Kawasaki must be completely full of gas to start
by jrcowboys
16 minutes 34 seconds ago
Un-Screwing
by Ducked
47 minutes 58 seconds ago
BG 109 vs 120, any techs experienced w/ both?
by dccode
Today at 08:24 PM
Harder on engine, idling or restart?
by mattri
Today at 08:20 PM
Solvent/cleaner + 2 stroke oil for piston soak
by OldEuroCarLover
Today at 08:09 PM
Costco Canada Michelin wiper blades $9.99
by JC1
Today at 06:47 PM
Havoline Car Giveaway
by SatinSilver
Today at 06:47 PM
Opinions please
by ceast
Today at 06:41 PM
UOA, Pennzoil Platinum 5W30, 15K KM, 10 months
by ST2008
Today at 06:19 PM
Cruise control going downhill
by Donald
Today at 05:58 PM
O'REILLY SYNTHETIC OIL
by dooscoop32
Today at 05:10 PM
Anyone here a ice road truckee?
by car51
Today at 04:42 PM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
86 registered (AirgunSavant, barkingspider, 4WD, 9C1_guy, 2015_PSD, Bandito440, 6 invisible), 1351 Guests and 35 Spiders online.
58935 Members
66 Forums
253600 Topics
#3219732 - 12/17/13 02:56 PM What oil would an engine like this use?
Olas Offline
Loc: Manchester, England
Its a VW 2.0 litre 16 valve, 58psi boost at circa 1000 hp - I watched the clip on youtube and first thing I thought was "I wonder what oil he uses in that thing" like what could withstan the blowby and the heat and the shear from that much pressure an temperature.. Would Redline's 70wt nitro drag oil be under/over spec?
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3219784 - 12/17/13 04:06 PM Re: What oil would an engine like this use? [Re: Olas]
BobsArmory Offline
Loc: Michigan
Youtube link?
Keeping the forces of evil at bay
2016 Chevy Malibu
2009 Chevy Silverado
#3219827 - 12/17/13 05:42 PM Re: What oil would an engine like this use? [Re: Olas]
CHARLIEBRONSON21 Offline
Loc: MEMPHIS, TN
What kind of use? If it's drag car I'd bet 0W2 or 0W3... Track racing... Probably 50/60 weight.
'13 Fusion Hybrid: 5w20 PUP/FU
'15 Civic Si: 0W20 PPPP/FU
'16 Fusion Hybrid: FF
'14 Odyssey: 0w20 PUP/FU
'93 Civic: 5W30 M1/TG
'99 SVT Cobra: 5W30 M1/FU
#3219862 - 12/17/13 06:33 PM Re: What oil would an engine like this use? [Re: Olas]
Olas Offline
I forgot the link..
http://www.youtube.com/watch?v=dElFiQcLsp8
Guy by the name of Boba, has a reputation for builing very high PSI stuff - one of those 'if only I had the money' kind of dreams.
1982 VW Scirocco
1457cc
98 bhp
78000 miles
Redline fluids
Mann/Mahle filters
#3220672 - 12/18/13 01:05 PM Re: What oil would an engine like this use? [Re: Olas]
Finn Offline
Loc: Finland
I asked the guy about the oil/oil pressure. Lets see if he has time to reply.
2006 Skoda Octavia Estate 1.9 TDI PD | 1991 Lexus LS400 | 2000 Audi TT quattro 225 hp | 1978 Corvette 427" | 1986 Corvette 383" | 2003 FLHR
#3220701 - 12/18/13 01:29 PM Re: What oil would an engine like this use? [Re: Finn]
Finn Offline
Loc: Finland
And he replied:
"Shell 10W60 stock ABF oilpump"
Must be the Shell Ultra Racing 10W-60.
#3223071 - 12/20/13 07:42 PM Re: What oil would an engine like this use? [Re: Olas]
A_Harman Offline
Loc: Michigan
Is it for drag racing or road racing? 58 psi is the kind of boost they used to run in F1 1.5L qualifying engines.
Redline's 70WT Nitro oil would probably be overkill for that engine. Nitro engines have to deal with a lot of fuel dilution.
OK, I watched the video. It's a street car, and it looks like it could be run on a track, but they were only going through the gears during the video. What a wanton display of excess Horsepower. I love it. The thing I noticed was the turbo wouldn't spool until the engine got to 5400 rpm, so it would have nothing down low.
Edited by A_Harman (12/20/13 07:51 PM)
1985 Z51 Corvette track car
2002 Camaro Z28 LS1/6-speed
2001 Dodge Ram 2500 diesel
1972 GMC 1500 shortbed project truck
#3223842 - 12/21/13 03:46 PM Re: What oil would an engine like this use? [Re: A_Harman]
dailydriver Offline
Loc: Bucks County, Pa.
I guess you didn't know that EVERY bone stock, untouched, 2JZ-GTE can handle that kind of boost on 91 pump gas? crackmeup
2000 Z28 1SC 6 speed 180K miles
4L Motul 300V 0W-40, 2L Motul 300V 0W-20
M1-206 oil filter
Motul Gear 300 75W-90
Red Line D4/MTL in the T56
#3237492 - 01/04/14 06:34 PM Re: What oil would an engine like this use? [Re: Olas]
CATERHAM Offline
Loc: Burlington, Ontario, Canada
Not enough info'
Like every engine it depends on maximum oil temp's.
Then you want the oil to be light enough for the oil pump to be out of by-pass at high rev's.
The 10W-60 will likely be too heavy unless oil temp's are exceeding 120C.
74 Lotus Europa, 5W-50
86 Porsche 928S, TGMO 0W-20 25% / M1 0W-40 75%
96 BMW 328i, Idemitsu/TGMO 0W-20 70% / M1 0W-40 30%
94 Caterham 7, FUCHS 0W-20
#3237517 - 01/04/14 06:53 PM Re: What oil would an engine like this use? [Re: Olas]
Shannow Offline
Loc: Oz
being out of OP relief does not ensure that the oil film thickness in the bearing is up to the requirements for the load applied to it
#3237546 - 01/04/14 07:14 PM Re: What oil would an engine like this use? [Re: Shannow]
CATERHAM Offline
If it doesn't then the maximum relief pressure setting will have to be raised.
