Originally Posted By: outoforder
What is the shelf life of this additive?
The stuff is pretty much no good even on day 1.
^^This^^. But really, if you cars engine is so bad that you need to use it in the first place, who cares if its expired. Im not sure how long its good though.
My car is running fine. I found the Lucas Oil while cleaning out the garage and figured the easiest way to dispose of it was to run it through my car. Suppose I could just add it to waste oil containers and send it to the recycle center.
I read an article at edmonds that says the days of the 'Thick' additives are gone and these companies that promote such products are far behind with the current technology.
Small amounts would be OK to use but 20% will give you more headaches than you need. I tried the stuff once and dropped the oil 100 miles later LOLZ
