Car&Driver opinion on Toyota weird styling
by HTSS_TR
42 minutes 23 seconds ago
Old house woes
by OVERKILL
48 minutes 38 seconds ago
Toyota Factory Fill???
by Doog
Today at 05:43 PM
Time to Replace?
by GMFan
Today at 05:20 PM
typical "life" of differential oil?
by TexasTea
Today at 04:22 PM
MaxLife Semi Syn 5w-20 vs Castrol HM
by dpaldino
Today at 04:10 PM
Vehicles with American contends are shrinking !
by HTSS_TR
Today at 04:03 PM
Anybody use Shell Rotella T1 SAE 40 in boats?
by Bgallagher
Today at 03:00 PM
"Scrub Radius"
by George Bynum
Today at 02:36 PM
Any Subaru gurus here? EJ25 DOHC vague knock
by Why_Anything
Today at 02:31 PM
Erdogan apologizes to Russia
by Jetronic
Today at 02:28 PM
Terrible accident in So Cal last night.
by HTSS_TR
Today at 01:30 PM
jameson223, graywolf001, Likeapogi, 40fordcoupe, stickrpg23
58319 Registered Users
87 registered (2002 Maxima SE, 2015_PSD, 01rangerxl, AirgunSavant, 2004tdigls, 5 invisible), 1875 Guests and 13 Spiders online.
58319 Members
66 Forums
250995 Topics
#3217247 - 12/15/13 10:43 AM I need a fast Hydraulic Fluid answer!
79sunrunner Offline
Loc: Illinois, USA
My friend owns a 2000 New Holland LW190. In the summer in a desperate financial scare, he sprung a leak and couldn't afford the repair bill until Fall, so he filled the machine up with the thick Shield 303. Now the machine is used for pushing snow with a snow box. The implements are barely used until he goes to load a salt truck. The issue is, the very thick Shield 303 tractor hydraulic fluid was left in it, and raising the bucket is almost impossible even after the machine is as warm as it can get, in this 0-15*F climate.
Our question is, is there an additive that can be used to thin this stuff down (that is gasket and seal safe), or are we going to have to drain it and fill it up with the proper grade? Since it is 15*F today, we are seriously trying to avoid working outside as much as possible, and unfortunately there is no garage to work in.
My idea was to drain most of it out, and fill it up with very thin oil, which will mix with the residual thick oil, and mix it to a manageable grade.
any suggestions welcome.
Edited by 79sunrunner (12/15/13 10:52 AM)
2013 Fiat 500T PU 5/40
'79 MG Midget SunRunner 20/50 GTX (winner of TopGears Rate Your Ride)
And many more leaky British cars!
#3217260 - 12/15/13 10:59 AM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
eljefino Online   content
Loc: ME
Just put the right stuff in. It'll be mostly that.
#3217265 - 12/15/13 11:05 AM Re: I need a fast Hydraulic Fluid answer! [Re: eljefino]
DoiInthanon Offline
Loc: Missouri
+1 The spec fluid will do the trick even if more of the stiffer fluid remains than you would want.
Respectfully, Jim
#3217276 - 12/15/13 11:16 AM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
Rand Offline
Loc: NE,Ohio
ugh that stuff is junk.
anytime it has a disclaimer that says
Quote:
"when a product of this quality is recommended"
its also anemic on the additive side and carries this disclaimer
Quote:
Misapplication may cause severe performance problems.
303 Tractor Hydraulic Fluid has not been recommended by
any manufacturer since 1977
303 fluid I believe was a spec from the 70's they list a bunch of manufacturers but it was for their equipment from that time period.
http://images.peakauto.com/303_specs.pdf
for more details, vi of... 61 POUR POINT of 0F
Edited by Rand (12/15/13 11:20 AM)
2015 Forester I-Premium 6MT
#3217284 - 12/15/13 11:23 AM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
daman Offline
Loc: Bad Axe, MI
How much does the system hold? dump that 303 [censored] and pour some JD high-guard low viscosity in, you'll be good to go.
