Brake Pad Shims a MUST?
by SavagePatch
08/28/16 01:34 AM
Bean Counters vs Swedish Engineering
by Y_K
08/28/16 12:04 AM
Interesting website for comparing guns
by 901Memphis
08/27/16 11:45 PM
Android clear cached data
by expat
08/27/16 11:07 PM
Worm gear vs spring type hose clamps?
by TheLoneRanger
08/27/16 10:35 PM
Factory fog lights...common wiring and wattage?
by ryan2022
08/27/16 10:32 PM
2 Hyundai/Kia OEM Filters cut open
by KD0AXS
08/27/16 10:30 PM
Preferred SUV for snow: Large FWD or smaller AWD?
by Carbon12
08/27/16 09:55 PM
Chevron 5W-20 $10/5-quart at WM
by wgtoys
08/27/16 09:15 PM
Best alternative to FL500S
by buck91
08/27/16 09:11 PM
New router?
by Quattro Pete
08/27/16 08:44 PM
MPV 7100 Hybrid Mower
by spk2000
08/27/16 08:17 PM
DALpilotMike, Safetyfirst, rwood, USARMOR, GV00
58943 Registered Users
20 registered (Bandito440, dec219644, berniedd, dccode, 3 invisible), 692 Guests and 34 Spiders online.
58943 Members
66 Forums
253657 Topics
Page 2 of 2 < 1 2
#3220605 - 12/18/13 11:56 AM Re: Harley-Davidson FXSTS 1992 valvetrain picture [Re: Finn]
skully Offline
Loc: NYS
looks good, post pics when done. about the front end, its not a clunk, its like a goove/notch that will lock the front end forward. if you can swing the bars left-right, back and forth and not feel them wanting to lock into one position, then your good, if the want to go to one spot all the time, without any fallaway then you have pooched bearings, that can be very unsafe. this all is done with the bike on a stand, but then again, your old so you'll never be at any hi-speed...lol.
to the other poster, the springer and my fxlr are my favorite bikes to ride, i will and always have had a springer
#3220642 - 12/18/13 12:33 PM Re: Harley-Davidson FXSTS 1992 valvetrain picture [Re: Finn]
Finn Offline
Loc: Finland
I do use 3rd gear every now and then. grin
We'll check the front end for abnormalities.
2006 Skoda Octavia Estate 1.9 TDI PD | 1991 Lexus LS400 | 2000 Audi TT quattro 225 hp | 1978 Corvette 427" | 1986 Corvette 383" | 2003 FLHR
#3220895 - 12/18/13 05:33 PM Re: Harley-Davidson FXSTS 1992 valvetrain picture [Re: Finn]
flstffxe Offline
Loc: MN, USA
Originally Posted By: Finn
Originally Posted By: skully
i would not shave heads, no need to with that camshaft, its a bolt in camshaft. .....
Well, 9.25:1 is Andrews' recommendation so that needs a bit of shaving. Would work OK with stock 8.5:1 I guess but if that's what they recommend that's what we'll do. The valves/seats get machined anyway so shaving the heads is not much extra work.
I have to agree, I would not be shaving the heads any more than cleaning them up.
I may be missing it but I don't see anywhere Andrews specs 9.25:1 for the EV13.
Andrews EV13 description from their catalog.
Quote:
Bolt-in street/touring cam for heavy bikes. Much more
low and mid-range power than either stock cam. Best
cam for 2 up riding with camping gear and side cars.
Most street engines have the best power output(are most efficient) with a dynamic compression of 7.5-8.5:1. With out having actual CC volumes and measurements of your parts my quick calculations are as follows. Using a stock 3.498" bore, 4.250 stroke, and a ball parked 7.4375/7.440 rod length with the given static compressions.
With static compression set at 9.25:1. The EV13 with a 31 intake valve close puts the dynamic compression up at around 8.8 to 8.85:1.
If not set up properly this is a recipe that can provide favorable conditions for pinging/detonation as it may run hot. Requiring you to pull back the timing to control engine temps and detonation, thus cutting power. Or make you one of those guys who is always on the hunt for "good gas".
With the factory 8.5:1 static compression, I work it out to be around 8.0 to 8.1:1 dynamic compression. Putting it right in the sweet spot for trouble free operation. Which may allow you to start with more timing and add timing more aggressively, thus building power sooner and higher peak numbers VS the 9.25:1 static compression combination that could be a troublesome.
Again these are just quick calculations, but are enough that to me, I would question the changing of the compression, the rest of the setup(head/ piston cc, valve/port flow, exhaust) and or the choice of cam.
#3220947 - 12/18/13 06:56 PM Re: Harley-Davidson FXSTS 1992 valvetrain picture [Re: flstffxe]
skully Offline
Loc: NYS
omg...not third??..lol. all kiddin aside, whatever you do to the gearside of the motor is up to you, make sure you use the steel breather, plastic is not supposed to be in an engine. make sure that the neck bearings are good. have fun
flstffxe, i was gonna get into it but because its a oil forum really and finn seemed convinced, i wasnt gonna get in depth as you did, absolutely correct what you said in your post!!! with today gas, stock compression for a daily reliable driver is plenty and for the setup that Finn is working to achieve. so be it, its gonna happen anyways. Finn just make sure those neck bearings are in good shape!! enjoy the winter boys, its gonna be a long one.
Page 2 of 2 < 1 2
