Speed & Temperature ratings vs cold PSI
by badtlc
05/31/16 10:52 AM
Worthy of a news story??
by andrewg
05/31/16 10:13 AM
Gorilla Shooting...decaying moral values?
by Smokescreen
05/31/16 09:53 AM
Oil Change Frequency - 04 Neon
by racer12306
05/31/16 09:15 AM
Great PDF on Mazda Skyactiv
by buster
05/31/16 08:43 AM
2014 Chevy Silverado 1500 CC. 5.3L 4WD Oil
by AirgunSavant
05/31/16 08:13 AM
0W-40 for 223k mile 95 Mercedes E320?
by gregoron
05/31/16 06:22 AM
I hate surprises
by Excel
05/31/16 06:10 AM
Wix coolant filter change and cut open
by A310
05/31/16 03:45 AM
O2 Sensor Voltage
by Falcon_LS
05/31/16 01:36 AM
Electrical shock at the grocery store
by Merkava_4
05/30/16 11:42 PM
Another should I change my oil thread
by dan_erickson
05/30/16 10:53 PM
ph9, Kurt34556, Skullzaflare, Jakes_Lawn, Aarrghhh
58031 Registered Users
88 registered (87sammy, 757guy, Abakev, 901Memphis, Andrei, AndyB, 6 invisible), 1811 Guests and 141 Spiders online.
58031 Members
66 Forums
249626 Topics
#3209608 - 12/07/13 03:38 PM ATP AT-205 , Can it make things worse ?
quant Offline
Loc: Canada
Hello,
I have a 99 Mazda with over 300,000km (186+ miles) on the odo. It seems like it has a small leak on both the front and rear seal but since the car is nearing it's end of life I don't want to spend the money on pulling the transmission/timing belt and replacing the gaskets.
Currently the leak isn't bad, a few drops here and there so not a huge issue.
I am considering trying the ATP AT-205 re-seal but only if it doesn't make things worse. According to my research it seems to be 100% DIETHYLENE GLYCOL MONOETHYL ETHER. The ATP staff refer to it as "plasticizer" .
Can it make things worse ??? If it can't make things worse, lets give it a try, if it can, I might as well wait until things are really bad !
#3209612 - 12/07/13 03:43 PM Re: ATP AT-205 , Can it make things worse ? [Re: quant]
michaelluscher Offline
Loc: Tri States Little Italy
Don't add the whole bottle and you'll be fine.
4oz should be enough.
'06 Toyota Camry SE V6 3MZ-FE 51k
'01 Mercury Villager Estate VG33E 48k
'06 Ford Taurus SE Vulcan 48k
'13 Chrysler 300 3.6 Pentastar 45k
2012-2015
#3209635 - 12/07/13 04:19 PM Re: ATP AT-205 , Can it make things worse ? [Re: quant]
NHGUY Offline
Loc: USA
In New England 186K miles is just the beginning....as long as there is enough metal left to attach pop rivets or bondo to.
#3209644 - 12/07/13 04:27 PM Re: ATP AT-205 , Can it make things worse ? [Re: quant]
jhMalibu Offline
Loc: Boston, MA
Coworker with an 03 (I think) MPV with leaky seals tried that stuff. While it didn't cure it, tranny didn't grenade. They have become more aware about checking the fluid level as it had gotten pretty low.
It won't hurt anything. Just don't expect miracles.
#3209939 - 12/07/13 10:27 PM Re: ATP AT-205 , Can it make things worse ? [Re: quant]
dino33 Offline
Loc: British Columbia
I bought some for a newly acquired Geo Metro that was losing a quart of oil every 250 miles due to a distributor seal leak. Was worried like the Op about over swelling and the risk of a big leak. The company states that while it swells seals the seals are not softened or weakened like other seal swellers. I went ahead and put nearly a full bottle in the little one liter engine and have to say that it does seem to be working nicely. I've driven about six hundred miles and have only lost a liter. Atp folks say that it takes five hours of driving for it to kick in, so I'm hoping this stuff will do it's magic...
2004 Toyota Prius 165K miles Redline 5w30 LG Biotech Fram Ultra filter
1996 Geo Metro gas mizer oil guzzling $300 pizza man car
Filtermag!
#3212792 - 12/10/13 08:00 PM Re: ATP AT-205 , Can it make things worse ? [Re: quant]
MolaKule Offline
Loc: Iowegia - USA
The DIETHYLENE GLYCOL MONOETHYL ETHER is produced by Dow under the trade name, "Carbitol."
It is used as a solvent for paints and varnishes.
When you choose the Behavior, you choose the Consequences. smile
#3212927 - 12/10/13 10:25 PM Re: ATP AT-205 , Can it make things worse ? [Re: dino33]
Quest Offline
Loc: beaver land EH?
As I told you before: 15 mins and a 3dollar O-ring from the stealership and your leak is fixed for at least 6 to 8 yrs down the road without the need of replenishing motor oil.
How much better than that can you get (other than resort to using short-term temporary fix?)
Q.
"Internet discussion boards act as echo chambers for conspiracy dittoheads" A.Allen
#3215128 - 12/13/13 03:08 AM Re: ATP AT-205 , Can it make things worse ? [Re: Quest]
dino33 Offline
I agree Quest, I had some extra Atp kicking around so I gave it a shot just to see how it would work with the distributor seal, and also, attempt to 'freshen up' all the other seals including the main crank seal. I will be replacing the distributor seal soon enough. I believe Atp is legit and not snake oil....
Filtermag!
