Its a VW 2.0 litre 16 valve, 58psi boost at circa 1000 hp - I watched the clip on youtube and first thing I thought was "I wonder what oil he uses in that thing" like what could withstan the blowby and the heat and the shear from that much pressure an temperature.. Would Redline's 70wt nitro drag oil be under/over spec?
