When should you replace brake pads?
I just had mine inspected and they said they are fine. 8mm on the front and 6mm on the rear. I know the front come with more material but don't last as long because of the ratio of front:rear brake.
I thought the fronts were probably close to needing replacing so I planned to put new pads/rotors on in a couple weeks - haven't done on this vehicle before but have on others. But I guess they are fine. After the inspection there is less travel in the pedal, too. Not sure why?
So at what point (i.e.: how much brake pad left) do they need to be changed? And anyone know how thick OEM pads are when new (for front and back - this vehicle is a 2010 Equinox)?
