I don't drive it much as it sometimes will sit a week but recently started having a brake issue. Due to cold weather? Caliper hanging up? Braking at higher speeds I don't notice an issue but stop and go or at stop signs the brake pedal pulses sometimes and the truck continues to coast. Scared the [censored] out of me as I almost drifted through a stop sign! Almost feels as though the ABS is kicking in. Checked fluid level and it is good. I do know my rotors could be replaced due to slight warping but not terrible. Pads replaced 7 months ago and are good. This morning on way to work I did jump on them a little harder at stop signs and worked fine except right before the truck was about to stop I could feel the brakes slip or let up. Brake pedal feels normal.....not spongy except when the ABS or slipping kicks in. Of course then they get mushy but it doesn't stop well. Any way I can self diagnose and repair?
Thanks,
Scott
Thanks,
Scott
