for 1994 Accord LX [Re: imcharlescee]
SOHCman Offline
Loc: USA
I already have toyota factory red coolant on hand for two of my other vehicles, so i started using it in my 94 accord with no ill effects. Plus its a concentrate which i like and mix it with distilled water.
Its a phosphate coolant ( organic ) and you dont have to worry about e2ha junk.
Do or do not, there is no try. USA
