Non-directional performance winter tires 205/65-15
by slacktide_bitog
08/25/16 06:14 PM
Is there a market for a used tool box? w/Pics
by Jimmy9190
08/25/16 05:18 PM
Review of Sangrean Weather Radio CL-100
by chiefsfan1
08/25/16 05:18 PM
Round holes AND louvers! Oh the humanity!
by Nick1994
08/25/16 04:20 PM
Should I change the oil when changing spark plugs?
by THafeez
08/25/16 04:08 PM
Maxima synthetic oil
by gman2304
08/25/16 04:02 PM
Mobil vs. Castrol: Battle of the Walmart 0W-40s
by 1JZ_E46
08/25/16 03:58 PM
Need advice for older car burning too much oil
by Car_Careguy
08/25/16 03:29 PM
Camaro 2.0T review by subaruwrxfan
by wemay
08/25/16 03:18 PM
Dryer Duct Boosters?
by 2015_PSD
08/25/16 03:02 PM
some strange lawsuits against fast food franchises
by John_Conrad
08/25/16 02:40 PM
Rotella T5 10W-30 in Chevy Z71
by RHALL
08/25/16 02:20 PM
ryaneirich, Gabe78, taters, Louis_Desbiens, Burk
58918 Registered Users
99 registered (123Saab, 09_GXP, 2010Civic, 1JZ_E46, 02s4audi, 10 invisible), 1515 Guests and 5 Spiders online.
58918 Members
66 Forums
253552 Topics
#3215327 - 12/13/13 09:13 AM A-RX in my Silverado 5.3- initial impression
zuluplus30 Offline
Loc: Fly-Over Country
About 1600 miles into my cleaning phase. My history is a 2009 5.3 AFM that began consuming oil around 25-30k miles. Currently 57k. Consumption got bad enough for the dealer to finally do the TSB fix for a revised PCV valve/cover and AFM shield in the oil pan. They also did a piston soak but said this fix is usually 50/50. Next fix would be engine teardown for piston & ring replacement.
Did a double dose of A-RX in Mobil 5000 oil. Took several 300 mile trips over the last 1600 miles. Initially, it continued to drink oil. Down 1/2 quart over the first 500 miles. However, it has begun to stabilize since then and is now only 3/4 quart down over the next 1100 miles. I'm not sure how much of this is the TSB and how much is the A-RX, but the consumption is definitely stabilizing. Also, for the first time in a long time, I am able to spin the tires from a standing start and trigger the traction control. I have no doubt A-RX is cleaning and has freed up some coked oil/carbon from the ring packs.
Just thought I'd share. I know it A-RX has fallen out of graces around here. Regardless, the journey ends here. I traded it for a Honda Pilot grin
#3215354 - 12/13/13 09:45 AM Re: A-RX in my Silverado 5.3- initial impression [Re: zuluplus30]
Trav Offline
Loc: MA, Mittelfranken.de
The piston soak cleaned the rings and boosted the compression. What was done in the TSB reduced the oil consumption.
I seriously doubt ARX did anything at all in 1600 miles.
#3215413 - 12/13/13 10:50 AM Re: A-RX in my Silverado 5.3- initial impression [Re: zuluplus30]
Donald Offline
Loc: Upstate NY
Its hard to know what has helped. I would finish with the ARX program.
Having before and after compression tests might have shown something. But its possible the compression rings can be fine and the oil rings gummed up, so you burn oil, but compression shows OK.
2015 Ford F250 w/Powerstroke
2001 Jeep Grand Cherokee Laredo 4.0- sold
1999 Dodge Ram 2500 w/Cummins- 4-sale
#3215544 - 12/13/13 01:08 PM Re: A-RX in my Silverado 5.3- initial impression [Re: zuluplus30]
Joe_Power Offline
Loc: USA - Coast to Coast, Border t...
Gee...I wonder why this engine is in such bad shape. Maybe if you try taking care of your stuff, you won't have these kinds of problems. I remember when I was a teenager......
2011 Jeep Wrangler
2015 Chevrolet 2500HD LTZ
2011 Harley Davidson FLHX
Common sense is a flower that doesn't bloom in everybody's garden.
#3215562 - 12/13/13 01:25 PM Re: A-RX in my Silverado 5.3- initial impression [Re: zuluplus30]
roadrunner1 Offline
Loc: oh
Two out of the three replies this gents post are negative, wow.
I have used Auto RX , and while I admit its not cheap it did work for me in several applications, so for me the cost was justified.
One truck, '48 Ford V-8 flathead, I use periodically for the PTO and it only idles, for a couple of hours at a time, since 1972. It never gets driven down the road and I knew the rings were gummed up. The Auto RX worked, as I'm sure many other products would have, but Auto RX is what I chose to use.
From reading the first post it seams as if GM had an acknowledged issue with this engine, hence the TSB. Why would someone suggest that the issue was caused by owner neglect?
'15 F350 6.7
#3215572 - 12/13/13 01:38 PM Re: A-RX in my Silverado 5.3- initial impression [Re: zuluplus30]
demarpaint Offline
Loc: NY
The OP no longer owns the vehicle, so we'll never really know the final outcome or long term results of the TSB of anything else for that matter.
God Bless Our Troops
#3215951 - 12/13/13 09:05 PM Re: A-RX in my Silverado 5.3- initial impression [Re: roadrunner1]
Trav Offline
The point is the GM dealer did a piston soak.
GM has one of the best top engine cleaners in the business, that and the mechanical work indicated in the TSB is much more likely to have helped the problem than something in a bottle.