"Always"....Mobil 1
Current fill: AFE 0w30
#3217313 - 12/15/13 11:53 AM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
Barkleymut Offline
Loc: Richmond, VA
Another vote for draining it and replacing with the correct stuff. Even if is cold as heck, it should drain ok. Personally I would run it after the first drain/fill for a couple of hours then drain fill it again. Depending on what % of the fill comes out you may have most of the junk out by the second change. And I bet it runs way better.
09 Vue(95K) 2.4 4spd AT -PU 5w30 / 09 Flex(52K)3.5L PU / Moms car 04 Pilot(105K) 5w20 PP + Puro
#3217320 - 12/15/13 11:56 AM Re: I need a fast Hydraulic Fluid answer! [Re: daman]
79sunrunner Offline
Loc: Illinois, USA
It holds ~25 gallons
#3217328 - 12/15/13 11:59 AM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
79sunrunner Offline
Loc: Illinois, USA
I understand the complaints against 303. But this man is believer in anything cheap or free. He changed the oil in his truck yesterday, and got 5 quarts of 20w/50 Castrol for free. I mentioned it might be a little thick for winter, and he said back "It doesnt matter what the numbers say, all that matters is that its Castrol" (facepalm)
Anyway, thanks everyone for the advice, I'll try to convince him into buying the proper stuff.
#3217331 - 12/15/13 12:03 PM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
daman Offline
Loc: Bad Axe, MI
It sounds like his reasoning is flawed and he's on the path of making things worse not better. Drain and refill with better fluid and call it a day.
"Always"....Mobil 1
#3217402 - 12/15/13 01:16 PM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
Chris142 Offline
Loc: apple valley, ca
Put the cotrect fluid in it. Make sure that the filter is clean. If the filter is plugged they wont lift.
02 Wrangler super-s 10w30
87 F250 delo 15w40
04 Tahoe super-s 5w30
Z400 Lucas 10w30
KLR250 Maxima 10w40
Can am maveric delo 5w40
#3217490 - 12/15/13 03:23 PM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
Texan4Life Offline
Loc: Texas
wash your hands and walk away... some people you cant help.
2005 Dodge Ram 1500, 5.7L
[Current Fill: PP 0w-20][Baldwin B2-HPG]
#3217505 - 12/15/13 03:41 PM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
volk06 Offline
Loc: Iowa
How does this 303 fluid compare to the stuff he used? We still use this in our older farm equipment, pre-1977. This milemaster (citgo) looks a heck of a lot better than that shield stuff.
http://docs.milemasterlubricants.com/msds_pi/MM3004.pdf
2011 F-150 Ecoboost
2012 Focus S
2001 Taurus
#3218701 - 12/16/13 04:08 PM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
Rand Offline
Loc: NE,Ohio
it depends on if its cheap 303 fluid or something that meets or exceeds 303 specs.
the stuff you linked has a vi of 140+ and a pourpoint of -45
It looks fairly quality and while not OEM fluid probably would work fine or at least work all year.
the OP's stuff has a vi of 61 and a Pourpoint of 0
so it basically turns into tar probably about 10F out.
pour point isnt pump point. So its probably not useable under 20F and would have issues even then.
also lack of additives in the op's 303 shield will cause excessive wear. Probably costing 10000$ or more to fix.
It gets really expensive to fix equipment that has the wrong fluid in it.
I wouldnt walk away I'd run away.
If you put the right fluid in now and it blows up it will suddenly be your fault instead of his.
The motor oil is bad too. 20w50 at -10F is thicker than some 5w30 at -35F
Edited by Rand (12/16/13 04:12 PM)
#3236067 - 01/03/14 02:13 PM Re: I need a fast Hydraulic Fluid answer! [Re: 79sunrunner]
BrandonVA Offline
Loc: virginia
lol there's no helping this guy....hope he has good insurance.
2006 Toyota Corolla LE, Manual - almost 100k
