JHZR2
Staff member
Originally Posted By: djb
From the description it sounds as if the car cranked fine, but then wouldn't continue to run.
That doesn't necessarily suggest a battery problem. It suggests a fuel atomization problem or a spark problem. If your injectors are producing a irregular stream rather than a fine mist you'll have a combustion problem that is only obvious during cold weather.
I agree. The battery is suspect for other reasons, since we dont know the age, where it was used before that, if its rating is correct, etc. But this doesnt sound like a battery issue.
Given that its winter, I would either replace it with an autocraft silver from AAP (using a coupon to take the price down), or a Kikland from costco which tends to be a few dollars less for a good battery. Otherwise at minimum Id put the car on a good quality battery charger and ensure that it is topped up.
