Stapled down carpets ???
by Oldtom
07/29/16 01:51 AM
MicroGard (Wix) 57047 ~7k miles
by MrQuackers
07/29/16 01:24 AM
Ford 4.6 with Supercharger, 2,000 mi. / yr.
by milkboy
07/29/16 12:50 AM
Only secure content is displayed?
by Eddie
07/28/16 11:35 PM
2008 Honda Element oil question
by fujirio
07/28/16 09:50 PM
TIRE QUESTION
by renegade_987
07/28/16 09:46 PM
What's your favorite outboard and why ??
by BrocLuno
07/28/16 09:30 PM
Briggs 'Quantum 6.0' Flathead top no load 2600RPM
by Colt45ws
07/28/16 09:15 PM
EPA efficiency testing may not work, at all
by wemay
07/28/16 09:11 PM
Mobil 1 0w40 for 2013 4.8 V8
by CapitalTruck
07/28/16 09:04 PM
2013 Passat service
by powersmo
07/28/16 08:24 PM
A/C troubleshoot
by Leo99
07/28/16 07:50 PM
_hashtagusername, larrybroad123, dr_p, CapHead, rowebil
58632 Registered Users
47 registered (09_GXP, 2015_PSD, AnthemBassMan, Al, 97f150, 5 invisible), 1044 Guests and 10 Spiders online.
58632 Members
66 Forums
252385 Topics
#3218199 - 12/16/13 08:35 AM Best Grease for High Speed- High Load Bearings?
fins Offline
Loc: ohio
Have been reading the oil forums for years.......but just started reading all about grease. All kinds of grease red, moly, marine, synthetic, hi temp, etc......
I have a 72" finish mower behind my tractor......the bearings on the blades operate at pretty high speed and under some load.
What would be the best grease for this type of operation?
Would the same grease be recommended for wheel bearings?
#3218267 - 12/16/13 09:28 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
johnnydc Offline
Loc: Rochester, New York
I would have to believe wheel bearing grease would work good for that application.
1996 Mercury Cougar XR7 V8
2009 Mercury Milan V6
VWB and Motorcraft Filters
#3218407 - 12/16/13 11:50 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
229 Offline
Loc: Mid Atlantic
Chevron delo EP grease and Castrol Pyroplex are two that are well regarded.
Eneos Dealer
#3218418 - 12/16/13 12:03 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Dufus2 Offline
Loc: Virginia
Tacky Red grease with a 70 lb Timkin rating would do better than just plain chassis grease. Usually the industrial grease does well due to the hammering load of the gearbox pushing against the blades. Chevron, shell, schaffers they all have a good product that is not real expensive.
I used shell alvania and a few others with good results. Now days, I use Amsoil grease and their GLC is excellent, or the Truck grease.
ASE Certified in Med/Heavy Truck Service including A9
Heavy Equipment Repair, Fleet Maintenance
Real Cars Rattle and Smoke a Little
#3218764 - 12/16/13 05:06 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Ramblejam Offline
Loc: Kentucky
Here's what I use: http://docs.mystiklubes.com/msds_pi/M20026.pdf
Excellent performance & available at your local Wal-Mart for $3.67.
Pick up a battery powered gun and grease often!
#3219022 - 12/16/13 09:11 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
tom slick Offline
Loc: Central Coast, Calif.
The good news is you don't technically have high speed bearings. High speed bearings are about 10k rpm and above. A good grease rated for wheel bearings should serve you well.
You get what you pay for...
So keep in mind how much you paid for this advice.
#3392113 - 06/08/14 11:04 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Raybo Offline
Loc: Clearwater ,Florida
#3400346 - 06/18/14 07:13 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
Kestas Online   content
Loc: The Motor City
I agree with Tom. Lawn mower bearings are not considered high speed bearings.
#3408390 - 06/27/14 11:04 AM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
ironman_gq Offline
Loc: MN
I've always used disc brake wheel bearing grease. Mystik is what most of my stuff gets, it's cheap and not a bad grease.
#3452529 - 08/11/14 03:54 PM Re: Best Grease for High Speed- High Load Bearings? [Re: fins]
kawzak Offline
Loc: South Tx usa
At my work we designed a piece of equipment that had alot of heat and had a thrust brg that was subjected to both. At first I was going to use Dupont Krytox-extreemly expensive (typically I think it is in alternator brgs). However ater much research we decided on Redline brand CV-2. It handles both issues very well. it does turn brown-but I was told it would. We have been running this grease for over 2 yrs now. It works for us.
