cstoremotoroil.com
by AirgunSavant
08/27/16 09:37 AM
What's good/bad about a 2006 Mazda 5?
by 55Test
08/27/16 09:30 AM
My 1st air impact - go with 3/8" or 1/2" drive ?
by Cressida
08/27/16 08:55 AM
Silly me
by jay929
08/27/16 08:41 AM
15K oil & filter
by marine65
08/27/16 08:36 AM
Battery or starter
by Dallas69
08/27/16 07:56 AM
Napa Syn 15w50 to replace BradPenn 20w50 in 454bbc
by FlyNavyP3
08/27/16 07:51 AM
Real Main Seal Leak ? ? ?
by larryinnewyork
08/27/16 07:35 AM
Gov't wants to lower speed limits for trucks
by JetStar
08/27/16 07:11 AM
GM 55560202 longlife cut open - 10782km
by turboseize
08/27/16 04:54 AM
Coolant Question.
by Farmer
08/27/16 04:20 AM
Stocking up for the Eco
by buck91
08/27/16 12:25 AM
therhett17, glldprimr, krankshaft, Tony_Rhed, greasemonkey1
58935 Registered Users
80 registered (55Test, 4WD, 2015_PSD, a1mfw, 2004tdigls, A310, 8 invisible), 1658 Guests and 36 Spiders online.
58935 Members
66 Forums
253619 Topics
Page 3 of 3 < 1 2 3
#3218009 - 12/16/13 12:06 AM Re: 2013 Jetta Diesel [Re: jdw1222]
bigjl Offline
Loc: London, England
The issue of cam wear was spotted in Europe pretty early on after the introduction of the pd engine in higher spec VW models, Seat and Skoda stuck with the older TDi engines.
Several oil companies therefore brought out oils specifically for PD engines, in the same way as they also had Zetec oils for Fords. Castrol even had a Magnatec marked up for Vauxhall.
With the correct oil the Private Hire and Taxi trade regularly put 300k or 400k on Ford/VW or Seat 7seaters with few if any issues.
Most issues were I suspect from low mileage private owners who skimped on maintenance.
I have watched people at Halfords buy the cheapest oil they can see on the shelf, usually GTX and then you see them outside topping off a vehicle that is fairly new so extremely unlikely to be specced for that oil.
The problem is when these vehicles have issues later in their life Internet forums end up full of comments about their PD engine needing a top end rebuild.
As an example a large Private Hire Co in London called Addison Lee has a fleet of about 4000 seven seated vehicles, they use the Ford Galaxy now but used to use the VW Sharan with the 115pd engine.
After a three yr life they often get sold onto owner driver Private Hire drivers, they have at least 100k on them at three years.
You can easily spot them due to the fact they are all black and have a slightly unusual spec (seat colour and inbuilt child seats for example)
There are still many running about on 2006 and 2007 plates.
A mates brother works for the fleet department there and he said the only problems they had were with the autobox, the engines were reliable, they did use the correct oil though and changed the oil at 5k.
Over the years they used them they likely went through 20000 of these vehicles.
He also says the Galaxy with the 2.0 diesel is just as reliable, though the later ones with the Powershift box suffer from slight juddering on pulling away sometimes.
14 Kia Picanto 1.0 City 10k miles. Kia 5w30
07 Citroen Berlingo Multispace 1.4i 39k 10w40 Maxlife
#3622651 - 02/04/15 01:35 PM Re: 2013 Jetta Diesel [Re: jdw1222]
SR1919 Offline
Loc: TX - Texas
I have a question for our British colleague (bigjl), or anybody else from Europe who would like to contribute.
Has there been any cam issues (premature wear/failure) in "Pumpe Düse" TDI engines using VW 507 approved oils (since these oils have been used much longer than in North America)?
#3622678 - 02/04/15 01:52 PM Re: 2013 Jetta Diesel [Re: maineiac]
SR1919 Offline
Loc: TX - Texas
In general terms the TDI community considers additives such as Stanadyne, Power Service, Opti-Lube, Howe's, Liqui Moly, etc. as more beneficial than detrimental to the TDI engines (with or without DPF).
I would think that if you can bring your diesel fuel to the minimum quality standards that companies like Bosch require making your TDI engine run more efficiently then it will lessen the load on the DPF.
Makes sense?
Originally Posted By: maineiac
I can definitely agree with that. I always run a 4oz shot of Power Service Diesel Kleen whenever I fill up. [/quote]
You are talking about a car that requires an oil with an ash content that is insufferably low - 0.6 IIRC - to protect the DPF. You guys are putting stuff like this directly into the combustion chamber and therefore exhaust stream (as opposed to this strictly classified oil, which is only burned in minute qualities and then only as a residual of the lubrication process)? Do you have reliable information that would lead you to believe that this is OK for your DPF?
BTW, if you are concerned with lubricity and are confident that this stuff is DPF-safe, you'd be much better off with an additive that actually meaningfully enhances lubricity, like Opti-Lube. [/quote]
Page 3 of 3 < 1 2 3
