Ever have an "old guy" day?
by daves87rs
02/08/16 10:25 PM
Fram Ultra C$11.87 (Ontario)
by dgunay
02/08/16 10:16 PM
dodge 4.7 fram problem?
by joel95ex
02/08/16 09:45 PM
ok until oil change 4.7 dodge
by joel95ex
02/08/16 09:41 PM
0w20 vs 5w20 running on a Mazda 3 2014
by Stewie
02/08/16 09:37 PM
5w20/30 4.4L Castrol Edge WM Canada $24.88
by Stewie
02/08/16 09:31 PM
Back to greasing stuff...
by JHZR2
02/08/16 09:04 PM
Castrol Import Multi question
by Carguy21
02/08/16 08:20 PM
2005 F150 steering rack
by Colt45ws
02/08/16 08:12 PM
Tinkering around today with my Cold Air Intake
by GumbyJarvis
02/08/16 07:51 PM
Crude Oil at Historic Lows and 5W30 is High Priced
by cjcride
02/08/16 07:35 PM
2014 f150 coolant
by robo339
02/08/16 07:27 PM
paulp, ATLjunkcars, jqgz, ukpdxwrx, TerrenceRocks
56865 Registered Users
57 registered (askani79705, akela, 901Memphis, 01_celica_gt, 90crvtec, ammolab, 4 invisible), 878 Guests and 218 Spiders online.
56865 Members
66 Forums
244432 Topics
Page 1 of 2 1 2 >
#3220933 - 12/18/13 06:28 PM slight miss at idle
ram_man Offline
Loc: southern mo
Ive been getting inconsistent fuel mileage in the saturn and exhaust pop at idle fairly often was tuned up 2000 miles ago. Wires tested good, coils are good, no cel. Intake gasket and vac lines are good. O2 sensor seems to be switching pretty good. I cleaned the throttle body no change. Spark plugs looks good to. Egr is clean to. I drive the same route everyday and last time I got 36mpg this time 31..... same station and pump to. What else toncheck
Edited by ram_man (12/18/13 06:29 PM)
2015 dodge dart se rallye package
1995 Dodge ram 1500 5.9l
2003 chrysler pt cruiser
#3220935 - 12/18/13 06:34 PM Re: slight miss at idle [Re: ram_man]
brandini Offline
Loc: Richmond, VA
Winter gas?
07 Mazda3s Hatch - ZoomZoom - Using EAO-ALM-BF3-MTG-ANT-ATF
#3220948 - 12/18/13 06:56 PM Re: slight miss at idle [Re: brandini]
ram_man Offline
Loc: southern mo
Originally Posted By: brandini
Winter gas?
ehh that wouldnt cause the little miss at idle though. And the gas mileage varies from tank to tank. It was 32 then 36 now 31 and this tank is right around 29.its getting worse,
Edited by ram_man (12/18/13 06:59 PM)
#3220952 - 12/18/13 07:01 PM Re: slight miss at idle [Re: ram_man]
Eddie Offline
Loc: Florida, Cape Coral
Sticking exhaust valve?
CX5 Touring 2.5L :-)
#3220964 - 12/18/13 07:17 PM Re: slight miss at idle [Re: ram_man]
ram_man Offline
Loc: southern mo
Engine has been very well maintained. And runs good while drivimg.
#3220971 - 12/18/13 07:23 PM Re: slight miss at idle [Re: ram_man]
c502cid Offline
Loc: Elizabeth. Colorado
Even though I would have guessed a dirty throttle body I see you tried that. I'd get the exhaust analyzed and see what the readings are, might tell you a bunch. O2 sensors get lazy as they age.
15 Chevy Trax AWD
10 Dodge 1500 5.7 hemi
02 GMC 3500 4x4 8.1/Allison
00 Chev Blazer 4.3
84 Chev K30 454 EFI
71 GMC Jimmy 502 RamJet
#3220988 - 12/18/13 07:48 PM Re: slight miss at idle [Re: ram_man]
beast3300 Offline
Loc: Ohio
What kind of spark plugs are in it?
'03 Regal GS L67 3.29 GR:, PUP 5w30/TG3980, Filtermag
'99 Grand Prix L36: QS Defy 5w30/TG3387A, Filtermag
#3220991 - 12/18/13 07:49 PM Re: slight miss at idle [Re: ram_man]
Cujet Offline
Loc: Jupiter, Florida
Could be a dirty injector. I've had luck with Chevron Techron in the fuel. Believe it or not, MMO in the fuel might help too (but I did not say that) smile
However, as engines age, compression changes, valves don't seal as well, injectors don't spray as cleanly and so on. It all adds up to a slightly rough idle.
Turbo's rule.
#3220996 - 12/18/13 07:53 PM Re: slight miss at idle [Re: Cujet]
ram_man Offline
Loc: southern mo
ngk copper plugs.
Its got 123,000 miles.
#3221003 - 12/18/13 08:01 PM Re: slight miss at idle [Re: ram_man]
beast3300 Offline
Loc: Ohio
ngk copper plugs.
Gapped at .040?
#3221029 - 12/18/13 08:26 PM Re: slight miss at idle [Re: ram_man]
artificialist Offline
Loc: Florida
Many Saturns of that time had failure prone coolant temperature sensors. Sometime one sensor was connected to your gauges, and another one connected to your ECU. This could make you think that your sensors are fine when they aren't.
Such sensors aren't expensive, thankfully.
2010 Lancer Ralliart Sportback
#3221031 - 12/18/13 08:27 PM Re: slight miss at idle [Re: beast3300]
ram_man Offline
Loc: southern mo
ngk copper plugs.
Gapped at .040?
Yes I believe that's what it is specd for. Double checked it
#3221033 - 12/18/13 08:28 PM Re: slight miss at idle [Re: artificialist]
ram_man Offline
Loc: southern mo
mine has one ects. Its the metal sensor
#3221049 - 12/18/13 08:44 PM Re: slight miss at idle [Re: ram_man]
99Saturn Offline
Loc: NY
Ignition control module maybe. Probably some cheaper things to try first.
#3221062 - 12/18/13 08:54 PM Re: slight miss at idle [Re: 99Saturn]
ram_man Offline
Loc: southern mo
it has been replaced by the original owner. Not long before I bought it.
Page 1 of 2 1 2 >
