I've noticed recently that on cold starts my start up noise is beginning to be a bit louder and have noticed what appears to be a slight knock. After doing some research I've found that rocker arm failures aren't unheard of for this engine. I've taken the following video, what do you think?
This video is after the engine has fully warmed and as you can tell there is a slight knock. It becomes easier to hear when I scan over the intake manifold, it tends to muffle the sound of the belt and injectors.
